Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-10-2010, 06:19 PM   #876
silver7
silver7's Avatar
Re: 68 K-10 SWB build thread - project Money Pit...pics galore!
I need to do the same thing myself. Had to drive to SC to get it but I got a great deal when I bought my 80 gallon air compressor off a guy on Craigslist. But I still have yet to bolt it to the floor and I'll make sure I use a rubber pad to buffer the vibrations.
Ran external conduit for the 220v myself and it was a lot easier than I thought. Couldn't imagine doing my rebuild without this big son of a gun.
She may be ugly, but those old compressors are dependable and if you are luckily -cheap. Good score Mike.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 01-10-2010, 09:55 PM   #877
msgross
msgross's Avatar
got old Betsy wired for 220v 20 amp today. Easier than I thought, like you said. Ran a new 20amp breaker from the basement and put in a 20 amp dual pole light switch so that I can turn the power off.
She kicks on at 100 psi and off at 135 right now, that should be good for me. When it's running I can run the die grinder at 80 psi and the main pressure gauge barely moves!!! I loosened the floor bolts today while she was running and the vibrations didn't changed. I might find some rubber but to be honest, this thing is 50 years old and still running...is it really going to matter?
thanks for the offer dammitmitchell, i'll hold off right now. I might snag some pieces of the kids floor puzzle when I get a chance... I'm 6'3" @ 250lbs and I can barely move the beast!
still no truck update, but I did get the x-mas lights down and managed not to die inside my house breaker panel!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-10-2010, 10:19 PM   #878
my67chevytruck
Under Construction
my67chevytruck's Avatar
good progress Mike. great looking parts..
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-10-2010, 10:44 PM   #879
msgross
msgross's Avatar
that's what she said!!!
sorry, had to...
The Garage:
Old 01-11-2010, 04:23 AM   #880
vk_chevy
vk_chevy's Avatar
that compressor definitely has a character, I like it.
I would also suggest to fab up belt guard for it.
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 01-11-2010, 07:04 AM   #881
msgross
msgross's Avatar
Character is a good description!
a belt guard would be nice, since it's tucked in the corner nobody should accidently walk into it, but I can see some fingers or clothing getting caught if not careful...
The Garage:
Old 01-11-2010, 10:52 AM   #882
my67chevytruck
Under Construction
sorry, had to...
Well, now you can say you've had 1 cheerleader in your life!!
sorry, had too.........
now get busy on the money pit!!!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-13-2010, 08:47 PM   #883
msgross
msgross's Avatar
ok, im heading out to the garage to work on the rad support... it will be at the powdercoaters by Friday!
The Garage:
Old 01-13-2010, 09:01 PM   #884
my67chevytruck
Under Construction
bout time!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-15-2010, 10:59 PM   #885
msgross
msgross's Avatar
well, I was hoping for the powdercoaters on the rad support today, but didn't make it that far. My metal shop at work had a berillium incident and had to seal the doors. I was planning to use the shear and metal brake but had to resort to a clamp and hammer to bend some steal. Last of the rot on the lower portion of the rad support, I plan on grinding tomorrow and seeing if the PC guy is open. If not then Monday...
The Garage:
Old 01-16-2010, 11:12 AM   #886
glimmertwin01
glimmertwin01's Avatar
Mike.... looks like you had to resort to My method of fabrication...lol looks good..an no one will see it anyhow
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 01-16-2010, 03:00 PM   #887
msgross
msgross's Avatar
true, if I hadn't replaced it though it would have driven me nuts! Would have been nice to use the brake, but it's not a sharp 90 degree curve anyway...
Is there supposed to be a drain hole under the radiator?
The Garage:
Old 01-16-2010, 04:52 PM   #888
glimmertwin01
on newer stuff there is.... it cant hurt to have one just in case...
ive been workin on strippin own my latest a 74 K5... its on the build page under the next gen trucks
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 01-17-2010, 07:55 PM   #889
msgross
msgross's Avatar
made some progress today...
radiator support is pretty much ready for the powder coaters tomorrow.. Had some rust area that needed fixed, also had to weld in some nuts for the lower pan, the lower pan also had some rust... It's not a perfect fix but should barely be noticeable once coated...
