07-30-2013, 03:06 PM | #901 | |
Re: Markeb01 Build Thread
Going to be in town tonight at midnight !!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
07-30-2013, 08:38 PM | #902 |
But Found Her 25yrs Later!
I've been tempted to get the same mat as you, but cut it the same as the original - where it only covers the front portion of the cab, not under the seat. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-30-2013, 10:46 PM | #903 | |
Senior Enthusiast
I can truthfully say if it ever has to be replaced I'll never install another one. I'll either go with carpet, or leave the portion under the seats and install another stock replacement mat instead. I don't care for carpet in the truck because it retains too much dirt. I preferred the convenience of the original rubber mat so I could remove the floor pan for transmission work, but the MIP is so good looking I'm hopeful it will outlast me so I'll never have to make the choice.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
07-31-2013, 10:20 PM | #904 |
Senior Enthusiast
Darned if that chrome plate didn’t pop out on one corner of the new Mr. Gasket boot, so I pulled the boot back out and after scrubbing the upper interior of the plate cavity with alcohol, it was covered with a liberal coating of 3M clear silicone adhesive and the plate reinserted. It takes 24 hours for full cure, so it won’t be going back in until tomorrow.
Before pulling the boot I realized it tends to lean to the passenger side as there is no support on the right side of the stick. So I elected to slice up the old adapter into a support piece that would match the top of the main adapter. Using a 4” angle grinder with a metal cutting abrasive blade, it took about 20 minutes to turn it into the piece shown here on the passenger side of the stick: The angles look a little off due to optics as the new piece hadn’t been painted yet, but it matches the profile of the left piece and contacts the top center of the boot evenly. The only portion that touches the boot is the narrow edge directly above the bolts. The grommet on top is used to lift the boot up enough to cover the portion of the stick that was heated for bending, which stained the chrome. I truly am running out of ideas to make any other refinements. Rather than squandering more money on the truck itself, my next investment may be a GoPro camera so I can better capture the sound effects and hopefully produce more interesting/artistic video posts.
07-31-2013, 11:24 PM | #905 |
The Gopro camera is a good choice. I recently read the whole thread and like your work and truck. I recommend a Steptoe/Kamiak Butte Fall drive. Maybe a Coug football game.
The Palouse still strikes a chord for me. I used to tour it in my 65 C 10. |
08-01-2013, 01:32 AM | #906 |
Senior Enthusiast
Sounds good to me. Since we're both retired now, doing substantially more cruising is much higher on the list than in the last few years.
08-03-2013, 01:11 AM | #907 |
Senior Enthusiast
Collecting custom shift knobs has been a lifelong hobby that started for me at about age 13. The first knob I ever bought on my own was a chrome Cal Custom ball that I promptly installed on the family 52 Oldsmobile. My dad removed it just as quickly when it was discovered the added weight caused the transmission to unexpectedly drop into the next lower gear!
Before I handed most of the collection over to my oldest son, I had an assortment of knobs and T-Handles that covered just about everything Cal Custom, Hurst, Peterbilt, and a few other brands ever made. One that always evaded me was a high quality blue metalflake knob. I finally picked one up at a car show a couple years ago and have been very happy with it. It’s not easy to photograph being so highly reflective. In real life it there are no black specks, just transparent blue with silver flakes embedded. Eventually it became evident a shift pattern needed to be added, but I couldn’t find anybody local capable of doing the work. And one disappointment common to all transparent shift knobs, is the magnified view of the hole bored in the knob for the threaded adapter fittings. In the correct light this “feature” can look huge. It turns out knobs ordered directly from Epco can have a smaller hole drilled for the insert at no extra charge, simply by asking for it (which I did).. Here’s the bottom of my current knob, showing the “master” insert which is 16mm wide, with a 3/18-16 insert threaded into it: And these next images show how big the bore hole looks from outside. The lighting is highly exaggerated as I’m shining a high powered flashlight directly at or behind the ball: The new knob will only have the smaller 3/8-16 insert, so it should look much smaller when looking into the interior of the knob. And I received good news this morning - I placed the order for the new shift knob last Monday 7/29. Normal lead time is two weeks, but the knob is shipping today - Friday of the same week! Just in time for the upcoming car shows we will be attending.
08-03-2013, 01:23 AM | #908 |
Great to know you'll be at the show.
95% sure I'll be there too. Have to meet up and say hi. Posted via Mobile Device |
08-03-2013, 01:40 AM | #909 |
Senior Enthusiast
Sounds like a plan, look forward to meeting you! If you come in the front gate we're usually off to the upper left area where most of the trees are.
08-06-2013, 08:03 PM | #910 |
Senior Enthusiast
For the few members that haven’t yet been bored to tears with gearshift knob info, the new EPCO metalflake 4 speed knob showed up today. It’s really beautiful, perfectly round, and exactly as requested. The pattern is perfect and the insert is the smaller 3/8-16 size. Old knob on the left, new knob on the right (I parked both knobs on a couple of bottle caps to hold them steady):
The core hole on the new knob is nearly invisible inside the knob both because of the smaller diameter, and also because this ball came out a bit darker than the other one: As EPCO advertises no two are exactly alike. I like both equally. The old ball was more electric blue while the new version is more like a dark Navy blue. In direct bright light they both look nearly the same color: But in normal ambient they look more like this: EPCO provides the biggest jamb nut I’ve ever seen for a shift knob. I’m sure it was meant to protect the knob where it contacts the nut, but wow! That would be uncomfortable. So instead, I used the Hurst nut mounted upside down, after I rounded off the sharp corner indicated by the arrow. I threaded a stud unto the nut and chucked it in a power drill which was run against a D/A sander. The corner is now nice and smooth. The nut portion is so thin it can’t be detected against the ball when shifting gears, and the smoothed corner of the nut/sleeve just feels like part of the shifter stick. That’s it for today. Two car shows over the new two weekends, so just running the check list to make sure everything is cleaned, filled, or loaded up. I just found out there’s also a car show down in Rockford, WA this Saturday. If for any reason the Mirabeau show doesn’t work out we may head down there.
