08-10-2006, 09:32 AM | #76 | |
Re: LS1/T56 installed!
1986 C10 - LWB, 305/700r4, posi, vortec heads |
08-10-2006, 09:48 AM | #77 | |
Questionable
I don't even know if "too much travel" is an issue with our trucks, to be honest.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-10-2006, 01:23 PM | #78 |
Please tell me who this S&P is. Do they have a website? If you send me a number I will try to contact them.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
08-10-2006, 01:40 PM | #79 |
Street & Performance --> http://www.hotrodlane.cc/
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
08-10-2006, 01:44 PM | #80 |
Yes Sir!!!! That is, indeed a good feeling!!! Congrats!!!
08-10-2006, 06:37 PM | #81 |
Cereal Killer
You can get rid of the optispark and put the Dist up top where it belongs.......but it takes work.
08-10-2006, 07:00 PM | #82 | |
Before you throw the baby out with the bath water, one should check this product out www.dynaspark.net.
I have this distributor in my 94 z-28 and it is an excellent product. Quote:
08-10-2006, 10:01 PM | #83 |
Cereal Killer
simply stating i know of several LT1's with the dist on top....you loose the sequential injection of the LT1 but gain the durability of a gm HEI dist.
09-28-2006, 02:47 PM | #84 | |
Questionable
That's essentially it. You need to make allowance for 15/16" of of actual rod travel for the clutch to engage, or at least, this is what I grasp. I realize it's a little far along for a bump, just trying to share in case I'm not around in a few months.
03-23-2007, 01:03 AM | #85 |
How is it coming?
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
03-23-2007, 01:53 AM | #86 |
The original post was almost 3 yrs ago. He has had that truck running for quite a while now.
Anthony |
03-23-2007, 10:19 AM | #87 |
Questionable
Actually, the truck is totalled already. Someone rearended him, totalled out the truck, and I think he is putting the engine in a Porsche (unless that's a completely new build).
06-07-2007, 01:34 PM | #88 |
For the original thread maker (doubtful due to the totaled truck) or anyone who might know. Since you made your own mounts, is there a reason you didn't shift the engine & trans forward for a better shifter position? I assume there would be interference issues somewhere, but just curious.
Second question I'm sure shifty knows. I read your entire LS1tech thread, did you have to switch to the truck pan, or was it just easier? Seems like a lot of coin to spend (pan, windage tray, etc) if it wasn't necessary. Between great people on this site, and the LS1tech forums I'm learning too much to rebuild my 350. |
06-07-2007, 02:31 PM | #89 |
Questionable
It was easier (truck pan), and I would recommend it for the sake of clearance. You need the pan, pickup tube and oil dipstick (+tube). I could have gotten it cheaper, but I chose not to do it that way
I thiunk FirstGen mounted it that far back for a couple of reasons: better weight distribution over the axle, more room in front of it (mine is cramped in the front!), possibly to have room for addons later -- and, no doubt, header installation is easier with the engine farther back.
06-07-2007, 05:28 PM | #90 |
I love this place!
03-06-2008, 10:29 AM | #91 |
this is bad@$$
03-06-2008, 10:33 AM | #92 |
reachin way back!
03-06-2008, 10:36 AM | #93 |
gotta keep stuff like this ALIVE sometimes lol so they dont get lost.. search feature helps.... lol better than askin ya know... do the searchin then ask if cant be found...
08-07-2008, 12:51 AM | #94 |
I am going through a LSx swap myself.
I am going to build a custom Auto Meter dash. Can I tap into the factory wiring harness to make the water temp, oil pressure, speedo, and tach?
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
08-07-2008, 07:25 PM | #95 |
you will have to keep the water sender on the drivers side head for the computer but you can tap the pass head for your guage, as for the oil sender you can do the several ways but you can't use the ls harness as far as I know or I was not able to. Let me know if you have any questions.
