Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-15-2022, 08:49 AM   #951
regan wilson
regan wilson's Avatar
Re: Ok Boys and Girls it's Storytime
Originally Posted by SCOTI View Post
The push rod issue.... Is that a thing were you have to check multiples to ID the issue or an anomaly?
There are three different length pushrods. Two different intake and then the exhaust. It may have been the cut up pushrod that caused me to miss it on the length. It may have had a smaller od end on it than my pushrods. The seat was higher in the new lifters. It threw everything off.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 02-15-2022, 08:51 AM   #952
regan wilson
Originally Posted by A.Delaney View Post
Those are some massive intake ports!
Yes Sir! I can stick four fingers high in them.
Old 02-15-2022, 08:56 AM   #953
regan wilson
We got it running Sunday evening. I was in the shop from 8am till 7pm. I should have quit at 5pm. I had a little hiccup and chunked a pushrod. I think everything is going to be ok though. My new alternator belts were too short but I'll have some more tomorrow. Chrome don't get you home but some newly added stainless hardware cleans everything up a little.
Old 02-15-2022, 05:56 PM   #954
mongocanfly
Post Whore
mongocanfly's Avatar
It's a beaut to look at,,,,no matter what
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-15-2022, 09:55 PM   #955
regan wilson
Thank You Bud!
Old 02-16-2022, 08:28 AM   #956
regan wilson
When we got the truck running I wasn't showing any fuel pressure. I've been messing with it the last two days. I finally had to pull the cluster. Like I haven't had it out enough times this winter. I loosened the isolator line at the bottom and bulbed antifreeze into it and capped it off. Luckily it's working now. I didn't know if it was the gauge or my pump .The way my luck has run lately I wouldn't doubt I had a pump issue.
Old 02-16-2022, 09:18 PM   #957
regan wilson
My new belts were here when I got home today. Luckily everything worked out. I only had 10.25" to 10.75" of centerline to work with on belt size. Andrew at Jones Racing Products sent me the right belt. They have to calculate the tooth count on both pulleys and the centerline to get the right length.
Old 02-16-2022, 09:21 PM   #958
SCOTI
SCOTI's Avatar
Where's the debut on the freshened mill?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-16-2022, 09:49 PM   #959
regan wilson
Next week in Belle Rose, La. We'll get it finished up and loaded this weekend.
Old 02-16-2022, 11:26 PM   #960
SCOTI
SCOTI's Avatar
Thanks.
It was probably mentioned but when I went back to look I just missed it.
I'll be on the look-out when you're closer to home.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-17-2022, 08:44 AM   #961
regan wilson
Thanks.
Tx Motorplex May 19th to the 22nd.
Old 02-19-2022, 08:20 PM   #962
regan wilson
Old 02-19-2022, 08:21 PM   #963
regan wilson
Dirty but ready to go!
Old 02-19-2022, 08:23 PM   #964
regan wilson
Flat Hoods are cool!
Old 02-20-2022, 12:59 AM   #965
SCOTI
SCOTI's Avatar
Sweet! Looks clean enuff for the task.
Go get-em!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-21-2022, 09:12 AM   #966
regan wilson
Go get-em!
Thanks Scoti. As I said it would probably be down to the wire on getting ready. It's in the box and ready to go.
Old 02-21-2022, 02:36 PM   #967
mongocanfly
Post Whore
boxed up...just needs a ribbon on it..!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-22-2022, 09:53 AM   #968
regan wilson
It needs to bring home a Wally and a Paycheck.
Old 02-22-2022, 09:55 AM   #969
regan wilson
On another note. Mongo nominated me for TOTM this month. Vote now vote often! Lol
Old 02-22-2022, 10:00 AM   #970
Liz
Catchy title goes here..
Liz's Avatar
well deserved imho
Liz is offline   Reply With Quote
Old 02-22-2022, 10:04 AM   #971
regan wilson
Originally Posted by Liz View Post
well deserved imho
Thank you Liz.
Old 02-23-2022, 08:03 PM   #972
regan wilson
Well I feel like a Glutton for Punishment right now. I'm loaded and ready to leave in the morning. When you go from 80 degrees one day to 30 degrees and rain and you are trying to go racing? It makes you question your Sanity. But we are heading down south in the morning.
Old 02-23-2022, 10:49 PM   #973
SCOTI
SCOTI's Avatar
Be careful. Highways are slick North of you. Had to scrape windows before driving anywhere after work here in Dallas. Hopefully the moisture doesn't migrate that far South & spoil the opportunity.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-24-2022, 07:19 AM   #974
regan wilson
Thanks Scoti. It's just wet here now and around 32 degrees. Luckily the ground is too warm to cause any issues. We're heading out in a little while.
Old 03-03-2022, 10:09 AM   #975
regan wilson
Things didn't go well in Belle Rose. I made two hits and burned up and exhaust pushrod. I had other issues I didn't realize. It's all valvetrain related. I have the motor out and the pushrods are being sent back again. I have an issue with three rocker arms that I'm trying to fix. Spare rockers seem to be unobtainable and I'm not sure mine are up to the task. I'm calling all over the country looking for spares as T&D are 12 weeks out. I can buy a whole set but that would be probably close to $2500.00. That isn't happening. Just another example of what's going on in this country unfortunately.
