01-19-2006, 07:50 PM | #76 |
GM ONLY BABY!!!
Re: Air Ride For Dummies
Check out NAPA, or autozone, they have lots of switches.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
02-05-2006, 02:12 PM | #77 |
Well, I finally got it all back together. Here are some pictures aired up and down. I would like to get the front down a little more so I am going to cut an inch or so off the bag cups. The ride is unbelievable, smooth like a cadi.
67 SWB |
02-05-2006, 02:13 PM | #78 |
A couple more.
67 SWB |
02-05-2006, 02:21 PM | #79 |
Looks good!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-05-2006, 03:30 PM | #80 | |
Do those front bag mounts just bolt in? Can someone PM me with the part number of that setup minus the bag?
02-05-2006, 03:34 PM | #81 |
the upper cup bolts in and the lower one sets in the lower spring pocket. as for part number just go to ***************** and click on bag cups
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
02-05-2006, 03:40 PM | #82 |
Is it really that easy? What years of Chevy are this easy? I might change what type of truck i am looking for.
02-05-2006, 04:05 PM | #83 | |
Happy to be here
02-05-2006, 04:08 PM | #84 |
Happy to be here
The bottom of the bag has a "cup" bolted to it that sits in the bottom of the spring pocket. It is not mounted, instead it "floats" in the cup. This prevents the bag from ever being over extended.
02-05-2006, 04:16 PM | #85 |
Happy to be here
Routing the air lines is time consuming and it's "very" critical that they are routed correctly. They must be ran through grommets, rubber hose, or wire loom at any point that they come in contact with anything. Any point of frisction can create a weak spot that will blow.
They can not be ran anywhere near the exhaust. Even the heat created by an exhaust leak can build up in an area sifficent enough to cause a line to blow. You can use copper line to prevent this, but it is much more time consuming to run.
02-07-2006, 05:51 PM | #86 |
MY EX DRIVES A BROOM
looks good
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
02-07-2006, 06:16 PM | #87 |
Jamie Hyneman is my twin
Looks great. Glad to hear you are so satisfied with ride and fit.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
02-09-2006, 01:51 PM | #88 |
Very nice upgrade! Look good! Now I need to find $900........
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
02-09-2006, 03:39 PM | #89 |
Never Done?
Glad to see you got it back on the road! How are those shocks working with the air ride set up?
02-09-2006, 06:23 PM | #90 |
LAIDOUT
Wink_tim, killer looking truck!
Hey what is your rise time from flat? And how many times can you do it before your compressor kicks on? |
02-09-2006, 06:34 PM | #91 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-09-2006, 07:08 PM | #92 | |
The ride is super smooth, I have no intentions of changing out the shocks. I would recomend them if you are going with bags. Like I mentioned before they are the ones you get with ECE's relocator kit.
67 SWB |
02-09-2006, 07:13 PM | #93 |
I just installed the relocator kit on my 69 Burb. It was very simple to install and it made a BIG difference in reducing the bounce in the rear. IMO this should be part of ART rear bag kit.
Rob
02-09-2006, 07:15 PM | #94 | |
It will rise to ride height in about 1 second, maximum lift in 2 to 3. I only have the single 5 gallon tank for now so the compressors will kick on by the second time I cycle the bags. I think I will add a 3 gallon tank on each side of the frame at the rear later. This would give me a total of 11 gallons, and I think I should be able to play with the switches a bit longer then.
67 SWB |
02-09-2006, 07:17 PM | #95 | |
I was suprised that for the cost it was not part of their kit. Did you stick with the air ride technologies shocks or use KYB's.
67 SWB |
02-09-2006, 08:02 PM | #96 |
wink_tim, now you need to change your sig from "4"/5" Drop" to "Bagged"
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
02-09-2006, 08:32 PM | #97 | |
Got it covered, thanks for the reminder.
67 SWB |
02-09-2006, 08:48 PM | #98 |
someday it will be done!
Looks great!The aired up pics....is that ride height or max lift?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
02-10-2006, 12:29 PM | #99 | |
67 SWB |
02-10-2006, 01:41 PM | #100 |
Never Done?
Any chance you could get part #'s off those shocks next time you're under there? I already have the relocation brackets and would like to see if I can find the shocks cheaper than ECE is asking. I would really appreciate it!
