Old 02-24-2012, 08:53 AM   #876
77chris03
77chris03's Avatar
Re: My 68 swb build.
heres the mess of wires pic....it should be cleaned up tonite...
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 02-25-2012, 12:21 AM   #877
Slick67
Sofa King Crazy!!
Slick67's Avatar
Spagetti bowl!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-25-2012, 01:56 AM   #878
77chris03
77chris03's Avatar
haha spagetti bowl...
i got a few things done tonight but nothing extravagant....i tried to get her fired up but that didnt happen....heres what i did...
got the drivers door gasket back in and hopefully it will seal like the passengers door...got all the wires tucked under the dash except the wires for the windows....im having a problem with the turn signals, etc...gotta figure it out its driving me crazy...got the floor cleaned up...yay!!!
i got the throttle linkage hooked up and got the gas pedal installed...i think thats it.
Old 02-25-2012, 10:23 PM   #879
77chris03
77chris03's Avatar
Old 02-25-2012, 10:35 PM   #880
Twisted Illusionz
What company did you get the steering column from. That chrome looks good in there. Much better than just a painted one.
Twisted Illusionz is offline   Reply With Quote
Old 02-26-2012, 01:32 AM   #881
68 TT
Still plays with trucks
68 TT's Avatar
Great to see & hear it running.
Nice work on the tail light french job. Can't wait to see the lights in place.
Keep up the great work.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-26-2012, 01:44 AM   #882
77chris03
77chris03's Avatar
It's stainless....Chrome steering wheel adapter...eBay...
Old 02-26-2012, 12:16 PM   #883
77chris03
77chris03's Avatar
ITS ALIVE....!!!
Old 02-26-2012, 12:18 PM   #884
77chris03
77chris03's Avatar
Old 02-26-2012, 11:17 PM   #885
77chris03
77chris03's Avatar
Old 02-26-2012, 11:21 PM   #886
77chris03
77chris03's Avatar
Old 02-26-2012, 11:23 PM   #887
77chris03
77chris03's Avatar
Old 02-26-2012, 11:24 PM   #888
Slick67
Sofa King Crazy!!
Slick67's Avatar
That's awesome!!!!! Congratulations!!! Just got a shower, I am tuckered.......
Old 02-26-2012, 11:28 PM   #889
77chris03
77chris03's Avatar
i got the cab mounts finally tightened down, started securing the brake line on the frame and doing some little stuff under the truck while i had the jack under it. i think im gonna rerun the gas line so the bends are the same as the brake line...
Old 02-26-2012, 11:29 PM   #890
77chris03
77chris03's Avatar
did you get a trophy? btw i think my seal is leaking on the crank...got a small bit of oil from the flywheel cover...
Old 02-26-2012, 11:33 PM   #891
Slick67
Sofa King Crazy!!
Slick67's Avatar
No trophy.... Clean it run it and start looking for the leak, should be a PITA.
Old 02-27-2012, 12:01 AM   #892
77chris03
77chris03's Avatar
NOTED>>>>> i always assume that....lol
Old 02-28-2012, 01:33 AM   #893
77chris03
77chris03's Avatar
tried to get the fuel line re ran...i didnt like the way it looked....i do have one question...can i put the fuel filter before the fuel pump next to the pickup?
Old 02-28-2012, 11:56 PM   #894
77chris03
77chris03's Avatar
someone chime in please...
Old 02-29-2012, 12:20 AM   #895
77chris03
77chris03's Avatar
anyone...??
Old 02-29-2012, 12:23 AM   #896
Slick67
Sofa King Crazy!!
Slick67's Avatar
What pickup are u referring to? Shouldn't matter where you put it just as long as you can access it easily. Mine is right on the frame just a few inches from the pump, another at the back above the rear axel.
Old 02-29-2012, 12:27 AM   #897
77chris03
77chris03's Avatar
located at the tank...i cant get the bend i want...figured id do one at the tank(pickup at the tank) and one right before the fuel pump....so i guess if yours works, so will mine...
Old 02-29-2012, 12:30 AM   #898
Slick67
Sofa King Crazy!!
Slick67's Avatar
Go for it!!!!!
Old 03-03-2012, 10:52 PM   #899
77chris03
77chris03's Avatar
Old 03-03-2012, 10:55 PM   #900
77chris03
77chris03's Avatar