08-07-2013, 11:28 AM | #911 |
Hey Mark, really like the look of the Epco knob, and your detailed explanations are what keeps me checking out your thread, AWESOME!
Here's the knob I rock in my DD... Here's the Epco knob I plan to order for my '65, Personalized with my Holy Fire Customz logo... Just thought I'd share this with you and the followers of your build! Thanks again for the Epco tip...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
08-07-2013, 11:31 AM | #912 |
The 60-66 GMC/Pontiac guy....
I had a metal skull gear shift knob back in the 70's.. can't recall what ever happened to it... :-/
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
08-07-2013, 05:05 PM | #913 | ||
Senior Enthusiast
Thanks for your ongoing visits and comments!
08-07-2013, 05:12 PM | #914 |
Somebody say skull not the greatest pictures but you get the idea..Vernski
08-15-2013, 01:32 AM | #915 |
Senior Enthusiast
Tomorrow is the first day of early registration for the Goodguys show this weekend. I’m already preregistered, so we’ll head over in the morning and pick up our packet & windshield sticker.
I washed the truck this evening for the first time since the car show in early July. It reminds me why I love Blitz Black paint. The truck has been covered in bug guts and cooking in above 90 degree temperatures for almost 2 months and the stuff just washed right off. I’ve also been missing the Moon Equipped decals on the front fenders almost since I took them off. I had another set that were marred, but some light attention with a can of wax made them look perfect so they went back on this evening. It never really showed, but the front fenders had some light residue left behind from the previous decals making it super easy to locate and align the new ones exactly as before. I’m hoping to have some decent open exhaust video to post by next Monday.
08-16-2013, 12:23 PM | #916 |
have a great time at the show
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
08-16-2013, 02:40 PM | #917 |
Enjoy the show, looking forward to the Pics that are sure to follow!!!
08-16-2013, 09:18 PM | #918 |
Senior Enthusiast
Thanks guys! We did indeed have a great time this morning, and we’ll be going back for most of tomorrow. We arrived around 8:15 and hung for over 5 hours which is a long stretch for me.
I was surprised by the large turnout for a Friday. There was around 70% of the regular volume of cars in attendance for a normal Saturday event. I imagine it will be cram packed tomorrow: On a quick trip through the “Good Gals” area on the way to get more Moon decals, I spotted a moose table. My squeeze collects such things, and with her birthday coming up in a week, I grabbed it up before it walked away. It stood guard in the passenger seat the rest of the event: And here’s my cowgirl sweet heart having a good time as always: There were only two other 60-66’s in attendance. The super long panel truck made another appearance, with a substantially lower price: And this beauty from Montana with a fully louvered hood: It has a nicely detailed big block and overdrive trans: And unknown (to me) five spoke wheels: Here’s a close up of the hood: On the way home several miles from the fairgrounds we spotted a flat black 1961 short stepside, so perhaps he’ll be at the event tomorrow and I’ll be able to add some more photos. And for those interested in video, here’s a parade lap around the fairgrounds. The cutouts sound way better in real life than they do on my cheap Chinese dash cam. Next year I will definitely have a GoPro instead. Too much of the “mechanical music” is being wasted by the present equipment. The cam sounds far more radical than it is and there’s no doubt the exhaust note commands attention from onlookers. It is a real head turner with the pipes open. http://www.youtube.com/watch?v=Zuou_...ature=youtu.be More to follow.
08-16-2013, 09:45 PM | #919 |
Rollin' Old Skool
Good to see you guys out having fun together. Nice pics of the 60-66 stuff, & hopefully more to come tomorrow. The moose table looks pretty neat riding shotgun, haha.
And that engine is screaming, "Get out of the way people, I'm coming through!"
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
08-17-2013, 12:32 PM | #920 |
Thanx for the Parade Lap
Even with the chinese cam, the Cam and the Gear Drive sound Mean!!! Have a Great Weekend Mark!
08-18-2013, 03:46 PM | #921 |
Senior Enthusiast
Saturday was a great day. We got to hang out with McMurphy & wife, Bomp & wife, and Captainfab. I also got to meet several other forum members and regular visitors to the site. A few more 60-66 Chevy trucks also showed up:
This is the supercharged long bed with the glass bed cover that first appeared a year or two ago: Here’s another attempt to capture the beauty of the paint, which doesn’t come close to the appearance in real life: I believe this was originally purchased by the grandfather of the current owner: Here’s one sporting 54 Chevy BelAir wheel covers setting on the ground: And some details of the rear suspension:
08-18-2013, 03:47 PM | #922 |
Senior Enthusiast
And a few more. Here’s an in-progress chopped top with a healthy sounded engine:
A very clean 64-66 with lots of shiny stuff:
08-18-2013, 03:52 PM | #923 |
Jealous to say the least...
Glad you Guyz and Galz had a great time!!!
08-18-2013, 03:52 PM | #924 |
1 thing at a time is progress.
Very cool y'all got together! Thanks for the pics
Alan
Philippians 2:14-16 |
08-18-2013, 10:10 PM | #925 | |
Posted via Mobile Device Posted via Mobile Device
My frame Layin 63 short bed project http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
