Old 05-04-2012, 08:25 AM   #926
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-04-2012, 01:43 PM   #927
Ford Assassin
Ford Assassin's Avatar
Re: my 80 build
Did you end up slamming it again?
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 05-04-2012, 06:51 PM   #928
truckzilla
truckzilla's Avatar
Re: my 80 build
Lookin' good Aaron!
truckzilla is offline   Reply With Quote
Old 05-05-2012, 03:22 AM   #929
flamingbig10
6.0 powered square
Re: my 80 build
I kept the truck about the same height as before, thanks Larry. I got the trans pulled took me a good part of 45 minutes from pulling the truck in the shop to trans sitting on a table,but the shift kit is taking much longer though but just have a few parts left
Aaron
Old 05-05-2012, 08:50 AM   #930
Ford Assassin
Talking Re: my 80 build
Changed your mind?
I read earlier in the thread you planned on going back to stock height, then alittle lower than stock.
Personally I think it has a 'Pro Street' look which suits the squares perfect.
Cable
Old 05-18-2012, 10:15 PM   #931
flamingbig10
6.0 powered square
Re: my 80 build
I decided it wouldn't look any good higher than a 4-6 with the wheel and tire combo I have so kept it lowered, I got the trans back together a couple weeks ago I really haven't tested the stall yet but its really street able even with the 3600 stall, but I need to get the truck tuned soon and get some drag radials to see it get in the 12s
Aaron
Old 05-25-2012, 12:48 AM   #932
flamingbig10
6.0 powered square
Re: my 80 build
I ordered some M/T e/t streets should be here in couple weeks hope they hook good
Aaron
Old 05-25-2012, 12:51 AM   #933
Ford Assassin
Re: my 80 build
I have Hoosier DR's on my Z car and it dead hooks off the line after a mild burnout in the waterbox. Plus they last a decent life, I've owned mine since 2008.
Cable
Old 05-25-2012, 09:50 AM   #934
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
hey ford Assassin. do you got a pic of your z? sounds cool from your sig. dont want to mess the tread up tho.. i hope you dont mind
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-25-2012, 10:08 AM   #935
Ford Assassin
Re: my 80 build
Next time prob best to PM me, http://www.cardomain.com/ride/685533/1975-datsun-280z
Cable
Old 06-08-2012, 12:59 AM   #936
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 06-08-2012, 01:11 AM   #937
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
damn they dont leave you much tread till your at the wear bars.. but cant wait to see some real time slips up and maybe a video of some runs
-00 Saturn 5spd
1/4:13:90
Old 06-08-2012, 01:22 AM   #938
flamingbig10
6.0 powered square
Re: my 80 build
Just enough to be street legal, but they are very sticky no more 20mph burnouts
Aaron
Old 06-08-2012, 09:47 AM   #939
mooseknuckles
mooseknuckles's Avatar
Re: my 80 build
you should notice a big improvement in your 60' times now!...even my mickey s/r are pretty soft, my truck don't spin too much....plus the four link helps it "squat" and "hook up".
mooseknuckles is offline   Reply With Quote
Old 06-23-2012, 10:35 AM   #940
flamingbig10
6.0 powered square
Re: my 80 build
finally got a real tune on my truck, I was trying get hold of the tuner for months, he finally had a little free time called me Wednesday, went to his shop after work, he started tuning it and found the black bear tuned pcm is block, luckily I have two pcms, he started tuning it found my carless self hooked up the two speed sensors back words so it though it was going 15mph at idle why I had first girl for 5 feet, got that switched, he adjusted all the perimeters, went and drove it, it was real strong till it hit about 5500 the stock 22ib injectors work as hard as they could, so he said I'll need 44ib to get to run up to 6500, so he said he new were a lightly used set was, that was on my buddies supercharged silverado, so he called several guys and finally found them, so yesterday he was cross the street from my work at the drive shaft shop so he saw my truck and he come back to drive shaft shop so he brought the bigger injectors, and tuned it so it would run the bigger injectors, so after work I put the bigger injectors in, during the day he called me saying if I get those injectors bring it by my work I'll retune it, and take it to the track so I went home and got my drag radials went a head and put them on before I left, so I headed over to his shop and he retuned and we headed to track, got there about 10, let the truck cool down for a little, I didn't even air down the drag radials they were probaly at 30 psi, first pass I did a good little burnout, did a high idle launch ran a 13.06, I did 4 other pass never could get in the 12s, the convertor is only stalling to 2,000 then it moves, I dont if i should blame the willwoods or the yank convertor, but the trucks going to be dyno tuned soon, so it should be quicker than a 12.99 for sure
Aaron
Old 06-23-2012, 12:14 PM   #941
Ford Assassin
Re: my 80 build
A 13 sec quarter mile time for a street/daily driver square is hauling the mail no matter what, especially since our trucks are about as aerodynamic as a flying brick.
