04-23-2022, 10:04 AM | #851 |
Post Whore
Re: My Dusty 71 GMCe Electruck
36" divided by 4 equals enuff sticks for 2 battery modules
how do you properly cut threaded stock to keep the nuts going back on them, any tips? |
04-23-2022, 10:06 AM | #852 |
Post Whore
so one on top and one on the bottom, upside down, bat style
04-23-2022, 10:08 AM | #853 |
Post Whore
so this is the Oreo Cookie battery tray design, respectfully stolen from Sir Artur Kustusch
Jaguar XJR EV Conversion - Battery Box Build - Part 1 Last edited by Gregski; 04-23-2022 at 10:19 AM. |
04-23-2022, 10:21 AM | #854 |
04-23-2022, 10:23 AM | #855 |
Post Whore
04-23-2022, 10:24 AM | #856 |
Not necessarily, the one you used is curved, and that affects the aerodynamics of the downward strike....
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-23-2022, 10:24 AM | #857 |
I've done the same thing but I also grind a taper on the end of the rod before taking off the nut. It leaves a nice clean cut.
04-23-2022, 10:24 AM | #858 |
With all tread, I typically spin a nut on before I cut and then taper the cut on a bench grinder and lastly spin the nut off to clean the threads. Hopefully this makes sense
71 C10 72 K20 72 K10 Super Kirk |
04-23-2022, 10:26 AM | #859 |
Post Whore
not sure if you are serious or not, my original point was that them pretzel sticks don't always fit the holes nice and snug, some sticks are just a bit too big the others just a bit too small, so when you stick the stick that will fit in the hole there is some play some times, kapish, iriegardless of the downward strike
04-23-2022, 10:27 AM | #860 |
OH, I get it now.
04-23-2022, 10:32 AM | #861 |
Post Whore
it does, and I've done the same, I was hoping for some super duper trick especially when you are using Grade 3 or Grade 5 nuts, they are really soft metal and the nut gets damaged in the process of trying to bend the all thread into submission, know what I am sayin', I guess you could use harder material nuts like Grade 8
04-23-2022, 10:37 AM | #862 |
04-23-2022, 10:49 AM | #863 | |
Post Whore
there's also this for only $400 bucks (at $2.50 per pre cut 1 foot rod, we could buy 160 pre cut rods for that price) ha ha |
04-23-2022, 11:22 AM | #864 | |
This build thread is fascinating. I'm subbed now.
'71 C/20 350/T350. |
04-23-2022, 11:27 AM | #865 |
Post Whore
tried that, the 1/4-20 thread die wouldn't even screw on to the original uncut threaded rod to begin with, strange? I thought but with today's quality and it being a cheap die set, who knows
04-23-2022, 11:38 AM | #866 |
Post Whore
so here's a peak looksee what we are going for, I don't even know if that Tesla Model 3 battery charger / DC-DC converter combo unit is laying on there right side up or upside down, (you tell me, ha ha)
I am also entertaining shoving it under where the oil pan used to live there may be just enough of a cavity to bolt it up to the battery tray from underneath, for that German like impossible to get to to troubleshoot feel |
04-23-2022, 05:59 PM | #867 |
Post Whore
actual footage of me going to clean the THIRD lower control arm
04-23-2022, 07:46 PM | #868 |
Post Whore
The Nigerian ball joint puller !
04-23-2022, 07:48 PM | #869 |
Post Whore
and this is all the crud that we manually remove with some hand tools such as the putty knife and metal toothbrushes and some elbow grease before even thinking of spreading the rest across our beautiful lawn with the wire wheel
04-23-2022, 07:49 PM | #870 |
Post Whore
and here it is after the first encounter of the four inch kind
04-23-2022, 07:52 PM | #871 |
Post Whore
so I thought maybe all that tar and road grease and grime is good for it maybe that keeps it from rusting? WRONG !
rust is like cancer, it is nasty and dwells under all that grime which only serves to capture and encapsulate moisture |
04-23-2022, 07:54 PM | #872 |
Post Whore
so got a new jug of Concrete and Metal Prep which they renamed, removed the "removes rust" part and there is no mention of Phosphoric acid anywhere on the 90% in Spanish label, also they raised the price, can't wait to see how lame this assumably new formula works
04-23-2022, 07:56 PM | #873 |
Post Whore
No One: How do you know when to stop wire wheelin'?
Me: |
04-23-2022, 07:58 PM | #874 |
Post Whore
the steerage got some Cool Whip treatment as well
04-24-2022, 03:24 PM | #875 | ||
There is always that set of jeweler's files that come in handy for unbuggering threads.
