12-28-2013, 10:22 PM | #8901 |
Re: What did you do to your truck today?
Me and the little lady took the 66 out for a drive and bike ride. Then downtown to grab a bite to eat. Even though we were doing 10 under on the hwy we still got thumbs up haha. Gotta love driving home with the cool dim green lights on the dash. I love this old truck.
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
12-29-2013, 11:06 AM | #8902 |
Active Member
Finishing up my power steering install. Using a CaptainFab plate and shaft flange. Excellent quality product, thanks Captain.
12-29-2013, 01:26 PM | #8903 | |
12-29-2013, 02:24 PM | #8904 |
Got bored and cleaned up the engine bay with some new colors.
12-29-2013, 03:46 PM | #8905 |
Man wish we had -3f, would be awesome instead of -35celcius, poor truck just sits.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
12-29-2013, 07:32 PM | #8906 |
Doug out the 71GMC out of its resting place for the past couple years. Swapped in stall convert or so I can use stock one in the 65 camper eng trans swap. While there replaced seals and installed b&m deep pan, replaced fuel pump and got it running. Wohoo!!!!!!
71 GMC Long Bed, 454,factory everything, lowered, and shaved. 64 GMC Short Bed (great grandfathers truck) 65 Chevy 1 ton Dually a/c p/s p/b v8 auto 89 Jeep Cherokee 3" lift 79 MG Midget (My 7 year old vehicle) 29 Ford Model A Rat Rod (in the works) 86 pontiac fiero 2.5 manual18 year olds) 87 pontiac fiero SE 2.8 auto (18 year olds) 90 Mitsubishi eclipes turbo AWD (18 year olds) 69 BMW 1600 (wifes toy) |
12-29-2013, 11:33 PM | #8907 |
brought it home.
sadly this is the last hurrah.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-30-2013, 11:10 PM | #8908 |
Installed my Collector plate on... found a backing plate off another car
Big woof .. well to me it's a big deal because it means "The Man" can't ticket me for driving/parking truck on street for non Lic plate . names is not "Jamie" but do still think good girls like bad boys. I put that frame on temporary it was either this or "Happiness is being a grandparent"........sp . . |
12-30-2013, 11:31 PM | #8909 |
Today I stood in my garage and drank beer with a buddy while he drooled all over the truck. Good times.
12-30-2013, 11:33 PM | #8910 |
Today I drove it.. yesterday I drove it. Friday I picked up sheetrock and Durarock at Lowes for a job I am doing and tomorrow I am going to drive it. I love this truck.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
12-30-2013, 11:49 PM | #8911 |
some metal work on the floor support today
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust |
12-30-2013, 11:50 PM | #8912 |
i didnt take a pic today so i just used this one of the inner rocker section
12-30-2013, 11:53 PM | #8913 |
After fixing a "new" oil leak, took the '65 and went to a friends and bought a C20 rolling chassis. Starting a new dually project. It already has a good 14 bolt in it on coil spring rear. My C30 disc brake FE will go right in it. I have a 6.5 TD and an Allison for it already.
Will post a build thread when it actually starts. |
12-31-2013, 11:08 AM | #8914 |
The 60-66 GMC/Pontiac guy....
Worked on my friends 62, doing a disk/bag conversion.
Started My 66 to make sure the battery isn't dead. Also looked at my 65 and 63 sitting there begging for attention like loyal dogs. Gotta get my Bud's 62 out of my driveway first.. New Year Resolution #1..... work on my own stuff
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
12-31-2013, 02:39 PM | #8915 |
Active Member
12-31-2013, 02:57 PM | #8916 |
One day...
Got the battery box tacked up and mounted
12-31-2013, 08:23 PM | #8917 |
installed new sending unit, but truck wont start getting a lil gas from line at carb.,not sure if theres not enough gas or if somethings wrong with fuel pump
01-01-2014, 12:01 AM | #8918 |
Should have still had fuel in old pump to start it up, maybe something to do with the sending unit pickup, I would try filiing the fuel line up first from carb down to the pump just to prime it and see if it continues to run, hope so if not when it use the bit of fuel used to prime it then back to pump or tank.
01-01-2014, 10:41 PM | #8919 |
Pressed the last few pieces off the main shaft of my soon to be rebuilt Camaro T5 with an S10 tail housing swap. I will order the rebuild kit tomorrow and finish cleaning parts until the kit arrives. This is a great learning project for me.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
01-01-2014, 10:58 PM | #8920 |
Today my offspring drove her truck for the first time since converting to a big back window and lowering. I have not posted any pick but I will post a before and after pic.
01-01-2014, 11:02 PM | #8921 |
I put mine to work again.
01-01-2014, 11:04 PM | #8922 |
i love your truck!!!! Sweeeeeeeeeeeeeet
01-01-2014, 11:32 PM | #8923 |
I've been underneath the rear of the truck for the last few days installing C-notches. I've done so much grinding, drilling, air chiseling, and cutting that I feel like I've gone 12 rounds with Mike Tyson. Almost done!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-02-2014, 12:10 AM | #8924 |
Thanks... I love driving it.
01-02-2014, 12:14 AM | #8925 |
With the bed on.....? Why..
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
