Old 11-18-2007, 08:14 AM   #76
jkade
jkade's Avatar
Re: How to: Ruin a perfectly good Blazer...
You got that thing back on the ground yet? I am having withdraws
jkade is offline   Reply With Quote
Old 11-18-2007, 09:15 AM   #77
gringoloco
A guy with a truck
gringoloco's Avatar
Me too. No real play time this week, but I got a few small things done. Hopefully be able to set it down this coming week...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-18-2007, 11:32 AM   #78
jkade
jkade's Avatar
I know how it goes, I haven't got to do anything this week either but spend money But I did get my vette front suspension
Old 11-18-2007, 04:51 PM   #79
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nice work, really jelous of those on here that have skills
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-18-2007, 06:48 PM   #80
gringoloco
A guy with a truck
gringoloco's Avatar
Sweet! Spending money is half the fun- finding boxes on the doorstep is the other...
Only one way to learn- dig in! What's the worst that could happen? How's your Blazer coming along?
-Chris
Old 11-21-2007, 06:22 PM   #81
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Please do us all a favor and ruin the blazer even more to look more bad azz than before you cant take it with ya and its only money so make the best of both...bad azz ride 4 sure..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-22-2007, 07:33 PM   #82
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the motivation. I'll keep 'ruining' it until I get sick of it, or someone makes me an offer I can't refuse...
Made a little progress on the passenger side notch. I won't bore you with the details- it is the same as the other one except for the studs I welded in for the rubber insulated clamps that will hold the fuel/brake lines. I still need to figure out where to mount the crossmember- it will have to wait until the suspension is mocked in place because it will also be the upper shock mount. Also got my shorter bumpstops in; they net about another 1/2"...
-Chris
Old 11-22-2007, 07:49 PM   #83
Frizzle Fry
Frizzle Fry's Avatar
Looking good. What are you planning for lower shock mounts?
Frizzle Fry is offline   Reply With Quote
Old 11-22-2007, 08:32 PM   #84
gringoloco
A guy with a truck
gringoloco's Avatar
Well.... I've been pondering this for a while. I even went so far as to order the suicidedoors under-axle units you used. They will not work for me with anything longer than about a 6" collapsed length shock- good luck finding those. I thought about just running the ECE relocation lowers, but with a 3" block, they will hang too low.
After racking my brain and looking at ideas, I decided that I will try using the stock lower mounts(had to dig them out of the junk pile) under the trailing arms. Hopefully, they will not hang too low, and I can get a good angle up to the crossmember. Only thing I'm worried about is if the shocks will clear the notches. I guess we'll see- suspension mock-up is scheduled for tomorrow...
-Chris
Old 11-22-2007, 10:41 PM   #85
Rokcrln
Rokcrln's Avatar
Looking good keep it going!
Kevin
LFD inc.
Rokcrln is offline   Reply With Quote
Old 11-22-2007, 10:46 PM   #86
Frizzle Fry
The reason I asked is because I am thinking about going to a longer shock and mounting the lowers on the arms. I may just weld a mount to the side of the arms. I am currently shock limited on my lift. Not too bad though.
Old 11-23-2007, 10:33 AM   #87
XXL
Seρor Member
XXL's Avatar
Monroe has a shock as follows--
Part# Top Bot Comp Ext Travel
5752 L1 L1 8.63 12.75 4.13
Maybe with a little pitch in the shock angle and you can get the coverage you need.
XXL is offline   Reply With Quote
Old 11-26-2007, 06:28 AM   #88
gringoloco
A guy with a truck
gringoloco's Avatar
Little forward progress. I got the axle back under it and bolted it to the trailing arms w/ just the 2" blocks- I still need to have some U-bolts made for the 3" block setup. Since my truck was originally a 4wd, the frame does not flare out in the rear for the upper spring mounts.
Before the step notch, I was using these air-over-leaf bolt on brackets from ART(slightly modified). Now, there is a big hole where they used to bolt to the frame, so I had to make them a little more permanent. I just whacked off the unneeded portion with my trusty angle grinder and made some gussets from the scraps of 3/16 plate from the notches.
Not much for in-progress pics though, I kinda got on a roll and forgot about the camera Once I finish the mount on the other side, she'll be back on her feet
-Chris
Old 11-26-2007, 09:21 AM   #89
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Looking good Chris!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 11-26-2007, 04:04 PM   #90
bagged74
its just $$$$$
bagged74's Avatar
lookin good.....now get it on the floor and lets see some pics.
bagged74 is offline   Reply With Quote
Old 11-27-2007, 05:37 AM   #91
gringoloco
A guy with a truck
gringoloco's Avatar
Ask and ye shall receive...
The Blazer is now holding itself up after being on jack stands for so long, but it will not go all the way down due to the inner bedsides- There is still more than 3" between the axle and the top of the notch when aired out...
-Chris
Old 11-27-2007, 05:47 AM   #92
gringoloco
A guy with a truck
gringoloco's Avatar
Sooo... I did what any self-respecting person would do: I hacked on my Blazer some more More cut off wheels and an air nibbler got the offending sheetmetal out of the way- now this beast is starting to look right...
There is still just under an inch between the axle and the notch. This will disappear when I get the 3" block in and the truck will drop another inch when aired-out. The front is sitting on the inners, but they will go away when the Dropmember goes in.
-Chris
Old 11-27-2007, 05:51 AM   #93
gringoloco
A guy with a truck
gringoloco's Avatar
I think I'm gonna have to do something about the trailer hitch...
-Chris
Old 11-27-2007, 06:36 AM   #94
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Nice...............
Grande Rojo is offline   Reply With Quote
Old 11-27-2007, 09:14 AM   #95
FRENCHBLUE72
PROJECT 7DEUCE
Looks good.......
MEMBER #6377
Project "7DEUCE"
Old 11-27-2007, 10:06 AM   #96
XXL
Seρor Member
XXL's Avatar
Lower the trailer?
Old 11-27-2007, 12:03 PM   #97
Frizzle Fry
geeeya!
Old 11-27-2007, 12:34 PM   #98
bagged74
its just $$$$$
bagged74's Avatar
me likey
Old 11-27-2007, 02:12 PM   #99
Rokcrln
Rokcrln's Avatar
I agree! Add a spark block
Kevin
LFD Inc.
Old 11-27-2007, 02:49 PM   #100
babyblueoval
babyblueoval's Avatar
Originally Posted by XXL View Post
Lower the trailer?
That's exactly what I did with my trailer.
I Dropped the fenders and put 60 series tires on it.
Gringo,
I'm planning on putting my hitch behind the license plate. Would that work for you?
Are there any legal issues towing that way since you wouldn't be able to see the plate when driving?
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
