Old 01-25-2007, 05:35 PM   #76
vtblazer
vtblazer's Avatar
Re: Went to a Bigger Blazer
Pics of the progress.
vtblazer is offline   Reply With Quote
Old 01-26-2007, 05:02 PM   #77
Yukon Jack
Post Whore
Yukon Jack's Avatar
Great to see you get it installed. I'm just waiting for some warmer weather around here so I can stab my 400 sbc in my K5. Good luck getting the tank installed today.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-26-2007, 06:32 PM   #78
vtblazer
vtblazer's Avatar
Well...the tank isn't going to fit as expected.
Contacted 'fuel cell guy' to find out what he has.
Old 01-26-2007, 07:23 PM   #79
1969k10stepside
That fuel injection is gonna be a good thing for that blazer.
Good luck on getting it back together and running
(I have had my motor out a year,still doesnt have one )
BTW,your making me so jealous with that blazer....Im setting up a deal to get one....wont be that monsterous though
1969k10stepside is offline   Reply With Quote
Old 01-29-2007, 01:09 PM   #80
BUDDY
Global warming is a myth
BUDDY's Avatar
Wink Re: Went to a Bigger Blazer
Just make your own.
Later,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 01-29-2007, 01:50 PM   #81
RAB38
I used a oem plastic tank and cut a hole in the top, made a bracket to hold the in tank pump. Works great. I'll see if I can find some pics.
72 Blazer CST 383 stroker roller, fuel inj, t350,NP205, D60 front, 14b rear, detroit locker, 38 x15.50 mtz's, welds, cross over steering, custom cage,Line X Spray in liner, House of Colors Tangelo Pearl Orange
RAB38 is offline   Reply With Quote
Old 01-29-2007, 02:49 PM   #82
Chris27
Blazerless
Chris27's Avatar
What's in the way of the tank? I've got a '90 Blazer tank in my '72.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 01-29-2007, 06:57 PM   #83
vtblazer
vtblazer's Avatar
My current exhaust routing dosen't help and I'm not willing to have it sit lower than the previous one and as it turned out, I'm not wanting to cut my cross member to raise it through the floor either.
An intank pump retro-fitted to my poly tank may be the answer but I like the idea of a fuel cell, just waiting for pics to be sent from the 'fuel Cell Guy'
Did get it installed and running at least, mounted to old 90 blazer tank in the back bed for 'testing' purposses.
Old 01-30-2007, 10:19 AM   #84
Burt4x4
Burt4x4's Avatar
Lookin good..is it just the pic or is your PS pump return line bigger than normal
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-30-2007, 10:29 AM   #85
Chris27
Blazerless
Chris27's Avatar
OIC, I got exhaust after the tank swap. And I removed the crossmember and fabbed a new one (the old one was pretty rusty anyway). Looks good! Looks alot like the engine bay of my K5. Only mine's closer to the ground .
Old 01-30-2007, 12:49 PM   #86
vtblazer
vtblazer's Avatar
That's the high pressure line I had made using hydraulic crimped on ends instead of the ones supplied with the kit.
It's a PSC ram assist kit, see the aluminum reservoir on the rad support where my spare battery is supposed to be?
Only allowed an 18" hose from the pump, so that's where it gets to live.
Old 01-30-2007, 07:03 PM   #87
jaros44sr
jaros44sr's Avatar
Nice work, now I have model to follow. Looks like you did all the hard work. Thanks
This thing will never be dun. J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-30-2007, 07:34 PM   #88
vtblazer
vtblazer's Avatar
Oh man...I sooo hear that.
Old 02-04-2007, 07:21 AM   #89
vtblazer
vtblazer's Avatar
Installed/running and semi tuned.
As every install has it's stories...
We finished the install/start up late on a Sunday night, backed the thing outta the shop and went home.
I left feeling like it was running pretty crappy and no where near how I expected an injected 383 to run.
I goofed with the timing but didn't start to worry cause the I knew the plug wires were total crap. (figured they were messing with the ECM)
The new 'LiveWire' plug wires came Fri afternoon and I installed them on Sat.
In the mean time, I'd been reading all about how a stock TBI won't properly run a 383 and was truley beginning to worry now.
Okay, long/short of it...
Plug wires 6 & 8 were switched on the dizzy. Amazing how well it did run like that.
So now it runs like it should, I can power brake my 39.5's!
Still needs some minor tuning but wow, what a difference.
Can't wait to wheel it and have throttle response/power on demand.
Old 02-04-2007, 08:53 AM   #90
meathead95
computer illiterate
meathead95's Avatar
so on a scale of 1 to 10 how hard was the swap?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-04-2007, 09:01 AM   #91
vtblazer
vtblazer's Avatar
1st time ever doing the swap, it's somewhere around a 7 or 8.
Takes a fair amount of planning and set up to get it right the first time 'round.
I also did quite a few other mods while I was in there, so that all added to the total.
Doing it a 2nd time will be a 3.
Will I do it on another truck? Absolutely!
Old 02-04-2007, 09:14 AM   #92
meathead95
computer illiterate
meathead95's Avatar
what harness did you use?
72 2wd blazer
72 swb 4x4
Old 02-04-2007, 09:28 AM   #93
vtblazer
vtblazer's Avatar
I went with the Painless #60101
I have the 'longer' version for my TPI and wish I had just got the normal harness, it's way to long IMO.
Old 02-05-2007, 09:02 AM   #94
vtblazer
vtblazer's Avatar
Can't believe I forgot to post the pics of my 'minor' fender trimming job.
Needed the room to flex so I did what I had to do.
Last pic shows the same exact 'position' sitting on the concrete block prior to the trim job.
Old 02-05-2007, 12:07 PM   #95
Still trimmin`,eh?
Old 02-05-2007, 06:33 PM   #96
1969k10stepside
Geez Kurt,you aint gonna have much left of them fenders if you keep getting bigger tires Im buying a blazer,you want to come over and convert mine to a 1 ton?
Old 02-05-2007, 07:10 PM   #97
vtblazer
vtblazer's Avatar
I hear ya but it was a necessary evil.
Plans are in the works for a bolt on fender lip that will (should) look like the originals.
It works and that's my story.
The one ton conversion is the easy part but start adding in the gears/spooled front axle/drive line e-brake/braided brake lines/roll cage/fender clearancing/detroit locker/HD diff covers/Alcan lift springs/zero rates/tilt column/cable shifter/doubler/built tranny/cardon joints/after market drive shafts/beefier axles/rock protection/ram assist steering/skid plates/383 TBI motor/2spd elec fan/remote coolers/rear discs/39.5 TSL's/fuel cell/winch/long travel shocks/bead locks/bumpers/rock sliders/loud exhaust and triple sticks, then you got some work to do.
Old 02-05-2007, 08:50 PM   #98
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
There only fenders anyways..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-06-2007, 06:33 AM   #99
Kurt,did you leave out cup holders?
Old 02-06-2007, 07:31 AM   #100
vtblazer
vtblazer's Avatar
Exactly!
I devised a way to duplicate them in about 10 minutes a side.
This way when I bend one and I'm pretty sure I will, I can throw the next one on without any issue or long term involved body work.
special-K, those, the off-road buckets/harness/console and toilet paper.
