03-28-2020, 04:14 PM | #926 |
Post Whore
Re: Columbus..the 1957 IH 4x4..
Well what I thought was gonna be high build day turned into another day of epoxy...once I got it all back in the shop and got a light close to it, the epoxy had a leathery look to it...I tried red scotchbrite and 180g and it wouldnt cut it..so it hit it with 80g again...so I sprayed 2 more coats of epoxy on it...supposed to storm tonite and sun...maybe mon I can get the high build on it....
I dont know why I'm getting that leather look in the epoxy...its done that before but I dont know what I'm doing wrong...I made sure everthing was tight...the net said it happens from air getting in the fluid chamber thru loose fittings..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 03-28-2020 at 09:02 PM. |
04-01-2020, 08:26 PM | #927 |
Post Whore
Got front and rear fenders in high build today...no pics cause they look just like the epoxy color...more sanding coming...hopefully I wont need to shoot them again with primer...fingers crossed..
04-02-2020, 09:54 AM | #928 |
Proprietor of Dale's Corner
Oh, joy....my least favorite activity....sanding. Enjoy it and don't forget to keep us updated.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-02-2020, 02:34 PM | #929 |
Post Whore
yeah...it seems like ever time I sand I create more problems..sighhh...
congrats on totm Dale..!!!!
04-04-2020, 12:29 PM | #930 |
Looking forward to more progress pics. Saw this story and thought of you- I know it’s a lot older than yours, but it’s a good story. I like all the bags, even stacked on the roof
71 C10 72 K20 72 K10 Super Kirk |
04-04-2020, 08:28 PM | #931 |
Post Whore
That's so cool Kirk..thanks.!!
04-04-2020, 08:30 PM | #932 |
Post Whore
Just as I suspected...after sanding the high build I get to spray it again with more high build..yeehaw..
I had sanded all the fenders with guide coat and used a durablock...but when I switched to the plexiglass sanding backers, it really showed how bad my work had been..on the 4 fenders I had about a dozen low spots show up and cut thru the high build into the epoxy in several places...most low spots would have filled with some more high build ,but I had 3or4 spots I didn't think the high build would fill properly..so I went ahead and scuffed all the lows with 80g and skimmed on some metalglaze... got that blocked down and now all fenders look good...will spray on another coat or 2 of high build tommorrow and those should be done.. Also got the tailgate in some more epoxy ,,after my last round of sanding exposed alot of bare metal..it looks good now so I'll hit it with high build tomorrow as well..the epoxy has a 3 day recoat window with no sanding..so I'm just gonna spray right on the epoxy without scuffing... Now to get the bed ready for paint.. Heres the tailgate...I feel so fortunate to have a near blemish free tailgate..I was told it was taken off the truck when new and stored in a barn for many yrs...
04-05-2020, 08:50 PM | #933 |
Post Whore
Spent all day spraying high build...4 fenders, 1 tailgate, 2 running boards, and 1 bed...all in high build now for the last time...(fingers crossed)...I'm gonna start out with 220g and follow up with 320g...I'm on the fence as wether to do 400g before paint....the paint store man said 320g was fine...everybody else says 400g...
04-06-2020, 02:29 PM | #934 |
Thanks, I hope the blocking goes well this time.
04-06-2020, 04:14 PM | #935 |
Post Whore
Thanks Dale...so far so good...sanding is going ok.....I know it wont be perfect ...but I'd like it to look decent..
04-06-2020, 05:12 PM | #936 |
Looking at that tailgate, I'd say you are succeeding.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-06-2020, 07:23 PM | #937 |
Post Whore
Well Robert...not so fast...haha..
04-06-2020, 07:23 PM | #938 |
Post Whore
Not much done today...after bushogging, piling brush, and running some errands for the socially distanced folks, I got a late start...so I sanded on the tailagte,....and the persistent low spots started showing,....again.... so I hit it all with 180g and sprayed a few more coats of high build on it....I think some of the high/low on it is from the stamping of the metal..there was alot of moving metal going on when they punched it out....however it turns out this time will have to do...but it think itll be ok..
Rear fenders are good to go...will spend some time tonite sanding on the bed
04-06-2020, 10:57 PM | #939 |
You want to be sanding your final primer before paint with something much finer than 320. 400 would be what I would consider the roughest, at least a "once over" with some 500 would be a good idea. Lorne
04-06-2020, 11:21 PM | #940 |
Post Whore
Thanks haulin....I've got plenty of paper....that's no issue...just going by (320g) what the paint store man told me...the paperwork says 400-600g...and I've got plenty....
04-07-2020, 12:15 AM | #941 |
I use 500 for solid color and 600 for metallic. If you still need to spray sealer, the grit number is a bit more forgiving. Panels are looking good!
Robert |
04-07-2020, 12:22 AM | #942 |
Post Whore
Thanks Robert..!!...there again the guy at SW said I dont need sealer...even though the primer is the lighter gray and the paint is dark red...hes adamant about it...talked to him several times about using sealer..the paint is solid color single stage...no metallic..
04-07-2020, 10:33 AM | #943 |
Yeah, you should be fine...
Robert |
04-07-2020, 10:51 AM | #944 |
Post Whore
Thanks Robert...the parts that I already painted red with the flattner added turned out ok, without using a sealer...no coverage issues anywhere.....so I'll proceed on to paint once I get done sanding...thanks again
04-07-2020, 01:34 PM | #945 |
Post Whore
Finally got some painting done....but not red...I had previously painted the dash panels,door panels,and radio box with rattle can paint...never was real happy with the results...so I had the guy at SW paints match me up some real paint...added flattner to it to semigloss level...I think they turned out much nicer than before...
Also gave me a chance to try out my little baby spray gun...its the Eastwood concours touch up gun..heres a door panel that's done showing the color..the rest of the parts are in the shade.... and the sweet little gun...
04-07-2020, 02:01 PM | #946 |
looking good. It's amazing how nice a job some of the cheap guns will lay out. I had to get a set of the cheap harbor freight guns when I did my 72. I was on a schedule and my dads Devillis had a cracked tip.. Perfect coverage and only 1 run. I was impressed since it had been nearly 20 years since I shot a truck. Only thing I did t like about the HF gun was it is impossible to put it back to the same setting after cleaning so I just kept a test panel near by for final tweaks.
I am waiting to see the red. I think that single stage looks much nicer on older trucks. It usually has a flatter deeper color compared to clear which usually has a more wet appearance. |
04-07-2020, 05:06 PM | #947 |
Post Whore
Thanks burning oil..I've never used a good gun, so I dont know what I'm missimg..haha
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-07-2020 at 08:21 PM. |
04-07-2020, 05:08 PM | #948 |
Post Whore
So after getting the little paint job done, I started in on the tailgate...I had quite a few low spots from before so I had added more high build...here you can see how the panels really slicked out...those plexiglass sanding boards are working great for flat surfaces....you can see the only low spot I have left is right under the R...a little hand sanding knocked the gloss off and I'm gonna live with it...
I've worked all afternoon sanding on this tailgate..its unreal how many nooks and crannies there are..but I've got the whole thing sanded and slick..now just need to follow up with finer grit for paint... Sanding around the (INTERNATIONAL) is extremely tedious...I made a half dozen small sanding boards to work around the letters....... One step closer..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-07-2020 at 08:22 PM. |
04-07-2020, 05:37 PM | #949 |
That's looking good.
04-07-2020, 08:25 PM | #950 |
Post Whore
thanks Robert ...
