12-05-2007, 12:20 AM | #76 |
Re: 67 C-30 Dually pickup build.
Couple more questions. I noticed you don't use a hydroboost, is the brake vacuum booster plumbed directly into the vacuum pump on the diesel? Any problems hooked up like that? Is the radiator and shroud from the diesel truck you got the motor from?
12-22-2007, 02:39 PM | #77 |
Texas Big Wig
Hey man, any updates yet ???
I got to thinking & if you must have side markers on your fenders, look at some of the side markers on a lot of these little sporty cars in your local parking lots What comes to mind for me, is some of the newer VW products have small oval side markers with clear lenses |
12-24-2007, 09:14 AM | #79 |
I have a radical idea!
The pic of the '71 with 6.2 in it above is not my truck. I'm going with hydroboost on mine.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
12-24-2007, 09:17 AM | #80 | |
01-24-2008, 10:57 AM | #82 |
Turn that blue one into 4dr crew cab and I think I just found my new tow rig!
Kevin LFD Inc. |
01-25-2008, 03:27 AM | #83 |
67_C-30,
Do you know where that 71 mounted his ac? On the 6.2L, the ac is mounted on the drivers side...If you run the hydroboost, you will not have enough room to mount the ac. Thanks, David |
01-25-2008, 02:25 PM | #84 | |
Texas Big Wig
The hydroboost master cylinder doesn't have a big booster behind it & doesn't stick out "that" far, & unless the engine was sunk back into the firewall really far I see no reason for there to be a clearance issue Now I may be incorrect in this, but I don't see you as being right in stating that it won't work either Last edited by Spray-Bomb; 01-25-2008 at 02:28 PM. |
01-26-2008, 01:42 AM | #85 |
Spray-Bomb,
I just put a 6.2 in my 1970 with hydroboost. The ac and hydroboost does not fit. I will post pictures on monday. David |
01-26-2008, 08:25 AM | #86 | |
Texas Big Wig
I just don't like people saying stuff won't work unless they know so |
01-26-2008, 12:31 PM | #87 | |
I'm interested in this as well. I thought it would fit too, but I haven't actually done it. Would a smaller AC compressor fit?
01-27-2008, 05:44 AM | #88 | |
Can you contact the owner of the previous pictured truck? Last edited by djw32; 01-27-2008 at 05:55 AM. |
01-27-2008, 02:10 PM | #89 |
I don't know who owns it. Its just a pic I found on some Diesel site. I can't remember where I found it. It was advertised as having A/C.
02-05-2008, 11:19 AM | #90 |
i was looking at your pics....wow...awesome.i am buliding a 1970 c-30 dually cab /chassis with factory 18" wheels.how do i join the one ton club.mine has a load rating of 16,000lbs.pretty heavy in its day.well i am glad to have met some one in the weird part of life.tim jr
02-09-2008, 04:06 AM | #91 |
Chevy nut
I still love your truck at stock height! It has that mean look to it stock. Its amazing truck. Anymore pics of progress?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
02-09-2008, 09:34 AM | #92 | |
I have also been playing around with some decals to go on the engine and under the hood. Detroit used to designate their engines by # of cylinders -Type of block - cubic inches per cylinder - and "T" designation if it were turbo charged. For example a 6V71 was a V6 engine with 426 cu in. With that being said, the 6.2 TD would be an 8V47-T if that designation was still used. I made up a few different designs of this decal, and another that would be a valve cover decal with all the service parts numbers. I think they'll look very cool on there and definitely different than anything anyone else has.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 07-20-2008 at 08:44 PM. |
02-09-2008, 08:50 PM | #93 |
Camaro Club
Will that motor bolt up to the same transmissions as the chevy v-8's. It sure looks like the same bolt pattern on the back of the block. Sorry for the dumb question i just know nothing about diesels
02-09-2008, 09:08 PM | #94 |
Yes, the transmission bell housing and motor mount pads are the exact same as a SBC. They are a direct bolt in. These engines put out a little over 400 ft lbs of torque with about 10 lbs of boost, and are very durable as long as you keep them cool. The other two 1 tons I've with this engine have averaged around 18 mpg, but will get 20+ all day long in 1/2 ton truck. My '84 K1500 gets around 25.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-09-2008 at 09:09 PM. |
02-11-2008, 11:41 AM | #95 |
high-Tech Red Neck
I have got to hand it to you, this is a very very cool truck you are building, I have long thought of exactally what you are doing. I have a 72 C-30 that I am working on right now. Somthing you might consider is installing a NV4500 as well, I will be posting pictures on a build thread here shortly, I think you might take a lot away from it.
Here is a pic of my Dually "The Boss Hoss" |
02-11-2008, 11:44 AM | #96 |
high-Tech Red Neck
Oh one more thing you might consider, this is a swap I have done in the past, if you find a 73-91 suburban in the junk yard, you can pull the fuel tank right out of it along with the frame cross members, these will bolt directly into your truck, some times with no drilling required, I am trying to remember, but I think that some of the suburbans even had 32 gallon tanks. you can also cut the fuel door out of a 90's model suburban, and graft it into your bed side, it looks really sweet, and the fuel door looks like it is suposed to be there.
02-13-2008, 11:46 AM | #97 |
Cool looking rig MrBeast!
02-14-2008, 10:55 AM | #98 |
high-Tech Red Neck
So any updates yet? I want to see that Diesel in your truck!
"He used to be a pretty nice feller, now he's a welder!" |
02-15-2008, 09:20 AM | #99 | |
FarmBoy.
wow, those are some impressive numbers for that mint green beast!
she should have plenty of balls to haul whatever you can fit in the bed. keep at 'er! -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
02-16-2008, 07:37 AM | #100 | |
Here is example. I really hope mine sounds as good!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 07-20-2008 at 09:13 PM. |
