07-05-2014, 08:04 PM | #876 |
Re: What did you do to your truck today? Chapter II
just put seats in
07-05-2014, 08:13 PM | #877 |
Lots....got cab off replaced bushings and bolts...cab is mounted.
Cut out lots off rust to replace front and rear cab mounts. Passenger side front and rear mounts are mounted and welded in. Built my own inner rocker panel, and it is mounted and welded in. I didn't want side markers, so I made some templates out of cardboard, cut some sheet metal, and good bye side markers. Filled and sanded....just need to primer them. Finally, I didn't want the bed light so I removed it, built a patch, and got it welded on. Still have to do the bodywork, but it is welded in and ground flush. A lot accomplished....just nothing real visible yet until we start to put truck back together. |
07-05-2014, 09:53 PM | #878 |
Removed the mid-bearing support & welded the seams on the trailing arms.
Brad handshoe |
07-05-2014, 11:22 PM | #879 |
Drove it on a 100mile round trip to the nifty 50's show .. Ran like a top and the vintage air blew ice cold!!! After all the problems I've had since the cam swap it was good to finally get all the links worked out and be able to enjoy it
07-05-2014, 11:28 PM | #880 |
Took off the passenger side upper and lower control arms and labeled everything to go to a shop so that i can get old bushing pressed out and new ones pressed in.
07-08-2014, 08:17 AM | #881 |
Finally got to go pick up my freshly balanced rotating assembly. Time to clean the engine up and start the assembly this weekend. After 5-1/2 months in machine shop jail...
07-08-2014, 03:34 PM | #882 |
My wife wants me to get a gap-filling plate to go between the radiator and the grill - like she saw on a friend's truck. Who am I to say no??
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
07-09-2014, 09:16 PM | #883 |
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch" "An intellectual is a man who takes more words than necessary to tell more than he knows" |
07-10-2014, 05:46 PM | #884 |
She sounds like a keeper!!! Your a lucky man.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
07-10-2014, 07:14 PM | #885 |
07-11-2014, 08:24 PM | #886 |
put on some tall chevrolet valve covers. was doing a timing check and did a vacuum check with my gauge....and now my truck is smoking out the exhaust -_- mainly out the passenger side
07-12-2014, 08:28 AM | #887 |
My Burb did the same thing, smoke from one side it was valve guides (but decided to have the heads done). Valve guides are very cheap, but had to remove the lifters and push the new ones down on.
07-12-2014, 04:08 PM | #888 |
Also dealing with valve covers! PO decide it was good to install a curve in the cover gasket! I decided it was a good idea to go for a spin with the radiator cap unlocked!! Just an FYI neither are a good idea!!
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!) |
07-12-2014, 07:30 PM | #889 |
Washed it and had a new seat cover installed.
07-12-2014, 07:59 PM | #890 |
You remember when drinking too many beers was a bad idea? Me neither. |
07-12-2014, 08:46 PM | #891 |
I was able to cut out my new floor for the trans/Transfer case hump (That old looking piece it the original floor I laid over the cut-out in order to drill the holes)
And also was working on the frame. Hoping to finish cleaning it tomorrow then get it primed and painted and then maybe, just maybe I can drop in the powertrain and get this show on the road! (I sometimes feel like I take two steps forward and three back!)
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
07-13-2014, 02:07 AM | #892 |
I replaced the valve cover gasket that was leaking really bad. So bad that I started calling her Smokie.....
"Now all I need is a shop to go with my shop vac!" |
07-13-2014, 03:03 AM | #893 |
With the help of some of the guys on here giving some great advice. i was finally able to get my truck running and start the braking in process of my new brake set up. was a productive day ending with a much needed bath for my 72.
1972 Chevrolet swb fleet side. - SOLD 2018 Toyota Tacoma but hunting for another C10 Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303 Instagram: https://www.instagram.com/72c10shortbox/?hl=en |
07-13-2014, 09:41 AM | #894 |
2WD Jimmy
[QUOTE]Washed it and had a new seat cover installed.
THAT is a beutiful truck! |
07-13-2014, 10:22 AM | #895 |
We put about 100mi. on the '71 GMC yesterday. My wife & I drove up to Daytona and bought a used 20' cargo trailer that's going to be a toy hauler/camper. We'll pick it up Monday. Then she wanted to go to Jo-Ann Fabrics across from the speedway. I went in Big Lots next door & bought some brake cleaner & stuff to munch on. I messed around as long as I could. Went back out to the truck and it was too hot to sit in it so I fired it up & turned the A/C on high. Sat there with it goin' BLOP-BLOP-BLOP for nearly an hour and the temperature gauge never got to half way.. nice n' cold inside too. Alum. radiator, shroud and 6 blade clutch fan work GOOD. Funny, while I sat there women kept parking and going into the fabric store... at different times 4 of 'em walked over and struck up a conversation about the old truck.... all of 'em between 40 & 80. The truck's an OLD CHICK MAGNET. I'm old & fat, if I was young & lean again .. it'd probably still be an OLD chick magnet.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
07-13-2014, 11:07 AM | #896 |
I opened up the garage door and turned all the fans on because it was still stank in there from priming and painting the frame over the last couple days (KBS Coatings rust seal & black top for the curious).
(Ignore the power strip plugged into the power strip plugged into the power strip, it was purely temporary while we moved things around...) |
07-13-2014, 02:19 PM | #897 |
Great looking interior! Great looking seat!
07-13-2014, 02:49 PM | #898 |
Put letters on my blank tailgate.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
07-14-2014, 07:48 AM | #899 |
Finally finished installing 3 inch drop springs in the front and 5inch in the rear with shock relocators and adjustable pan hard bar.
07-15-2014, 11:37 PM | #900 |
Testing out the new hitch for cruise night Saturday.
