06-08-2013, 06:53 AM | #951 |
Re: Extreme Powder Coating '65 C-10 Shop Truck
It is boiling the fuel after the pump... our new crappy gas with boil at 90 degrees .. fuel temp was 166 ... moving a coolant line and re-routing a fuel line
edited by staff |
06-08-2013, 07:27 AM | #952 |
dang i never would have guessed that.. what is heating it up so bad? exhaust, compressors?
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
06-10-2013, 07:22 AM | #953 |
The upper coolant line into the intake manifold... and the fuel line out of the mech. fuel pump is 1/4 in. from lower rad. hose.. All plumbed with alum. AN fittings boiling fuel at the 90 degree bends..
edited by staff |
06-10-2013, 08:05 PM | #954 |
Glad you got it figured out! Hope you get it all fixed, and can enjoy driving it soon!
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans Project Dooley One-Ton 4x4 on 38.5s Corn-binder build |
06-17-2013, 07:20 PM | #955 |
Does any one know the caster and camber settings for a Dropmember at ride height?
edited by staff |
06-18-2013, 08:42 AM | #956 |
The suspension gurus say 0 caster and any where from 3 to 7 camber for cornering depending on what your using it for...daily driving 3 to 5 If I remember the numbers correctly....
Geoff |
06-18-2013, 05:32 PM | #957 |
67-72 parts collector,…
I think you have your camber and caster backwards,...
06-24-2013, 02:20 PM | #958 |
OK Guys... NEED HELP Please....
Whats wrong with my engine combination on " NO Paint" ??? .030 over 1965 327 2.02 461 heads / 10-1 comp. Speed Pro pistons / full Comp Cams valve train package with a Comp Cams 295 TH7 mutha thumpr cam / Trick Flow Street Burner intake duel plain. 1997 T-56 6 speed with a Richmond posi 4.11 rear gear 31.5 tall tire.. What is wrong??? ... it will not pull 5th or 6th gear.. no low end... not happy with the performance and this TRUCK needs to be In Columbus / Good-Guys this year.. wrong cam ? need more gear ??? Please help..
edited by staff Last edited by kart34; 06-24-2013 at 02:36 PM. |
06-24-2013, 02:29 PM | #959 |
You might post up in the engine/drivetrain area,...
06-24-2013, 02:53 PM | #960 |
5th is overdrive and 6th is a DEEP overdrive in that tranny correct? Seems to me you are over cammed. Looks like the RPM range for that cam STARTS at 2500 RPM and tops out at 6400. 2500 RPMS in that tranny in 5th gear is going how fast? I have a 383 stroker in my Impala with a 670 cfm carb and a more moderate cam that starts around 1500 RPM's. It only dynos at 394 H.P. but makes 454 ft. lbs of torque. For ****s and grins bring it up to about 4500 RPM in 4th and shift into 5th and see if it will pull then. I just think it is set up for too high of an RPM range. Also, what is the carb? Is the timing right?
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
06-24-2013, 02:59 PM | #961 |
We have the Street Demon ( new style by Holley) combo carb/ looks like a Edelbrock / quadrajet deal.. 625 cfm.. We will check the timing ....
Also posted this up on Engine /driveline forum.. thanks.. 4 th gear it pulls great... runs best in 4th gear.. maybe just yang it out Blueprint 383 stroker 420 hp is what I need...
edited by staff |
06-24-2013, 03:33 PM | #962 |
sounds like it may not have enough gear and a little too much cam for the 327, a 383 or 400 with a little less cam or more gear might help, something with lower end torque. Just my opinion.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
06-24-2013, 03:35 PM | #963 |
Yes... looks like a cam and gear swap..
edited by staff |
06-24-2013, 03:55 PM | #964 |
edited by staff |
06-24-2013, 06:19 PM | #965 |
That camshaft with the little cubes makes it for higher RPM then advertised. Smaller cam, and more gear with that size rear tire. @ 1800RPM in 6th gear you doing 82mph that is not enough RPM for that motor. 4th gear 2500RPM you are doing 57MPH. You need to switch your rear gear to 4.88 min. or change the tire height.
06-24-2013, 08:01 PM | #966 |
Registered Loser
Hope you get everything sorted out. After the way my summer has started I really NEED to see your truck in Columbus.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
06-25-2013, 09:11 PM | #967 |
thanks Guys... picking up a alum. headed 383 stroker 430hp..457 torque.. that should fix the problem...
heading to Speedway Motors in the early am..
edited by staff |
06-26-2013, 03:52 PM | #968 |
If 457 torque won't scoot, I don't know what will. I guess you could always just drop in an LS9.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
06-26-2013, 08:45 PM | #969 |
Pretty happy... gotta 383 stroker today from Speedway Motors,built by Blueprint Engines, fresh build 5/22/2013 hp was better than thought 442hp @5600 rpm 445.1 on torque @ 4400 rpm alum. headed straight plugs also... so.. hopefully no exhaust issues, I got a set of Hedman block huggers on it now all ceramic coated... I hope the install goes well.... Roger Burman is painting the short block tonite.. Great crew down there..thank you Lakeside Rods and Rides.. I will have Tiffany post up some pics.soon...
edited by staff |
06-28-2013, 09:07 AM | #970 |
Never Done?
That 383 oughta be sweet!
Are you still running the eBay mustang mufflers? If so, are you happy with them? I'm going to be taking mine to the exhaust shop next week.. finally! |
06-28-2013, 09:55 PM | #971 |
Alvin, Yes still running the mustang mufflers...
edited by staff |
06-30-2013, 09:02 AM | #972 |
Well, We ran into a little problem.. 327 flywheel not campatable to 383 stroker... gotta order a complete flywheel / clutch combo early Monday AM.. any suggestions who I should call ? Bowler ? I got a 1997 T-56 tranny
edited by staff |
06-30-2013, 01:12 PM | #973 |
Is your 383 running a 400 type externally balanced crank? Mine had an aftermarket stroker crank and was internally balanced so a regular small block flywheel fit. Why wont the 327 wheel work specifically?
06-30-2013, 06:28 PM | #974 |
Registered Loser
If I remember correctly my 383 needed a 400 balancer and flexplate.
07-01-2013, 10:52 AM | #975 |
it has a big balancer on it now.. got Twin Cities Rod and Custom calling Blueprint Engines and Speedway Motors..
edited by staff |
Tags |
'65, c-10, carter hickman designs, extreme powder coating |
