03-01-2015, 02:10 AM | #876 |
Post Whore
Re: Restoring Rusty
well if the assembly is the reverse of the disassembly then we bolt up the transmission yoke first - done
03-01-2015, 02:24 AM | #877 |
Post Whore
Re: Restoring Rusty - Joint Problems
but when we go to mount up the rear joint to the differential we see that it is way too narrow for the yoke
what is going on here? we measure the width of the old one 3 5/8ths we measure the width of the new one 3 3/16ths no bueno back to AutoZone... |
03-01-2015, 02:32 AM | #878 |
Post Whore
Re: Restoring Rusty - Back to AutoZone
AutoZone rep is super helpful (easy on the eyes too) confirms I indeed have the right part number/part. She also looks up to see if the 3/4 ton trucks have one to match my used one, as well as the 1 ton, we also try different years 77, etc. to no avail
so off to O'Reilly's, here the rep is awesome he goes Def Con 4 for me and starts bringing out u-joint after u-joint and grabs a micrometer and starts measuring until we find an exact match I ask him so what application is the one like mine for, he says he doesn't know I say I'll take it |
03-01-2015, 02:38 AM | #879 |
Post Whore
Re: Restoring Rusty
I'll be honest with you, after redoing the front joint twice/three times cause of the fallen down needle bearings, and redoing the rear joint twice cause of the wrong size, I did not attempt the middle joint, I am not proud of that, but I will replace it when I play with the rear end / differential and have access to my buddy's press
03-01-2015, 02:50 AM | #880 |
Post Whore
Re: Restoring Rusty
I installed the clutch and brake pedals but didn't take any pictures as there aint much to see there, I also installed the Z-bar and the clutch linkage, again did not take any pics as it is difficult to take pics of that area
once it was all buttoned up, it was time for the Valvoline cocktail, poor Rusty was dehydrated, he downed 4 quarts and could have gone for more, but that's all I had so the IV method with the clear line and the trans fluid bottle did not work well cause the bottle needed a burp hole in order to breathe and even when I cut a hole in it (beer shot gun style) it still wasn't flowing fast enuff the funnel with the clear line was the way to go, it still takes time to run down the tube but you see clearly the progress somewhere along there I tried squeezing a bottle directly into the transmission by laying under the car and I could get about 2/3 of a bottle in that way but not all of it, the funnel method worked the best for me |
03-01-2015, 03:01 AM | #881 |
Post Whore
Re: Restoring Rusty
so here is a summary
started the truck and heard a metal on metal rubbing noise, so heart stops, dollar signs flash before your eyes you tell yourself don't panic, the clutch needs adjusting, so you double check the free pedal clearance... 1 1/2 inches, spot on you say what the heck loosen up the clutch fork all the way, what? still rubbing metal on metal, oh no, but it can't be the clutch wait a minute I bet it's that stupid fly wheel inspection plate cover attached to the bell housing, ever since I bent it back a bit cause it was funky, I second guess my correction because maybe it was bent that way for a reason, so I removed the darn thing, NO MORE NOISE put the clutch fork back into play, and go for a test drive, truck was cold, needed to warm up some, other than that, maybe another pedal adjustment, but other than that, all good left the truck in a new dry stain free spot on the driveway, we will see in the morning if he left a mark, fingers crossed (this was a main seal repair after all, LOL) |
03-01-2015, 05:14 AM | #882 |
Re: Restoring Rusty
Lol man the life of a shade tree mechanic eh!!
03-01-2015, 11:09 AM | #883 |
Re: Restoring Rusty
Well what's the verdict?
03-01-2015, 11:25 AM | #884 |
Re: Restoring Rusty
Greg, those u joints are pesky, eh? The large one on the transmission is a 1350. I think most of the half ton rear ends used a 1310, but yours isn't. I suspect the axle is a 1330. See if the bearing cap diameter is the same or smaller then the transmission ujoint.
By the way, you can fill the transmission up with fluid through the shifter hole when the shifter is out. Might have been easier. Anyway, good work on getting it all back together.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
03-01-2015, 11:28 AM | #885 |
Re: Restoring Rusty
A little tip when doing ujoints put a small amount of grease on the needle bearings. It helps hold them in place for installation.
03-01-2015, 11:47 AM | #886 | |
Re: Restoring Rusty
Glad Rusty is back among the living!!!
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
03-01-2015, 11:59 AM | #887 | |
Post Whore
Re: Restoring Rusty
ARE YOU SERIOUS !!! boy do I feel silly, lessons learned baby, lessons learned |
03-01-2015, 12:00 PM | #888 |
Post Whore
Re: Restoring Rusty
Yes of course, they had grease for sure, otherwise it would have been impossible. But we all know that even with grease sometimes they lay down.
03-01-2015, 12:10 PM | #889 |
Post Whore
Re: Restoring Rusty
Good follow up Chap, well went out there the first thing this morning in my pajamas and slippers.
