#926 |
Re: 85 burb meets 6.0 lq4
And if anyone wants free dog i will deliver if you live close. He just showed up. Very nice. He did not like what happend in previous post.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle Last edited by 85burb; 01-08-2012 at 12:27 AM. |
#927 |
Well i finaly broke down and replaced the passenger door hindge pins and bushings. I was tired of wife slaming door so hard she moved the mirror. I now remember why i have been putting it off for so long. Had to cut the old pins in half so i could take them out. Door shuts like new and body lines once again line up rite.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#928 |
I don't suppose you have pictures of the process... this is a much needed item for my truck. And when you say pins, you mean the actual pins going through the hinges, you had to cut them in half? Due to rust?
#929 |
Still plays with trucks
That job sucks but at least on a square body the hinges all bolt on and can easily be replaced. The next body style they welded them to the body tub. Mine wore through the bronze into the steel and were a real pain to replace.
After that burnout I bet your neighbors loce you too ![]() Posted via Mobile Device
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#930 | |
#931 | |
It is really not that hard to do if you can suspend your door from something. I took the 6 mount bolts out of the door, pulled door out as far as i could with out dissconecting the wires, removed pin, removed what was left of the old bushings, taped new bushings in and greased everything and installed new pins. Then bolted door back up and that is pretty much it. Got pins and bushings from autozone. PN 38400 i think. I was so happy the body lines were rite again and door shut with ease. Now i just have to do driver side. I will take pics of that side when i do it.
#932 |
That'd be awesome man... I'm really new to a lot of this stuff and (like everything else) don't feel comfortable doing something until I know [I]exacyly[I] how to do it... lame I know but I'm working on getting over my fears HAHA. Plus I can't start the build for another few months, in the process of moving. I'm rambling. Thanks, look forward to the pics.
KP |
#933 | |
#934 |
My wife gives me **** for that all the time too!
#935 |
TruckincrazY
I'm glad it's not just me. Have y'all gotten "is this the last thing" question from you're wife yet?
My build thread - '84 2wd w/ a 6.0 swap http://67-72chevytrucks.com/vboard/s...d.php?t=433595 |
#936 |
She knows better LOL
#937 |
Mine knows better as well. She is/was a gear head her self and her dad was so she knows.
#938 |
So i dougs is finally coming out with headers for my truck. How much hp should i expect to pick up with 1 7/8 try y headers. My consern is loosing low end power. Any quesses.
#939 |
Truck and auto performance nut
I would think anything under a 1 3/4" would be leaving power on the table for your 6.0.
Torque is strong on my 6.0 with 1 7/8" headers but of course it has the L92/LS3 heads. If these DT's are the best fit for your truck...I think they'd be my 1st choice over a 1 3/4" header that I had to mod/work around things for.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#940 | |
#941 |
Second Chance Program
You have a link to the dougs headers?
#942 |
#943 |
Link, http://dougthorleyheaders.com/produc...productID/1079
82 chevy longbed(grey truck)first truck when i was 15! |
#944 | |
They look to be a nice setup. Are they 4x4 friendly? Posted via Mobile Device
#945 |
I see they fit both 2wd & 4x4. Why can't all the headers be that way.
#946 |
I see those are for 67-72 trucks? I wonder how they know which aftermarket engine mounts you will use... I'd probably call their tech support before ordering. Very nice looking units! I was looking for Doug's headers instead of Doug Thorley headers with no luck.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#947 | |
I'd still probably call them to make sure as they my have been designed for a specific engine mount adapter plate and engine placement. I know the S&P headers don't fit well with some of the other brand engine mounts & adapter plates. Being ceramic coated you don't have any easy options to modify them to fit your application if they were designed for a different engine placement.
#948 |
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
all i know is that its going to be orange Last edited by N2TRUX; 01-12-2012 at 12:56 PM. |
#949 |
#950 |
You have my attention......
