Old 07-10-2009, 03:05 PM   #76
Kim57
Kim57's Avatar
Re: My 57 Pro Street
I welded the bolt to the end of the push rod and used the DOM tube to add strength to the new end.
Kim
Kim57 is offline   Reply With Quote
Old 07-10-2009, 05:19 PM   #77
GRIMSS
GRIMSS's Avatar
Nice mod.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 07-10-2009, 07:33 PM   #78
Kabwe
Certified Car Nut
Kabwe's Avatar
You are doing a great job on that truck Kim, keep up the great work.
Kabwe is offline   Reply With Quote
Old 07-11-2009, 11:00 PM   #79
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Nice mod on the hydroboost. Is that the total length of the rod you're going to use? I'm asking cause I have mine to do once I get the frame work done, but I'm thinking that the rod will need to be longer on mine.
Tri5
Tri5Nerd is offline   Reply With Quote
Old 07-12-2009, 10:32 PM   #80
Kim57
Kim57's Avatar
Tri5
Tri5
There will be a piece of DOM approximately 30" long connecting the pedal to the hydroboost unit. It will have a threaded insert welded into each end.
Kim
Old 07-16-2009, 10:57 AM   #81
Kim57
Kim57's Avatar
I did some work on the doors.
The driver door was missing two of the nuts on the top bracket.
I cut an access hole in the jamb so I could weld some new ones in.
Old 07-16-2009, 10:59 AM   #82
Kim57
Kim57's Avatar
Here it is with the new nuts and the access hole welded shut.
Old 07-16-2009, 11:05 AM   #83
Kim57
Kim57's Avatar
The passenger door had a little more work involved in it.
Thanks to some direction from Kabwe I was able to get it done.
The new lower panel didn't have the indentations in it that are on the original doors. On the side with the hinge I wasn't worried about it because it can't be seen and I'm not doing a restoration on the truck.
On the outside I was able to save the indentation so it would match the other door.
Old 07-16-2009, 11:07 AM   #84
Kim57
Kim57's Avatar
I had to modify the new hinge bracket because it was designed to fit around the indentation on the original door.
Old 07-16-2009, 11:10 AM   #85
Kim57
Kim57's Avatar
These pics show the finished repair.
Old 07-16-2009, 11:36 AM   #86
OrrieG
OrrieG's Avatar
Good work, I am so glad my doors are in good shape at those areas.
OrrieG is offline   Reply With Quote
Old 07-16-2009, 11:53 AM   #87
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My 57 Pro Street
Good work! Its coming along well! Makes the rest of us wanna get back to work on ours.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-16-2009, 12:43 PM   #88
Kabwe
Certified Car Nut
Kabwe's Avatar
Good job on the doors man, keep up the good work.
Old 07-16-2009, 12:56 PM   #89
Kim57
Kim57's Avatar
Thanks guys.
Kim
Old 07-18-2009, 11:49 AM   #90
CAL 58 GMC
CAL 58 GMC's Avatar
Nice job on the booster bracket.
CAL 58 GMC is offline   Reply With Quote
Old 07-18-2009, 12:10 PM   #91
57ToyBox
57ToyBox's Avatar
Nice wok on the push rod extension, very clean and professional looking.
BTW nicely documented build thread. Luv it
57ToyBox is offline   Reply With Quote
Old 09-22-2009, 10:17 AM   #92
Kim57
Kim57's Avatar
Time for some more up-dates.
I wasn't sure what I wanted to do with my dash after seeing what some of the other guys here were doing. I had already smoothed the entire dash and removed the opening for insturment cluster.
As I couldn't find a layout for the insturment cluster that I liked with the hump I decided to remove it.
I have to give a big thanks to Kabwe for making this possible.
I met him at the Brothers show this year and he was kind enough to supply me with the dash out of his truck.
These first pics are of what I had previously done to the dash.
Old 09-22-2009, 10:20 AM   #93
Kim57
Kim57's Avatar
These next pics show the cut out and the donor dash.
I cut a section from it that fit where my hump was and welded it in.
Old 09-22-2009, 10:25 AM   #94
Kim57
Kim57's Avatar
Heres what it looks like now. I also patched a section that I wasn't happy with from my previous work.
I now have the option of getting a hot rod bezel or just installing the insturments rite in the dash.
Thanks again Kabwe for your old dash.
Hope you guys enjoy the pics.
Kim
Old 09-22-2009, 11:49 AM   #95
my67chevytruck
Under Construction
my67chevytruck's Avatar
Great work Kim. Keep after it!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-22-2009, 12:16 PM   #96
Kabwe
Certified Car Nut
Kabwe's Avatar
Looks great, really smooth out. As far as your thank you, you are completely welcome, but you don't have to thank me, seeing you put it to good use is thanks enough. Great work Kim.
Thank you for sharing that mod, I think it fits your trucks theme.
Old 09-22-2009, 12:19 PM   #97
oregondunerz
Looks great! I like the idea of getting rid of the hump in the dash. Looks alot cleaner! Nice work...
oregondunerz is offline   Reply With Quote
Old 09-22-2009, 01:05 PM   #98
1Bad62Pro/Street
Nice........
Soon it will look like this!!!!!!!!!
Old 09-22-2009, 01:34 PM   #99
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice work! I like it!!
ChuckDriver is offline   Reply With Quote
Old 09-22-2009, 01:49 PM   #100
50adrod
50adrod's Avatar
Originally Posted by 1Bad62Pro/Street View Post
Nice........
got any pics of that engine setup? looks wild
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
