Old 03-14-2019, 12:50 AM   #926
joedoh
joedoh's Avatar
Re: "Project Orangepeel" 52 A.D
haha if a job is worth doing, its worth doing twice, thats my motto. that or "measure once, cut till it fits"
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 03-14-2019, 08:03 AM   #927
reaper71
reaper71's Avatar
[FONT="Comic Sans MS"]Thanks...It was a issue looking at how it looked unbalanced (like this from factory) so yes well worth the effort!
reaper71 is offline   Reply With Quote
Old 03-14-2019, 08:58 AM   #928
8man
The props look good. Waiting for more pictures.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 03-14-2019, 08:30 PM   #929
reaper71
reaper71's Avatar
Here are the panels I made to try and make the sides look a bit better.
Old 03-14-2019, 08:50 PM   #930
joedoh
joedoh's Avatar
man that does look really good, does it fit your vision now?
you can really see all the work you have put into that cab from that picture too, really nice work!
Old 03-14-2019, 09:36 PM   #931
OutlawDrifter
Looks great! +1 on what Russ said, to of work. That trans/rear engine tunnel still gets me, I'm so jealous.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-15-2019, 05:53 AM   #932
RockinKees
RockinKees's Avatar
That’s gonna be nice and clean under the hood!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 03-15-2019, 08:32 AM   #933
reaper71
reaper71's Avatar
Russ...This is the beginning of the project.
Still need to weld them in and metal finish. (as usual all this is already finished)in the later pics I'll show the rib issue.
Outlaw thank you!
Kees thank's. I hope it looks as good as I'm hoping!
Mark
Old 03-15-2019, 08:39 AM   #934
8man
Like the panels.
It looks like you put an over lay panel over the original firewall. If that is right, what did you do between the "two" panels to treat for potential rust. Also, are they flush against each other so that when the brake pedal/master cylinder are tightened down they won't deform?
8man-aka Robert
Old 03-15-2019, 09:05 AM   #935
reaper71
reaper71's Avatar
8man
Yes they are overlaid, on the original setup for the master I reinforced that area. So when I made this new plate it buts up to it and will get welded to insure it will not buckle.
Old 03-15-2019, 09:09 AM   #936
reaper71
reaper71's Avatar
If you look at the section for the master you can see a slight stick out.
And to answer you ? On prep I sprayed weld through primer.
Mark
Old 03-15-2019, 10:12 AM   #937
8man
Thanks Mark.
I have to do something to the firewall on the 54, it's a mess! I like the idea of doubling the steel in there for some support.
8man-aka Robert
Old 03-18-2019, 08:08 AM   #938
reaper71
reaper71's Avatar
poc 1. Being tracked in place.
Pic 2. Mare tracking, I also was doing some mig and some tig at this point.
Pic 3. So after I had it all welded in I hated the "non symmetrical" look it had so I cut the ribs out to fix this.
Mark
Old 03-18-2019, 08:45 AM   #939
8man
That trans tunnel looks good, and the slick firewall is nice. I need to go back and see your work and understand the steering column bracket.
8man-aka Robert
Old 03-18-2019, 09:22 AM   #940
Advanced Design
Advanced Design's Avatar
Looks good Mark. Nice work!
Advanced Design is offline   Reply With Quote
Old 03-19-2019, 08:06 AM   #941
reaper71
reaper71's Avatar
8Man the column mount is super easy.
It's made from exhaust tubing to fit the column tube,then welded to the floor in the desired angle. This way it lock's it into place. we've been doing like this for yrs.
Doug,thank's again!
Mark
Old 03-19-2019, 08:19 AM   #942
reaper71
reaper71's Avatar
Here are a few more shots of the firewall redo.
The metal I originally used for the firewall was thinner than I liked so I made a new piece to match the other repairs.
Now it looks cleaner!
Mark
Old 03-19-2019, 08:54 AM   #943
8man
Mark, did you weld the two small firewall/fender pieces to the firewall? They were attached with a couple of sheet metal screws, one plate on each side. If so, please post a close up picture. I like the firewall work and will be doing my best to copy what I can of it.
8man-aka Robert
Old 03-20-2019, 07:50 AM   #944
reaper71
reaper71's Avatar
8man
Yes all.was welded in solid, to prevent it from getting water behind the panels.
In this pic it shows a ton of tack welds to try and keep from warping.
Old 03-20-2019, 07:57 AM   #945
reaper71
reaper71's Avatar
I need to switch gears for a bit (getting burned out on the firewall)
So I started getting the motor prepped for paint.
Started by removing all pans,covers,tubes etc.
As the motor will be getting all new gaskets. I also removed the balancer and timing cover to replace the gasket and seal.
After masking I sprayed with etching primer.
Mark.
Old 03-20-2019, 08:21 AM   #946
8man
Thanks Mark, that's what it looked like. I thought the same thing, weld it up and no holes for water. Another "to do" added to the list.
8man-aka Robert
Old 03-21-2019, 08:17 AM   #947
reaper71
reaper71's Avatar
Engine painted, the stock valve covers were used as masking.
The timing cover was painted the custom bronze I mixed to match the wheels.
Mark
Old 03-21-2019, 08:21 AM   #948
8man
What a difference some paint and hard work make!
8man-aka Robert
Old 03-21-2019, 11:26 AM   #949
RockinKees
RockinKees's Avatar
Very nice Mark.
I’m jealous.....
Cheers!! Kees.
Kool Guyz CC
Old 03-21-2019, 08:33 PM   #950
joedoh
joedoh's Avatar
pretty work on the motor! I like the black and bronze accent, very unique
