12-08-2010, 10:56 AM | #901 |
Re: 67 cheby's Dropmember build thread
I had the bed all painted and my budy decided to change the lines on the top of the tailgate and the front panel. Bed should be painted in the week and then body work will start on the cab. I will get pics in my thread here in the next week or two.
12-08-2010, 11:01 AM | #902 |
Looks good, Mike. Can't wait to see the fenders all smooth either! Oh, and I know all about getting pushed aside for insurance work. But it's definitely understood that insurance work is their bread and butter!! Looking forward to more progress.
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
12-08-2010, 12:18 PM | #903 |
67cheby
well, a little bored at work this morning so i took my new 140 amp alt apart , so i can try my hand at smoothing one out
12-08-2010, 09:40 PM | #904 |
nice work 67cheby
12-08-2010, 10:00 PM | #905 |
Looks good so far. Even the greats had to start at the beginning. And yeh, grinders, cutting wheels, hammers and body filler can work miracles. Wish I could bring parts to work.
12-08-2010, 10:17 PM | #906 |
just went through the hole build nice job on customizing the seats and the score on the 67 air cleaner
12-08-2010, 10:29 PM | #907 |
low n' slo
hey, just a heads up, be careful when you paint it. i tried painting my aluminum intake and paint would not stick to it. finally i bought some etching mag cleaner, cleaned it about 5 times with it, then the paint stuck very good. i totally forgot about this when i tried painting my alternator...the paint just flaked right off. i got pissed and put it together anyways, but i plan on taking it apart and cleaning it just like i did the intake and re shooting it.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-09-2010, 12:07 AM | #908 |
Still Learning
This is an Awesome project! I wish I had found it earlier in the build. You sure have came a long way from where you started. Gonna be so slick!
12-09-2010, 01:40 AM | #909 |
theres a special etching primer for aluminium its a clearish mustard yelow (in the days i used it ) and you only aply a mist of it on the aluminium before painting , it does help to have the cast aluminium clean enough to eat off as its verry porious (lots of microscopic holes and cravises that hold dirt)
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
12-09-2010, 10:50 AM | #910 |
67cheby
thanks guys for all of the compliments, and tips on the aluminum all input is appreciated
12-09-2010, 10:55 AM | #911 |
67cheby
well here is last nights progress , when i got to the shop my builder said " i want you to work on those front frame horns" i said Mark i am just going to leave those spots alone... Mark says " you can either do it tonight or i will do it tomorrow , either way its getting done !! " so here is what i did, and now i am glad i did it
12-09-2010, 10:57 AM | #912 |
looks factory! good call
my build threads, 68 pro touring, auto cross c10 (mid life crisis) http://67-72chevytrucks.com/vboard/s...d.php?t=464109 website http://www.sauersgarage.com/ |
12-09-2010, 11:03 AM | #913 |
67cheby
thanks, i was pretty pumped after i got it done, or well not done yet still got to weld it up , but i think it will look pretty slick !!
12-09-2010, 11:27 AM | #914 |
VA72C10
It's the little details that make the difference!!!
Looking for a 67-72 swb or blazer project in or around VA. |
12-09-2010, 11:55 AM | #915 |
looks great
12-09-2010, 11:58 AM | #916 | |
For the lip, I simply made some relief cuts, straightened the steel (cresent wrench + a hammer/dolly), welded things back up, & then trimmed the rail slightly to have a better transition fore/aft of the area. I did remove the pads for the idler arm as they interfered w/my reinforcment plates I made for the R&P c-notches.
12-09-2010, 12:12 PM | #917 |
67cheby
i thought about trying that but i didnt know if it would turn out right , i should have asked on here first !!
12-09-2010, 09:47 PM | #918 |
Still Learning
I like the mod on the front of the frame too. It's going to look like it came that way when you get it welded and smoothed out. Nice!
12-09-2010, 11:44 PM | #919 |
Nice detail work.
12-10-2010, 10:29 AM | #920 |
67cheby
Thanks guys
12-10-2010, 10:45 AM | #921 |
PROJECT 7DEUCE
I agree im glad you did the front frame horns also they look killer..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-10-2010, 10:47 AM | #922 |
67cheby
Thanks frenchblue
12-10-2010, 08:42 PM | #923 |
Project is looking awesome! I agree with you as far as saving money and doing as much stuff as you can yourself. That's the whole fun behind these vehicles isn't it!? I have some questions though...Did you ever take off your cab from the frame? If not why not? and those front frame horns...What was there before? It's a good thing you filled in those holes, it looks a lot better! How are those Bear Claw latches treating you? I'm having some difficuilty with my stock latches now...Thinkin' about some new ones.
12-11-2010, 12:03 AM | #924 |
Tot Roddin'
Lookin' good!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-11-2010, 10:46 AM | #925 | |
67cheby
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
