Old 04-18-2008, 03:37 AM   #76
corn
Re: The birth of trailing arms
Ram Man, didnt you sell this project & buy an Impala? How's it coming along?...
corn is offline   Reply With Quote
Old 10-21-2008, 10:06 PM   #77
Ram-Man
Ram-Man's Avatar
I came back across this thread from someone else's post. I have been out of touch for about a year. I bought a 65 Impala, still have the truck in these pics and started a 69 GMC budget build. Still no trim on the bathroom door though and too many projects now.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 10-21-2008, 11:17 PM   #78
Shane
Shane's Avatar
Check out this one rack of truck arms from one of the Nextel Cup teams I visited last week ... it's no dad-gum wonder we can't find them in salvage yards anymore.
Shane is offline   Reply With Quote
Old 10-21-2008, 11:43 PM   #79
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
The other thing that's nice about building your own trailing arms is that you can get the exact pinion angle you want based on how low your truck is and get away from those wedges. Nice work sir!
prostreetC-10 is offline   Reply With Quote
Old 10-22-2008, 01:19 PM   #80
brad_man_72
the boat guy
brad_man_72's Avatar
reason i want to build my own is to get the axle back 1-2" TO CENTER WHEEL IN OPENING.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-22-2008, 02:52 PM   #81
SCOTI
SCOTI's Avatar
You don't have to build new arms to accomplish that. The trailing arm crossmember can be moved back the req'd amount or you can add spacers between the crossmember & the t-arm mounts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-08-2009, 12:29 PM   #82
ruggs
Ram-Man,
Very nice work. I,m starting to build a set myself but with one mod to your design. I think there should be a sleave welded in where the u-bolts pass thru to prevent any crushing of the tubing. Maybe you did this and I just didn't catch it. Anyway nice work...ruggs
ruggs is offline   Reply With Quote
Old 03-08-2009, 06:54 PM   #83
Ram-Man
Ram-Man's Avatar
Originally Posted by ruggs View Post
Ram-Man,
Thanks, Someone else thought that about the sleeve. Give this some thought there is a plate on the top and bottom of the arm IMO you would strip out the u-bolt before you would be able to crush that tubing.
Old 03-09-2009, 07:22 AM   #84
Tigman
COT arms are custom built since the early nineties! Laughlin , Ronnie Hopkins, Hutch Pagan all are building them. Also check out Boyce Industries in Ill. The team I worked for got one of the last runs from GM. The GM arms were the stuff . We done all kinds of trick stuff to them. The Boyce arms were tubular then split in half and welded back to back to resemble the GM arms!
Mark
Tigman is offline   Reply With Quote
Old 03-09-2009, 07:27 AM   #85
djracer
djracer's Avatar
Ram man if you want to build me a set to try I'll stress test them for you. I should have the 548 finished and installed before too long!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-26-2009, 03:35 PM   #86
ratrodder
ratrodder's Avatar
hey man i have some 2"x3" 1/8 wall tubing laying around. do you think it would be strong enough for this project? and how thick is you 3" flat plate?
ratrodder is offline   Reply With Quote
Old 03-26-2009, 06:15 PM   #87
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Thanks for the great thread, I think I will give this a go.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 03-27-2009, 11:49 AM   #88
shawn57nomad
shawn57nomad's Avatar
Ram-Man earlier you were talking about liability with the control arms/integrity of the welds. From what I know is that if you were to sell these you can put a clause in with the packaged item, trailing arms, and notify up front about there being no implied or expressed warranty and to use at your own risk. Kinda crappy sounding but I have a few friends that do it for a living and that is what some of the stuff says shorthand. Also, if you are near or have a close by tool and die joint they may be able to heat-treat the arms for you so you can get the integrity you were maybe worried about before. I know that when I get mine done, later down the road, they will go and get treated so that they will be better suitable for stress. After they are treated they will be more resistant to bending and breaking at the welds, more spring steel like. My 2 cents. project looks great and hope to be where you are on day. Me LIKEY!
FAST cars don't make power to the front wheels, THEY LIFT 'EM!
shawn57nomad is offline   Reply With Quote
Old 03-27-2009, 12:01 PM   #89
michael bustamante
michael bustamante's Avatar
question for you guys, What are the advantages of changing out the trailing arms if youre not actaully slamming the truck to the ground? Do trailing arms go bad? I know the bushigs wear out (like mine) but Ive seen quite a few people on here swap out the arms.
excuse my ignorance, but like the commercials on the cartoons on saturday say, "knowledge is power!"
1967custom
michael bustamante is offline   Reply With Quote
Old 03-27-2009, 12:20 PM   #90
lax54650
up here they rust out.
lax54650 is offline   Reply With Quote
Old 03-27-2009, 12:25 PM   #91
michael bustamante
I used to live in Milwaukee. I forget how they love flavoring the roads with salt in the winter,
1967custom
Old 03-27-2009, 02:22 PM   #92
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Looks like a fantastic job well done, i like the looks of that. Did you ase a stick welder or a mig.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 03-27-2009, 03:49 PM   #93
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Just saw this thread for the first time. Really nice build going on over there. I like the looks of the trailing arms. They turned out great. Nice work.
--Josh
Old 04-21-2010, 01:29 AM   #94
Racinaround
Racinaround's Avatar
I made some A Arms ones and used a bearing called a COM Bearing A Com10 i think was a 1/2" id for the bolt and a Com 12 was for a 3/4" ?
Anyway, then made a sleave to weld it the tubing and the bearing was heald in the sleave with a snap ring
Worked great! and sounds like it would work in the front of the truck arm.
I will look for some pics
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 02-10-2011, 01:37 PM   #95
blazerboy_4life
70Custom10
I know this is an old thread but this is a hell of an idea! And for the price!! Ive got some decent arms on the truck for now but I will be hopefully buying a welder sometime within the next month and maybe trying my hand at it soon. Just a question for your Ram-man. When you welded the plate on the top and bottom of the arm why didnt you weld all the way across? Why 3 shorter welds?
blazerboy_4life is offline   Reply With Quote
Old 02-10-2011, 04:38 PM   #96
Shaky
Six in a row makes it go...
Shaky's Avatar
Man, those are sweet. You should run without a bed just to show them off!
I'm no welder so I rescued my 3/4 ton arms mechanically and even that took longer than expected.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 02-10-2011, 06:04 PM   #97
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Wow those look CLEAN! Good job man!
John
1999 Toyota Tacoma 4x4
Old 02-11-2011, 10:05 PM   #98
blazerboy_4life
70Custom10
What kind of difference did it make in the way the truck handles?
Old 06-01-2011, 12:28 AM   #99
jmlcolorado
I'm getting ready to build some i think. I gotta move the axle forward a couple of inches (which could be done easier by moving the cross member) But my pinion is so far off its horrible!
I need to get the nose of the rear end to point up 3 degrees rather then down 6 degrees. I don't think shims will cut it
p.s. Nevermind my buddy in the picture. He thinks if hes in a few pictures, he can take credit for some of the build
jmlcolorado is offline   Reply With Quote
