Old 02-23-2012, 02:21 AM   #901
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
about 4 miles, I got it all back together, test drove it no leaks, so it will be taking me to work
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-23-2012, 11:38 AM   #902
truckzilla
truckzilla's Avatar
Re: my 80 build
4 MILES! Thats not far enough to even get the engine up to operating temperature. You could walk to work!
But where would the fun be in that? Smoke 'um son!
truckzilla is offline   Reply With Quote
Old 02-26-2012, 01:55 AM   #903
flamingbig10
6.0 powered square
Re: my 80 build
I let it warm up for a little bit, wile I get ready for work at it gets to operation temp by the time I get there, today I aligned the front end and checked the truck over, I got cleaned up filled the truck up with gas and went to a car show but got there to late after the show was over went to a car cruise then I noticed the fuel tank leaking again so when I got home I pulled the rear bumper, and wheels off and slide back the bed doesn't look like the hoses so I'm going to pull the tank again and see whats going on,
Aaron
Old 02-27-2012, 01:20 AM   #904
flamingbig10
6.0 powered square
Re: my 80 build
got the tank pulled and found it was leaking behind the straps but I was able to get it warranty, but got the back of the truck back together and put the front bumper on
Aaron
Old 03-01-2012, 01:26 AM   #905
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 03-08-2012, 01:57 AM   #906
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 03-08-2012, 06:59 AM   #907
bbbc10
Diggin The SquareLife
Re: my 80 build
it was good meeting u tuesday!!!! truck is kickass!
bbbc10 is offline   Reply With Quote
Old 03-08-2012, 04:59 PM   #908
truckzilla
truckzilla's Avatar
Talking Re: my 80 build
I wondered when you two would finally connect since you're not far from each other.
Old 03-10-2012, 06:00 AM   #909
bbbc10
Re: my 80 build
Lol yea should come out,too man lol
Old 03-12-2012, 10:13 AM   #910
truckzilla
truckzilla's Avatar
Re: my 80 build
Yeah, I'd like to see what you've got going on with your truck.
Old 03-12-2012, 07:05 PM   #911
bbbc10
Re: my 80 build
Ur more than welcome too..
Old 03-17-2012, 12:48 AM   #912
flamingbig10
6.0 powered square
Re: my 80 build
that sounds great, I haven't done much to the truck lately except drive it, I did add the old subs and amp back in, bolted up the flywheel inspection cover had to trim a bunch of material off but it fits, In a couple of weeks I going to get the exhaust fix and get a tune
Aaron
Old 03-17-2012, 07:47 AM   #913
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: my 80 build
Very nice work, looks great! I really like how your firewall turned out, super-clean!
How did you go about making your contact wirre for the horn in your steering wheel?
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 03-17-2012, 08:27 AM   #914
flamingbig10
6.0 powered square
Re: my 80 build
thanks Gordon on the horn contact I ordered one from summit, that was made for the billet specialties steering wheel
http://www.summitracing.com/parts/BSP-RP2510/
Aaron
Old 03-17-2012, 08:49 AM   #915
flamingbig10
6.0 powered square
Re: my 80 build
I'm having a little traction issue at wot up to 40 mph so these should help a little
http://www.summitracing.com/parts/MTT-3754R/?rtype=10
Aaron
Old 03-19-2012, 11:50 PM   #916
gringoloco
A guy with a truck
gringoloco's Avatar
Re: my 80 build
Truck looks good! How do you like the chevelle headers? Does the lh8 oil pan hang down below the crossmember at all? Great work
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-30-2012, 07:29 AM   #917
bbbc10
Re: my 80 build
2 nice trucks.....here the pics
Old 03-30-2012, 07:31 AM   #918
bbbc10
Re: my 80 build
Old 03-30-2012, 09:58 AM   #919
truckzilla
truckzilla's Avatar
Thumbs up Re: my 80 build
Thats what you are supposed to do with it Aaron, drive it and enjoy the fruit of your labor!
But have you had to worry about rain yet?
Old 04-01-2012, 01:25 AM   #920
flamingbig10
6.0 powered square
Re: my 80 build
thanks the headers are good so far but time will tell how the coating does, on the pan the dip down for the drain plug is the only thing that hangs below the cross member
Great work
thanks I been driving every nice day when the weather is bad I drive my grandpa's truck
Aaron
Old 04-01-2012, 01:27 AM   #921
flamingbig10
6.0 powered square
Re: my 80 build
I'm going to be getting a 3600 stall convertor and tune pretty soon then a set of rear tires
Aaron
Old 04-01-2012, 11:00 PM   #922
flamingbig10
6.0 powered square
Re: my 80 build
a short idle vid
Aaron
Old 04-18-2012, 10:37 PM   #923
flamingbig10
6.0 powered square
Re: my 80 build
I finally ordered a stall converter a yank 3600 pro truck, I was also be getting a transgo hd2 shift kit, autometer trans temp gauge, and amsoil transmission fluid
Aaron
Old 04-23-2012, 04:37 PM   #924
Ford Assassin
Ford Assassin's Avatar
Question Re: my 80 build
I was wondering the samething.
Does the H3 pan hang below the main crossmember?
I am in the process of converting my K5 to 2wd, but am running the stock truck pan. I am going to swap to the H3 pan (GM calls the 'Muscle Car' pan kit') and hope it good enough since mine will prob bagged all the way around.
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 04-29-2012, 09:35 AM   #925
flamingbig10
6.0 powered square
Re: my 80 build
the pan does hang about a 1/2" or so below the cross member, I did take the truck to the track last night first pass ever 13.74 at 98 in the 1/4, 2nd pass 13.8 at 99, 3rd pass hooked good 13.6 at 98, 4th 16.8 at 88 left sideways with a hole lot of tire spin and coasted down the track, can't wait to get the 3600 stall, shift kit, drag radials and a real tune, should help it run low 13s high 12s
Aaron
