10-16-2008, 07:30 AM | #76 |
1961 crewcab
Re: 72 suburban "3drdwn"
now you're movin' !
so is that whole kit for a burb? and other than some cutting and drilling is it 99% bolt on? |
10-16-2008, 12:34 PM | #77 |
3DrDwn--the 'burb not the band
Well it's not advertised as being for the burb's but the frame difference is minimal and obviously it will work.
The kit as designed is 99% bolt on with the only welding being the lower saddle/bracket for the axle. That being said with my welding background I'm really seriously considering welding the main notches into place while leaving all of the other parts bolt on. My thinking for doing so have very little with the design of the kit but my own confidence in being able to do the welding. ( Nate designed the kit for the majority of do-it yourselfers who either aren't comfortable or capable of doing the welding) I know that I should never have a reason to remove the main notch pieces and by welding them in I can in effect seal the seams which should be helpful when the frame is powder coated. I have heard of "blowouts" in the powder process from air pockets. I'd prefer welding into place rather than trying to put it back together after powder. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
10-16-2008, 05:02 PM | #78 |
I'd weld it too. Not that it needs it, just 'cause you can
10-22-2008, 04:01 PM | #79 |
Just wanted to throw out a few more pics.
first one is everything on the axle mocked up to set pinion angle This is a close up of some tig filler rod that I cut up to shim the upper mount and to pull the lower mount as snug to the axle as possible. Beacause it's round it allows the axle to still rotate for pinion set-up but makes the fit snug enough that it will hold it's place without a stand under the yoke. a couple bumps with the dead blow and she's all set. Obviously the rod will be removed once the lower pad is fully tacked into place. just a rear shot. the pan hard bar is bolted to the frame side mount but the axle mount is just resting on the floor for now. pick of the angle guage I used to set-up my pinion. These last 2 have nothing to do with the burb ( I know, I have the attn. span of a 2year old with ADD). Just a couple of welding practice runs I did a few years ago for one of my certifications. tube on the right was run under a wire wheel hence no color. It's also good that they were just practice cause they both would've failed. Maybe tomorrow or the next day I'll have the pics up of everything bolted in and bags temp. plumbed. I want to set this puppy on the gound and see if my 20's are too smal so I can ask santa for some 22's Josh
10-22-2008, 04:11 PM | #80 |
LAIDOUT
Awesome! Jealous!
I realize now that my welder hasn't been warm for months, I need to find a new project... |
10-22-2008, 06:02 PM | #81 |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-22-2008, 06:05 PM | #82 |
OK so in very unlike me fashion I was able to knock the rest out TODAY!
More pics: This is the next item on the agenda. It is the EVIL factory 2-link x-memeber. Not sure how the final replacement will be but I'm definately pulling it tommorrow and putting something temp in so I can see this thing lay'd out. Josh
10-22-2008, 07:04 PM | #83 |
soon to be bagged64sub
Looks pretty sweet.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
10-23-2008, 06:45 PM | #84 |
Diggin it!
11-18-2008, 11:22 PM | #85 |
Just wanted to let all my friends and family from the board that follow my life here know that Isobella Jane was born Sat 11/15 @5:32PM. She's a healthy 9lbs. 3.3 Oz and scored a 9 on her APGAR. My wife has decided to give up her 1969 VW Beetle to Izzy so she's already got her own project and I hope to get the burb driving again for spring so the family can hit a few cruises in style.
Any of you with kids know how busy the first week can be but I'll try to have some pics posted in Genreal Discussion soon. Josh
11-18-2008, 11:40 PM | #86 |
Lookin good so far, keep it up.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
11-19-2008, 03:46 AM | #87 |
Surviving, one day at a time!
Congrats on the new addition. I have 6 of my own so I know what the next 18 years will be like. Burbs lookin sweet, I wish I could do the same to mine!
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver 74 swb,350,350,driver & future project "There's no such thing as a finished project" |
11-19-2008, 09:52 AM | #88 |
Tasty Cakes!
Congrats on the new baby! Burb's lookin sweet too!
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
11-19-2008, 10:25 AM | #89 |
No wonder you have a suburban..6 requires the room.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
11-19-2008, 10:52 AM | #90 |
Congrats man! Now you need that burb to get done
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-19-2008, 12:23 PM | #91 |
Congrats on the new baby!!!! I agree with everyone on how the burb is looking SICK!!! Great job!
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
11-22-2008, 03:14 AM | #92 |
congrats to you and your family!!!
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 |
11-22-2008, 05:12 PM | #93 |
1 thing at a time is progress.
Congrats, there's nothing like the feeling of becoming a new dad.
Alan
Philippians 2:14-16 |
01-03-2009, 01:33 AM | #94 |
Any up dates?
Kevin LFD Inc. |
01-06-2009, 03:18 AM | #95 |
Kevin,
I scored a couple new leftover drywall carts that work perfect for rolling the body around and finally got it in out of the snow but my doors and front clip are still outside . I'm trying to get back to this but between being a new dad and having not one but 3 customer rigs left in the shop over there supposed exit date has left me a little cramped. I appreciate your interest and I am feeling a little more motivated. I'll see about getting something done soon. If you feel like swinging by I'd let ya help me with a 4th door mod. Not really in my plans but you made it look sooo easy anyway thanks for the interest. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 Last edited by RunninLo; 01-06-2009 at 03:19 AM. Reason: I have a college degree why can't i spell?? |
01-06-2009, 11:08 PM | #96 |
Don't make me come back up there and motivate you. J/K I know it's hard having a new born in the house. Hope the family is well.
Alan
01-07-2009, 04:43 AM | #97 |
lookin good runninlo
01-28-2009, 12:19 PM | #98 | |
Mick |
01-28-2009, 03:01 PM | #99 |
updates?
01-28-2009, 10:44 PM | #100 |
Registered 1971 K5
The Burb is not sold, is it? We want updated pics to prove you still have it!
LOL............... |
