01-05-2016, 01:02 PM | #901 |
Re: 55 2nd serie GMC
Now its the upper cowling replacement, not that easy to do but got it done.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
01-05-2016, 01:23 PM | #902 |
coming along nicely....
My Build: 57 Chevy Pro-Street |
01-05-2016, 02:57 PM | #903 |
What PTC says ^^
Lots of work to be done, again...
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
01-05-2016, 04:00 PM | #904 |
A320 Pilot/USAF Retired
Great work!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-05-2016, 09:16 PM | #905 |
Looking good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
01-05-2016, 09:24 PM | #906 |
Looks real good.
Kim |
01-09-2016, 08:55 AM | #907 |
Got my flatout front C4 conversion kit a couple days ago.
01-09-2016, 09:29 AM | #908 |
you graffed it in nicley
01-09-2016, 11:50 AM | #909 |
Nice looking parts.
Kim |
01-13-2016, 05:46 PM | #910 |
Starting to look like a truck again
01-13-2016, 07:51 PM | #911 |
Yes it does, starting to take shape now...Jim
01-14-2016, 02:12 PM | #912 |
Yep, starts looking good again!!
01-24-2016, 11:02 PM | #913 |
Looking good buddy! My hats off to you, I really respect your determination.
02-16-2016, 03:27 PM | #914 |
Ok back working on the truck again, was away on vacation and then finished a couple of other things. Left the bodywork aside for now, started work on the frame. First clean the frame of all the brackets i don't need. Remove front crossmember to work on installing that C4 front conversion kit. Installed the tranny crossmember and brace the front of the frame to keep things from moving around and boxed the front frame rails. The C4 crossmember is just tacked in for now just to see if everything is lining up right. I'm going to set up a front fender to see how the wheel will look in the fender opening before i do the final welding.
02-16-2016, 04:35 PM | #915 |
Nice!
Build Thread: 1958 GMC Memorial Build |
02-17-2016, 09:22 AM | #916 |
Real nice.
Kim |
02-17-2016, 09:23 AM | #917 |
Going to be a sweet ride!
02-18-2016, 12:17 AM | #918 |
Mucked up the left front fender to see how the wheel look in the opening. Well looks good to me. Next I put a little notch in the frame to clear the coilover springs
02-18-2016, 09:26 AM | #919 |
Looks real good in there.
Kim |
02-19-2016, 09:56 AM | #920 |
Wheel looks perfectly centered!
Nice chassis work!
02-21-2016, 11:58 AM | #921 |
Engine mounts are tack in, will finished welding them tomorrow.
02-21-2016, 12:24 PM | #922 |
Glad to see this getting put back together, looks great. I am sure it will look even better than the first time.
02-21-2016, 06:53 PM | #923 |
Making good progress on the rebuild.
Kim |
02-21-2016, 08:17 PM | #924 |
Good looking engine mounts! Were the curved pieces sectioned from a pipe?
02-22-2016, 12:42 AM | #925 |
Thanks, no I made then from a piece of flat 1/4" plate then bend it on the press turned out pretty good.
