Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 09-18-2007, 01:49 PM   #76
cysko9
MI '69
cysko9's Avatar
Re: another cheap electric fan build!
Did anyone ever give a definitive answer about using the temp sensor in the intake (for temp guage) instead of the one mounted in the side of the head?
Would this work?
1967 Chevy (Project Frankenstein)
1973 K5 Blazer
cysko9 is offline
Old 09-27-2007, 10:34 AM   #77
aitch
aitch's Avatar
Called my local dealer and they said that they could not sell me the CBG4F250 fan since it was a replacement for a recall. Could sell it to another dealer but not to an individual.
Anyone else have this problem? Know a way around it?
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline
Old 09-27-2007, 10:58 AM   #78
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Try a different dealer maybe. That or read the previous page, some of the guys are buying them online at www.moparpart.com.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline
Old 09-27-2007, 02:05 PM   #79
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Would this work?
Yes this will work. Not quite as accurate indication of engine temperature as the head but will still work fine. Just make sure your thermostat matches your fan switch sender.
IE: with a 180* thermostat use a sender with 185* on and 170* off.
Edit:
I reread you post and perhaps your just wanting to know if the intake water jacket will work for the temp gauge. This will work as well.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline
Old 09-27-2007, 10:37 PM   #80
BCOWANWHEELS
i found a thermostatic switch that controls the on ( 195 ) off at (180 )degrees . its a very heavy duty model used in off road equipment. has the correct thread size to screw into the head with no adapters and best of all it requires no relay to handle the 30 amps the fan draws at startup. also comes with wireing diagram and can be used with a manuel over-ride switch for driver controled off & on plus provision for a/c fan control. . if you need one or want pictures email me.
bob
bcowanwheels@aol.com
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline
Old 09-27-2007, 10:57 PM   #81
Arad68
Trucks N Tranzams
Arad68's Avatar
bob
I'd be interested if it was a different temperature range such as on at 180 and off at 160. It gets kinda hot in Las Vegas
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline
Old 09-27-2007, 11:33 PM   #82
BCOWANWHEELS
sorry it was 195 or 205 only for this machine so i got the 195 deg. i like on at 180 also but to do that you,ve got to run all the light duty parts and the relay. i like to keep it as simple as possible. less there is = lest to go wrong. you could always use the manuel switch for in town use.
Old 09-28-2007, 06:59 AM   #83
70c10
67-72 Addict!
70c10's Avatar
I JUST FITTED MY NEW JEEP FAN IN MY SCHROUD. wow it fits perfect..... anybody need the specs where to make the notch in the botton. it will save you a lot of time and aggravation on where to make it " just right " pm me if i can help with specs. and photos.
thanks for the great tip my 250 I 6 needed this bad especially in the winter when no fan is needed. i,am real anxious to do a fuel milage run to compare. bet it get better mpg.........
bob
Could you post the pics and specs in this thread so when Krue moves the post to FAQ everything stays together?. Just curious, did you guys feel any power increase at all???. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline
Old 09-28-2007, 07:46 AM   #84
DennyB
DennyB's Avatar
Is the fan with part number 52079528AB the one that this replaces. or will this one work too?
What is the over all diameter of this recall fan?
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline
Old 09-28-2007, 12:53 PM   #85
Scott68-93-97
Scott68-93-97's Avatar
My neighbor works for chrysler as a parts guy all the in stock ones were tagged for customers for the recall since each dealer only gets 5% of the vehicles they sold through that dealership so he ordered one for me I didn't have a problem, try another dealer or an aftermarket brand, they should be able to sell you whatever you want anyway I don't see why an individual cant get a part he's paying for even though it is a recall item, it might just be a inventory thing since they only receive 5% to keep on hand
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline
Old 09-29-2007, 01:14 AM   #86
Pont406
What are demensions for this fan? I tryed mark8 and it would not clear between water pump pulley and electric motor. Thanks
Pont406 is offline
Old 09-29-2007, 05:35 PM   #87
franks72
Junior Member
franks72's Avatar
71 RAT great job, Just ordered mine today,hope it fits in a big block shroud as nice as the sm blk shroud..By the way where do you run your truck at , atco ,englishtown??
franks72 is offline
Old 09-29-2007, 08:54 PM   #88
71Rat
ran out of money
71Rat's Avatar
franks 72: thank you, I actually picked up a big block shroud today so im also interested in seeing how it works (i guess the next step would be to buy a big block and install it). As far as what track I race at, Im from northern nj so when i get around to racing i race at island dragway, but I did race at englishtown twice, once with my 71 longbed and once with my dads srt8 300. did you go to the swap meet this weekend at e-town?
Modify everything, leave nothing alone!~
71Rat is offline
Old 09-29-2007, 09:49 PM   #89
1-tonmudder
Modern day Fred Sanford
1-tonmudder's Avatar
Has anyone done this on a 73 up truck/Blazer???
1-tonmudder is offline
Old 09-29-2007, 11:32 PM   #90
BCOWANWHEELS
19 inch openning is perfect steve-o.
how was mayberry days ?
Old 09-30-2007, 12:35 AM   #91
franks72
Junior Member
franks72's Avatar
71 RAT ..I didn't go to the swapmeat at englishtown had to work..
franks72 is offline
Old 09-30-2007, 10:21 AM   #92
1-tonmudder
Kinda overrated IMO.
Old 09-30-2007, 02:23 PM   #93
dan468
dan468's Avatar
amazing thread (like you didn't already know that). I'm curious about the shroud differeces between BBC and SBC as I didn't know there were any differences. I'm putting my truck together right now and I'm using a 454 with aluminum heads, roller blah blah etc. How do you think this fan will work around 500HP w/o towing? I'm also assembling the truck with a SBC shroud cuz I didn't know of any differences. Whew, any help is appreciated.
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline
Old 09-30-2007, 03:04 PM   #94
71Rat
ran out of money
71Rat's Avatar
i just measured my bb shroud and it measures a 21" hole over the sb 19 1/4 hole.... so the fans going to be a little smaller in it if used. no idea how it will work cooling a big block hopefully someone will chime in if they have tried it.
71Rat is offline
Old 10-01-2007, 12:24 PM   #95
Scott68-93-97
I have a sbc shroud with a 4 row bbc radiator I havent bolted it up cause I need to order the correct radiator mounts, I had to flaten out the 3 row mounts so the holes for the shroud are bent but the look like theyll work when I get the correct mounts, I just trecieved my fan the other day and Im ordering mounts within the next week so I'll let everyone know how it works out with the sbc shroud to bbc radiator
Old 10-01-2007, 03:11 PM   #96
dan468
dan468's Avatar
Are you using a BBC engine? What's the HP?
68 C-10
Build thread
dan468 is offline
Old 10-02-2007, 03:37 PM   #97
Scott68-93-97
No its a SBC but when I purchased my radiator a 4 row was only 5 more bucks so I bought it
Old 10-02-2007, 07:28 PM   #98
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Talking Re: another cheap electric fan build!
Like many others I ordered mine from Moparparts.com. They are a little slow on the uptake, but the fan arrived today brand new in the box for just under $55.00 with shipping.
screamin_c10 is offline
Old 10-03-2007, 10:54 AM   #99
DennyB
DennyB's Avatar
bob
We would love to have the dimensions and location for the notch in the bottom
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline
Old 10-08-2007, 10:35 AM   #100
Olden Days
Living In The Past
Olden Days's Avatar
I ordered one of those (without measuring first) for my 70 big block truck. Just so you know, if you have a big block with a "long pump" setup there is not enough clearance.
Olden Days is offline
