Old 03-03-2012, 08:53 AM   #926
motornut
78K & 79C Jimmys
motornut's Avatar
Re: My 86 build
Holy Cahonies! thats gona rock in there
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-03-2012, 11:08 AM   #927
mooseknuckles
mooseknuckles's Avatar
Re: My 86 build
yeah...I hope so man...
mooseknuckles is offline   Reply With Quote
Old 03-03-2012, 06:58 PM   #928
mooseknuckles
Re: My 86 build
got the water pump bolted back on....also I ported and polished the throttle body....of course I scratched the s**t out of it while doin that, so I had to paint it again....
Old 03-04-2012, 01:56 AM   #929
CuRtdOgG
CuRtdOgG's Avatar
Re: My 86 build
shiny....
CuRtdOgG is offline   Reply With Quote
Old 03-04-2012, 07:38 PM   #930
Pop's C-10
Pop's C-10's Avatar
Re: My 86 build
Purdy
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-04-2012, 08:03 PM   #931
bbbc10
Diggin The SquareLife
Re: My 86 build
is this the inline walbro 255?
bbbc10 is offline   Reply With Quote
Old 03-09-2012, 12:48 PM   #932
mooseknuckles
Re: My 86 build
yeah it is....but old vic just put his name on the kit and raped me out of another $100
Old 03-09-2012, 12:53 PM   #933
mooseknuckles
Re: My 86 build
been checkin out radiators lately, my old two core stocker is almost done anyways, and I want to go with electric fans, so this is what I've come up with.....
Old 03-09-2012, 01:29 PM   #934
truckzilla
truckzilla's Avatar
Thumbs up Re: My 86 build
Hey John, its looking hot! What source and part no. did you use for the K&N cold air intake? And the choice of radiators looks like the one I went with, a Griffin model 58272-1 with dual Spal's 31" x 19" and dual right hand side outlets. I picked mine up at Summit Racing for a great price considering some of the others I'd checked into.
truckzilla is offline   Reply With Quote
Old 03-09-2012, 01:34 PM   #935
mooseknuckles
Re: My 86 build
thanks man....yeah its the griffin one...got any pics?..installed?..I'm just wondering about the size before I order it.....I'll try to find you a pn# for the k&n.....
Old 03-09-2012, 01:40 PM   #936
mooseknuckles
Re: My 86 build
truckzilla....I believe it's pn# 77-3031kp
Old 03-09-2012, 01:51 PM   #937
truckzilla
truckzilla's Avatar
Sorry John, mine is still sitting in the box. It will be a while before I get that far along on it. I went with the widest one, the 31" because I didn't see any reason not to as more coolant the better. Here in Texas in the summertime, sitting in traffic can really put a cooling system to the test.
For the mount, I went with one from CFRperformance.com
HZ-41016 CFR UNIVERSAL RADIATOR MOUNTING BRACKET KIT (31" x 19")
Jegs has the same thing for almost twice the price.
Old 03-09-2012, 01:57 PM   #938
mooseknuckles
Re: My 86 build
thanks......there really is only one other option the 27", but I think its not wide enough?.....I'll measure the stocker tomorrow....
Old 03-09-2012, 02:00 PM   #939
truckzilla
truckzilla's Avatar
Re: My 86 build
I think the stocker is more like the 27" wide model. I wonder if that polished cold air tube can be adapted to hold the MAF sensor?
Old 03-09-2012, 02:04 PM   #940
mooseknuckles
Re: My 86 build
theres a rubber coupling that attaches to the end of the tube and MAF before the filter, the filter clamps on to a big aluminun ring that the MAF bolts to.....hope that helps explain it...
Old 03-09-2012, 02:06 PM   #941
truckzilla
truckzilla's Avatar
Re: My 86 build
Thanks, it sure did.
Larry
Old 03-09-2012, 02:11 PM   #942
mooseknuckles
Re: My 86 build
I still need to buy a MAF or I'd have some pics....
Old 03-09-2012, 02:16 PM   #943
truckzilla
truckzilla's Avatar
Re: My 86 build
Another reason, I'm thinking but I can't put my finger on the info right now, on why I went with the 31" wide unit is that I believe it uses larger fans than the 27" wide one does. I could be having a head up my butt moment, but that is what I seem to recall thinking.
Larry
Old 03-09-2012, 02:25 PM   #944
mooseknuckles
Re: My 86 build
Larry
sounds good to me bro...
Old 03-09-2012, 06:12 PM   #945
mooseknuckles
Re: My 86 build
I'm gonna try an get the chevy fired up tomorrow.....
Old 03-10-2012, 01:18 AM   #946
CuRtdOgG
CuRtdOgG's Avatar
Re: My 86 build
i posted that link up i think it should work now...it works for me
Old 03-10-2012, 02:35 AM   #947
my4by2
my4by2's Avatar
Re: My 86 build
Give Ron Davis radiators a call - they built mine & it turned out fantastic!!! Even set-up for the LS water neck locations!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 03-10-2012, 07:40 PM   #948
mooseknuckles
Re: My 86 build
yep...I figured it out.....
Old 03-10-2012, 07:40 PM   #949
mooseknuckles
Re: My 86 build
sweet set up 4by2!
Old 03-10-2012, 07:46 PM   #950
mooseknuckles
Re: My 86 build
got a little work done today.....bought some o2 sensors, drilled and tapped the water pump for the steam line fitting, mocked up the alt/bracket and noticed I'm missing an idler pulley and some bolts.....still have to do something with the power steering pump/reservior....