SHould I PC the lower pan or rhino line it? I'm thinking of using the Raptor liner on any metal facing the ground (front pan, inner front and rear fenders, under cab, bottoms of bed sides)
The Garage:
Old 01-17-2010, 08:01 PM   #890
msgross
msgross's Avatar
I'm always afraid to grind to much metal away so i'll leave it as is...
Had to mount it up to the truck just for a glance of hat she use to look like..
Welded in the lower 4-core mounts and sat a grille in place. I doubt that i'll be using this grille now that Seacrow sent me a perfect grille from FL. I might plate this area near the left mount though, rust took it's toll back in the day...
Off to the Powder House tomorrow...rad support, air cleaner, battery mount, hood latch and support, washer bottle and upper radiator pipe...
The Garage:
Old 01-17-2010, 08:03 PM   #891
msgross
msgross's Avatar
started a diet on friday (kinda ) wife insisted on snapping a pic, can you see my enthusiasm?
I plan on 20 lbs in 12 weeks...
The Garage:
Old 01-17-2010, 08:16 PM   #892
glimmertwin01
LOL you need a diet? your enthusiasm is ovewhelming...
do you get to tell her when she needs a diet too? LMFAO...
the core supprt looks good man
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 01-17-2010, 08:39 PM   #893
msgross
msgross's Avatar
i'm 6'3" 255 right now, heaviest yet... i'd be happy to go to the beach if I lost 20 lbs...
wife is 5'9" 120lbs... she can't gain weight! that's after three kids too...
The Garage:
Old 01-17-2010, 08:54 PM   #894
glimmertwin01
youre lucky well i should say she is...
im still a svelt 6ft 195 been that way for yrs...
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 01-18-2010, 06:52 PM   #895
sourkraut
sourkraut's Avatar
How did you make out at the coaters today?
Dude I have been 190lb since 12th grade and just in the last year & half have worked my way up to 227lb? Were the hell it came from I dont know? So you are not alone!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 01-18-2010, 06:59 PM   #896
glimmertwin01
blame it on mammas home cookin....LOL
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 01-18-2010, 07:01 PM   #897
msgross
msgross's Avatar
John, I think that your scale has been broken since high school and now you found an accurate one
dropped off the rad support, air cleaner, battery box, grille inserts, washer bottle holder, and upper radiator pipe to be powdercoated today. Hopefully his 60% matches what we did at your place.
Can your over hold a hood hinge? I hope so because he wanted $45+ for each one! I brought that and my pedal assembly back home. Says it should only take a few days... it's actually the chick that does most of the work there...
I bought fresh Talipia fillets so I could fell like I was dieting... then the wife cooked them like scampi (floating in butter) !!!
The Garage:
Old 01-18-2010, 09:24 PM   #898
sourkraut
sourkraut's Avatar
The thing that sucks is, the last time I was at the Dr. there scale said the same thing mine does!!
I think we should be ok ont he hood hinge but I will check tomorrow night to be sure. We might have to hang it on the rack first then coat and place in the oven. That is weird that he wanted $45 for each and is doing your rad support for $50? Was he still at $50 for your support?
Old 01-18-2010, 10:06 PM   #899
msgross
msgross's Avatar
we'll see.. his pricing sheet has a range, it all depends on how much blasting they have to do. Since my support had already been blasted, then prayed with rustoleum primer to avoid rusting, it shouldn't take much... I don't like dropping things off without a hard quote, but we'll see.
The Garage:
Old 01-18-2010, 10:18 PM   #900
silver7
silver7's Avatar
I recently participated in a weight loss competition at work and lost 20 lbs in about 5 months. I had put on a few lbs in grad school so I was up for it. Peer pressure and the joy of competition was a motivator for me.
Good luck with that Mike.
Shawn
1971 C10 4x4
