Old 10-31-2010, 08:04 PM   #951
sourkraut
sourkraut's Avatar
Re: 1967 C10 Custom Big Window
truck is looking awesome and sounds great!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 10-31-2010, 10:27 PM   #952
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks sourkraut!! Did a quick vid to show that I have to give it alot of gas just to get it going, I guess that the trans is not filled up yet so I hope there are no issues.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 11-01-2010, 10:45 AM   #953
my67chevytruck
Under Construction
my67chevytruck's Avatar
Congrats on the milestone Bro........ sounds good! we had a small rear intake leak, so i had the pleasure of R&R the intake this weekend, hope it's sealed up good now.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-01-2010, 11:55 AM   #954
kev2809
low n' slo
kev2809's Avatar
good progress man! nice to see that thing rollin!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-01-2010, 05:19 PM   #955
Slick67
Sofa King Crazy!!
Slick67's Avatar
That sux. I am having the slippy transmission issue right now so we'll see what happens.......
Thanks Kev!! Taking it to Niftee 50ees this weekend (weather permitting) and let people check it out for the first time at a big show. You should try to make the pilgrimage to the Northside of town!!!!
Old 11-01-2010, 05:22 PM   #956
Slick67
Sofa King Crazy!!
Slick67's Avatar
Got the rotors cleaned, painted, and installed today!!!!
Old 11-01-2010, 09:24 PM   #957
my67chevytruck
Under Construction
Looks sweet!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-01-2010, 10:54 PM   #958
butternut1972
butternut1972's Avatar
I told ya you'd be driving in no time! sounds good.
butternut1972 is offline   Reply With Quote
Old 11-02-2010, 12:52 PM   #959
Slick67
Sofa King Crazy!!
Slick67's Avatar
Looks sweet!
Thanks Heath! I am tryin to follow the pic that I drew of it as closely as possible.
You were right...just not really "driving" it. Can't wait to get the trans correct so when I push the gas it goes!!
Old 11-02-2010, 01:49 PM   #960
VA72C10
VA72C10
VA72C10's Avatar
Have you checked both the fluid level and also the kickdown cable adjustment? Don't think it is the cable...but you never know until you rule out all the possibilities...
...was the torque converter full of fluid when you bolted it up?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-02-2010, 02:21 PM   #961
Slick67
Sofa King Crazy!!
Slick67's Avatar
I do not have a kickdown cable that I am aware of, maybe I am mistaken but the only thing going to it is the shifter and the vacuum. It is a TH 400 so that may be a little different than a 350? The fluid is full but I have not been able to let it warm up yet. I drained about a quart and a half out of the tc when I pulled it but surely it has filled back up by now after adding at least 5 quarts. Help!
Old 11-02-2010, 02:36 PM   #962
VA72C10
VA72C10
VA72C10's Avatar
I'm no tranny expert...do you have the vacuum operated or electric kickdown then???
Have you tried with it manually in low 1 to rule out that possibility it's not taking off in 2nd? Stock or higher stall converter???
Old 11-02-2010, 04:12 PM   #963
Slick67
Sofa King Crazy!!
Slick67's Avatar
The vacuum goes to the modulator and I have one electronic plug on the drivers side. I have tried low 1 and 2 and there is no diff. I am guessing it is a stock tc but I can't be sure. Tomorrow I am going to talk to the tranny shop at the end of the block and see what he thinks also.
Old 11-02-2010, 04:19 PM   #964
mcbassin
Still Learning
mcbassin's Avatar
Sounds great! Looks Great! now finish it up and enjoy it.....just enjoy it.
mcbassin is offline   Reply With Quote
Old 11-02-2010, 04:23 PM   #965
VA72C10
VA72C10
VA72C10's Avatar
seems to be acting like it's got an agressive converter....what RPM's are you revving to get it running?
Old 11-02-2010, 04:24 PM   #966
Slick67
Sofa King Crazy!!
Slick67's Avatar
Ahhh yes, the holy grail of all projects.....enjoyment. Thanks MB! The interior is a little ways out, but it will be done for next season. Taking it to the show this weekend for the first time to see what kind of response it gets.
Old 11-02-2010, 04:32 PM   #967
Slick67
Sofa King Crazy!!
Slick67's Avatar
It does seem rather agressive but it didn't before the build. No tach yet but it is around 2500 to 3000 I would estimate. When I get the exhaust ran it may sound like less rpms also.
Old 11-04-2010, 01:39 AM   #968
Slick67
Sofa King Crazy!!
Slick67's Avatar
Talked with a transmission guy today and the news ain't good. He said that it could be stuck in a low gear or the tc was not installed correctly and it is eating the shaft........if there is shavings in the pan then I'll know that it's time to pull the trans out.
Old 11-04-2010, 02:19 AM   #969
Slick67
Sofa King Crazy!!
Slick67's Avatar
If the transmission is gonna have to be pulled then my thread will be put on hold.......not! Still have other stuff that can be done and in the meantime I'll just sit back and stare at it sitting.
Old 11-04-2010, 08:51 AM   #970
VA72C10
VA72C10
VA72C10's Avatar
sorry bout the trans....hope it's a simple fix....
Old 11-04-2010, 09:59 PM   #971
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here is the latest. I had my truck at the custom shop to have my air ride checked out and dialed in. My brother called me and had a customer of his talk to me about the transmission, he said that it is the pump and that if I bring him the tranny he will fix it for $100. Nuff said.....the tranny will be dropped and he will get it soon!
Old 11-05-2010, 04:04 AM   #972
texanidiot25
Eat My Rust
texanidiot25's Avatar
Originally Posted by Slick67 View Post
I am soo close......but it is going to be at the last one for sure, finished or not. It will have no interior but will be driveable. Really hope you are able to make it to that one!!! PM me where ya live cause I am spring too!
What's the date on the last show of the year? I'll bring the CST/10 back from Austin for that.
texanidiot25 is offline   Reply With Quote
Old 11-05-2010, 11:07 AM   #973
Slick67
Sofa King Crazy!!
Slick67's Avatar
Bring it this weekend! I know that's pushin it, but I think the last show is the 13th of November.
Old 11-05-2010, 03:28 PM   #974
shiner2001
shiner2001's Avatar
I was wondering about that too. Since I can't make it this weekend, I'd really like to come down for one of the shows before they wrap up for winter.
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 11-05-2010, 09:44 PM   #975
Slick67
Sofa King Crazy!!
Slick67's Avatar
The last show is next weekend, the 13th. It will crank back up in May so that isn't too long of a wait!
1967, custom, lwb
