Old 11-23-2016, 12:29 AM   #876
big_moss
big_moss's Avatar
Re: How about some pics of bagged 47-59
whats everyone running for lowers arms on their bagged a.d.s I've got speedway uppers and I'm going tho be notching the rear with a parallel 4 link just want the frame to lay and the running boards to lay flat with frame going to try and mount the cab as low as possible
big_moss bagged 51 3100 build
big_moss is offline   Reply With Quote
Old 11-23-2016, 11:44 AM   #877
99 to Life
99 to Life's Avatar
for the s10 frame, the stock lowers are fine. I didn't even have to dehump mine. and I was maybe 3" or under off frame, RB hit ground. You can find some threads online s10forums and such, on how to dehump the arms if you need. Personally, lower arms are pricey and the stock lowers do the same thing. I rebushed mine, which was $75 I do believe, so new balljoints and bushings you got yourself in around 150$ give or take. Even if your lower arms where no good, I would find a used set or buy some OEM s10 arms. again its just one area where its not necessary spending hundreds of dollars on, esp early on in a build. Just my take
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-23-2016, 09:23 PM   #878
lower50's
lower50's's Avatar
I used tubular upper and lower nice stuff link below. My frame sits about 3" off the ground. Cab is about 1/2" off the frame.
http://www.airassisted.ca/Bolt-in-Ai...r-Control-Arms
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-05-2016, 03:20 PM   #879
ironadict
ironadict's Avatar
Hey skunkswife, I know this post was years ago but I was wondering how tall of tire wheel combo you were able to fit under your step side bed. I'm starting a 57 project and trying to get all the math straight. Thanks!
HOTROD HOODLUM
ironadict is offline   Reply With Quote
Old 12-05-2016, 03:23 PM   #880
ironadict
ironadict's Avatar
Originally Posted by skunkswife View Post
here are a few recents of mine
What size tire wheel combo did you fit under the back? Beautiful truck!
HOTROD HOODLUM
Old 12-06-2016, 03:53 PM   #881
ironadict
ironadict's Avatar
Originally Posted by tpimuncie View Post
Hey is that the scottshotrods super slam? I just got quoted for one and am planning on going that route. How do you like it? Does it allow you to lay rocker? Thanks!
HOTROD HOODLUM
Old 12-06-2016, 04:03 PM   #882
513CHOPSHOP
513CHOPSHOP's Avatar
My 56 on Air
513CHOPSHOP is offline   Reply With Quote
Old 12-06-2016, 04:43 PM   #883
ironadict
ironadict's Avatar
Originally Posted by 513CHOPSHOP View Post
My 56 on Air
513chopshop that's a rad truck. Was just looking over your build thread. I'm starting a 57. Did you need to chop out any cab with single piece drive line? Also whats that tire wheel combo? Looks perfect
Thanks for posting
HOTROD HOODLUM
Old 12-07-2016, 10:09 AM   #884
513CHOPSHOP
Thanks for posting
Ironaddict , Thanks!! I had to notch the factory cross members but not the cab itself. The wheels are mobsteel 20x9s with the custom offsets.
Old 12-08-2016, 05:03 AM   #885
Perämettä
My -56
Perämettä is offline   Reply With Quote
Old 12-09-2016, 12:55 PM   #886
skymangs
skymangs's Avatar
my 49
skymangs is offline   Reply With Quote
Old 12-11-2016, 12:28 AM   #887
Cjcolbyjack
Beautiful trucks! Every single one!Name:  FB_IMG_1463173340474.jpg
51 motor buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=718113.
54 3600 Lincoln aviator chassis swap
http://67-72chevytrucks.com/vboard/s...d.php?t=717927
Cjcolbyjack is offline   Reply With Quote
Old 12-11-2016, 04:29 PM   #888
skymangs
skymangs's Avatar
Here's here's a couple more pics of my 49
Old 12-11-2016, 04:33 PM   #889
skymangs
skymangs's Avatar
Last one.
Old 12-11-2016, 04:33 PM   #890
tpimuncie
tpimuncie's Avatar
Yeah its the scotts ifs but switched it out and went hydraulics
Rockers dont hit but im happy with it
tpimuncie is offline   Reply With Quote
Old 12-11-2016, 08:44 PM   #891
Advanced Design
Advanced Design's Avatar
Chris, I love that truck of yours! It didn't get hurt in the fire did it? Man I hope not....
Advanced Design is offline   Reply With Quote
Old 12-11-2016, 09:34 PM   #892
skymangs
skymangs's Avatar
Nope, that one was under the covered parking luckily.
Old 12-12-2016, 07:36 PM   #893
lower50's
lower50's's Avatar
Cjcolbyjack Your truck tucks the wheels very well.
skymangs Very nice looking truck!! What do you have to lift your bed?
1951 MG TD
Old 12-12-2016, 07:54 PM   #894
murd969
Here's my 56'. Full accu-air with e-level and ridetech shockwave bags all around.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 12-12-2016, 08:47 PM   #895
skymangs
skymangs's Avatar
I used pillow blocks from Grainger with a 1 inch ID. Then I just bolted in a 1 inch piece of round tube. Then I built a simple framing for my bed and welded it to the round tube. It is all detailed in my build thread in my signature.
Old 12-14-2016, 02:15 AM   #896
Bone$
My 54....
Bone$ 54 Gmc Build
Bone$ is offline   Reply With Quote
Old 12-14-2016, 01:04 PM   #897
skymangs
skymangs's Avatar
It is perfect just the way it is put a back window in it and drive the wheels off it.
Old 12-16-2016, 11:27 AM   #898
laid67c10
laid67c10's Avatar
Some progress on my 49.
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!!
09 - Harley nighttrain on air ride!
laid67c10 is offline   Reply With Quote
Old 01-01-2017, 07:52 PM   #899
big_moss
big_moss's Avatar
Laid67 do you not have a build thread truck looks awesome man
Old 01-01-2017, 08:22 PM   #900
BigFrz
Originally Posted by laid67c10 View Post
Still in the works, mine is the one closet in the pic, the other two belong to a couple of my buddies! All will be bagged and LS powered! All s10 clips and full 3/4 custom frames!
In the pic it looks like you shortened your rear end is it.
BigFrz is offline   Reply With Quote
