07-11-2008, 12:54 PM | #1 |
PITbut
Re: My build. Project Karma. 71 stepside.
Update.
Cab is back from the blasters. The transmission is at the rebuild shop. SHould have the motor in with headers on and trans in. Then i can get to epoxying everything and start working forward. |
07-11-2008, 01:30 PM | #2 |
On the fast track to nowhere..
How does it look
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
07-11-2008, 01:46 PM | #3 |
PITbut
07-11-2008, 02:12 PM | #4 |
OIC. Same here
07-13-2008, 12:19 AM | #5 |
Resident of Here
Still no pics of the "primered" avatar yet?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
07-14-2008, 12:36 AM | #6 |
PITbut
07-22-2008, 12:20 AM | #7 |
Did you figure out your transmission cross member yet?
-Joel |
07-22-2008, 01:04 AM | #8 |
nuts is all i gotta say. if i ever buy another one it will be done and ready to drive. i have done 2 blazers , 68 camaro and started on my 71 pro-street and im sick of projects. better you than me. looks awesome so far. i wish ya luck.
07-22-2008, 12:49 PM | #9 | |
PITbut
I figure i will only build one of these bad boys, so i dont plan on doing another one. |
08-05-2008, 01:17 PM | #10 |
PITbut
Updates. I have been working on it pretty much every weekend.. Its tough when you have 4 kids. And two of them are under 3 and want to HELP. ahaha... I got the motor installed, crossmember drilled for exhaust, new transmission xmember i made and the headers installed... I just sent my driveline out to have it custom fit for my truck. First price quote was 450 bucks and i found a place that would do it for 230.. YAAY...
here are some pics. This is the original driveshaft and how close it comes to the th400. They are going to shorten my driveshaft and add a snub nose kinda like a 4x4 setup... Here is my engine ready for the tranny. Here is the trans on, now the motor is ready to go in its home. Here we are installed. |
08-05-2008, 01:22 PM | #11 |
PITbut
This is the cab after the blasters.... Not many suprises in there. Some questions i have is theres little pin holes here and there... Can i just weld up those little holes and be good, or should i cut it out and weld in new metal??
Cab' Heres the area im concerned about... THis is a previous owners work. This whole area was smooth and really well done with body work. I dont even know how im going to tackle this. I might cut that WHOLE section out, or just go to work with hammer and dolly then remud it.. I dont know. This is the drivers side rust i have to fix. This is the passenger side area that i have already finished... Is there any side affect to completely welding in the rocker?? I mean the whole thing so there is NO line where the cab corner and rocker meet? |
08-05-2008, 01:41 PM | #12 |
PITbut
Heres the crossmember where i put the holes.
Me figuring out my tranny crossmember. I just ended up using a 2x4 of metal and some bolts.. Works great.. Just trying to get the right level. This is how close the oil pan is to crossmember.. kinda close.... IM going to reroute the brake lines, or will they be ok where they are? More updates to come. |
08-05-2008, 01:44 PM | #13 | |
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011 Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
08-05-2008, 02:57 PM | #14 |
Project: years too late.
coooool! watching this build closly.
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here. |
08-05-2008, 03:05 PM | #15 | |
PITbut
Cool... Next step after the exhaust is diggin in to the drivers side of the vehicle... Then i will epoxy the whole thing and mount it back up...Im thinking of doing my engine bay in a semi flat black color. Havent decided if i wanted to color match it... Some good news i found is that my kickdown switch for my transmission is a direct fit. I have an 81 donor truck where i got the motor and trans out of and the throttle pedal assembley is IDENTICAL to my 71 except i didnt have a kickdown switch.. that was pretty neat. |
08-05-2008, 03:09 PM | #16 |
Thats what I was talking about also.
08-05-2008, 03:41 PM | #17 |
PITbut
08-05-2008, 03:45 PM | #18 |
There shouldn't be a problem with that lyrikz. Should make it pretty solid. I can tell you though that I had mine mudded in these area and and they did crack from flex of the cab. Your weld should hold just fine.
Nice build by the way, been watching. Question I been meaning to ask you, is where you got your glass fenders and how much? Are you satisfied with them? PM me. Eric Last edited by estig70; 08-05-2008 at 03:47 PM. |
08-08-2008, 12:23 AM | #19 |
BlahBlahBlah
Hey I think you forgot to install this piece. =)
08-08-2008, 09:39 AM | #20 |
PITbut
08-18-2008, 02:15 PM | #21 |
Resident of Here
You still havent posted the pic that your avatar is...
08-18-2008, 02:34 PM | #22 |
PITbut
08-18-2008, 07:13 PM | #23 |
Nice Center Lines. I love those wheels. Lookin a little too tall tho. lol. But looks good non the less.
1971 Chevy C10 LWB Shop Truck 1984 Chevy C30 Dually LWB Tow Pig 1985 Chevy K5 Blazer |
08-18-2008, 07:43 PM | #24 |
Haha yea. Theres no way it'll lay with a wheel that big. But will deff look sex anyways. Hurry up and finish it so I can see it layed out.
08-18-2008, 07:49 PM | #25 |
PITbut
Im just putting a c notch in the rear frame.. Im not layin out totally in the rear. The wheel fits ALLLLLLL the way to the top of the fender. ahaha SO it will go as low as it wants to.. I figure i have probably 8 inches or so before the c notch touches the axle??? I will be doing that notch here next... Need to get the cab back on, and the bed BACK off. ahaha...