Dang it there is a stain the size of two quarters under the truck. Right under the transmission drain plug. So I called a tow truck and had it towed to the junk yard! No just kidding just checking if anyone else is actually reading this, sorry fellas. Ok, so I feel the transmission drain plug and there is a drop of trans fluid on it ready to drip, (fyi the truck is on a pretty good incline in the driveway, front up) I wipe it with my finger, and it looks like trans fluid, feels like trans fluid, smells like trans fluid, and tastes like trans fluid. So I am gonna say, lets not send Rusty to the crusher just yet. I bet this is just the run off of the little bit of transmission fluid that I got all over the (newly painted transmission) whilst trying to fill her up. (All the other Greg's fault as he didn't tell me I could fill her up through the shift hole) yes we'll go with that, hee hee |
03-01-2015, 12:22 PM | #890 |
Post Whore
Re: Restoring Rusty - CLUTCH FREE PEDAL TRAVEL ADJUSTMENT
Words according to Manuel 7M:5
Only one adjustment is necessary to compensate for all normal clutch wear. The clutch pedal should have free travel (measured at clutch pedal pad) before the throwout bearing engages the clutch diaphragm spring or levers. Lash is required to prevent clutch slippage which would occur if the bearing was held against the fingers or to prevent the bearing from running continually. [ preach on my brotha ] 1. Disconnect return spring at clutch fork. 2. Rotate clutch lever and shaft assembly until clutch pedal is firmly against rubber bumper on brake pedal bracket. [ do I even have a rubber bumper any more, lol ] 3. Push outer end of clutch fork rearward until throwout bearing lightly contacts pressure plate fingers or levers. 4. Loosen lock nut and adjust rod length so that swivel slips freely into gauge hole. Increase pushrod length until all lash is removed from system. 5. Remove swivel from gauge hole and insert into lower hole on lever. Install two washers and cotter pin. Tighten lock nut being careful not change rod length. 6. Reinstall return spring and check pedal free travel. Pedal travel should be 1 3/8" to 1 5/8" on "C -K " models. [ oh just say 1 1/2" already for crying out loud, hee hee ] Seriously though, you allz follow these steps, cause I sure didn't I do have 1 1/2 inch free pedal play, but I didn't get there this way, a re check is in order. |
03-01-2015, 12:24 PM | #891 |
Re: Restoring Rusty
What a joker! Sorry I seem to have helpful tips for you *after* you needed them.
I think your axle ujoint is a 1330. The 1350 has larger diameter caps. The 1330 and 1310 have the same size caps, but the 1330 is wider. That transmission drain plug is a low point, so anything that leaks from above will work its way down to the drain lug and drip from there. More importantly, is the rear main holding?
03-01-2015, 12:40 PM | #892 |
Re: Restoring Rusty
I've changed a few u-joints over the years, but the last ones I did kicked my butt. I ended up taking the driveshaft to Driveshaft King in Dallas. After laughing at what they called my "cheap parts store u-joints", they replaced them with "made in the USA" models. They also straightened and balanced the shaft. (Pretty cool to watch.) The total cost? $100! Best money I ever spent. As an unexpected benefit, the balance job got rid of a couple interior buzzes, and reduced a floor shifter buzz.
On another note, I think we're due for some progress pics of your truck -- a few shots of the outside, inside, and engine compartment.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
03-01-2015, 12:47 PM | #893 | |
Post Whore
Re: Restoring Rusty
1. Changing / Balancing Tires 2. Windshield / rear window replacement 3. A/C charging/fill up (from empty not just top off) glad Rusty aint got AC 4. _____________________________ reserved for future use 5. Driveshaft universal joint replacement Last edited by Gregski; 03-01-2015 at 12:58 PM. |
03-01-2015, 01:03 PM | #894 | |
Post Whore
Re: Restoring Rusty
who knew there was so much to a joint (fill in your own college reference) Universal Joint Identification |
03-01-2015, 01:59 PM | #895 |
Re: Restoring Rusty
Greg, I'm with you folks who outsource driveshaft work. It's generally not expensive, and I want to be sure it is done right. I've had a number of custom shafts made over the years. There's just no way I could balance them correctly in my garage.
Glad you found the ujoint diagrams, and they confirm my memory.
03-01-2015, 02:39 PM | #896 |
Post Whore
Re: Restoring Rusty
ah the Sunday morning paper, some day I'll own some 6 ton floor jack stands (to replace my 3 tons with)
03-01-2015, 02:47 PM | #897 |
Post Whore
Re: Restoring Rusty
spent the morning lazily cleaning up my tools which were scattered all over the garage floor
I think I at least recovered all my Craftsman wrenches (my daddy taught me to buy Craftsman a quarter century ago, from SEARS he said, man did their quality go down the tubes) the ratched ones in the upper right hand corner are one of the nicest things I ever bought from Harbor Freight, they are Pittsburgh brand (what ever that means, Pittsburgh, China - LOL?) however I hardly get to use them as the ratched end is too bulky to get in to most places I would like, so I call em Gimmick Wrenches and they are there to beautify the drawer, LOL below I got my 6 and 12 point box end wrenches (spanners for you coming from across the pond) two of each except for the 11/16ths odd ball and his 13/16ths cousin (I think I can hide $100 dollar bills beneath these two and no one would ever find them) |
03-01-2015, 02:53 PM | #898 |
Re: Restoring Rusty
You can never have too many jack stands. I bought a bunch of 6 tons at a swap meet cheap, and I also have 2 ton (short) and 12 ton (tall and beefy).
03-01-2015, 02:54 PM | #899 |
Post Whore
Re: Restoring Rusty
So now the question is, how long do we ( I ) hold on to these old parts?
Is it Two Weeks, like with Birthday and Christmas cards? Or is it 18 Years like with your kids refrigerator art? |
03-01-2015, 02:56 PM | #900 |
Post Whore
Re: Restoring Rusty
I love you man, thanks for reminding me a huge local (walking distance) swap meet is coming up next month.