If you want to find out where the converter is stalling/flashing, go see your tuner buddy again and take a drive. While cruising about 25 mph, have him 'hold' the trans in 3rd gear with the tuning software then stomp the gas for a second. Whatever your RPM was when you stomped it is your stall RPM.
I am sure you mentioned it somewhere in the past 38 pages, but what rear gears are you running? Have you weighed the truck since completing the swap?
Gear ratios are often overlooked when it comes to converter stall. Weight is also a factor. The heavier the car/truck, the higher the converter will stall vs the same converter in a lighter car/truck. Same goes with gearing, the lower the gear (higher number) the lower the converter will stall due to load.
A good example is a buddy with a '70's Camaro, has a warmed over 383. Bought a 3,000 stall converter and it would flash to 3,500 with 3.55 gears. Later he swapped to 4.56's and now the converter barely flashes to 2500-2700.
Cable
Old 06-24-2012, 04:59 PM   #942
mooseknuckles
Re: my 80 build
Aaron...are you talkin bout the sensors on the tranny?......I'm having similar trouble....my truck will go about the lengh of itself in first gear before it shifts, and no matter what I can"t manually shift it...
Old 06-24-2012, 09:44 PM   #943
JohnC
JohnC's Avatar
Re: my 80 build
Haven't been on in a while. Truck looks awesome man. Great work!
JohnC is offline   Reply With Quote
Old 06-25-2012, 12:02 AM   #944
Can't kech me
Can't kech me's Avatar
Re: my 80 build
The more i read about this truck, the more awesome it gets! if i ever go to a strip in dallas i'll have to give you a call. 13.06 is haulin! maybe higher front tire prssure, and lower rear tire pressure would get u into 12s. but the dyno tune will for sure!
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 06-25-2012, 12:20 AM   #945
flamingbig10
6.0 powered square
Re: my 80 build
Thanks guys, it has 373s, John yes the two speed sensors on the trans swap them and see what you got because that sounds exactly like what mine did, the tire pressure was probably at 30 psi on all four I haven't check them in a couple weeks, I may order a adjustable proportional valve, I might be able to stall the truck up more and with the dyno tune It could run as quick as 12.8, then a 150 shot
Aaron
Old 06-25-2012, 01:09 AM   #946
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
dude that is great news! halling ass. 13.0 is pretty damn quick. i need to get mine down there. only at 13.9 so far.. we need pics and video of the runs ! please (:
-00 Saturn 5spd
1/4:13:90
Old 06-27-2012, 08:29 AM   #947
flamingbig10
6.0 powered square
Re: my 80 build
thanks man, next track time ill get a video of it
Aaron
Old 06-27-2012, 10:41 AM   #948
Ford Assassin
Re: my 80 build
What was your MPH and 60ft for your 13.06 run?
Cable
Old 06-27-2012, 11:22 AM   #949
flamingbig10
6.0 powered square
Re: my 80 build
left lane on a 1200rpm launch
Aaron
Old 06-27-2012, 11:24 AM   #950
Ford Assassin
Re: my 80 build
Cool. Are you dead hooking on the launch?
Cable
