09-27-2010, 11:57 AM | #76 |
This guy has got to be stopped
Re: 67/72 K20 Rusty build
Hey 67mater, when you swapped to the lockouts, did you just have to change the internals or the whole snout? Does the warn setup fit right into the full-time snout?
J P Evers 1970 4x4 LWB project: http://67-72chevytrucks.com/vboard/s...d.php?t=415134 |
09-27-2010, 12:13 PM | #77 |
That manual hubs are super easy to install. They go right in where the full time gear was. Remove cover, two snap rings, gear and spring and then install warn hub, new snap ring and screw the cap on. I still have the original 67 Rockwell part time case so these were all I needed.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
09-27-2010, 12:25 PM | #78 |
thanks for the info. I have a set of original 3/4 turn (blue) warn hubs on my donor truck, and the full time hubs on my 70. I plan on swapping them soon. I have the 203 case - but its been converted. I'm keeping my eyes open for a cheap 205 though...
09-27-2010, 12:29 PM | #79 |
I have a spare 205 and a rebuild kit to go with. Its currently in pieces but I have everything and Could reassemble. It comes with a 4 speed adaptor. Shoot me a pm and whether u would want it apart or assembled
09-27-2010, 01:09 PM | #80 |
Thanks for the offer, but I don't see myself making the 5+ hour (each way) drive anytime soon. If I find one real cheap, and local, just wanting to come home with me, I'd probably bring it home and put it near a corner (the corners are full) of my shop where it would wait until I need it for this or another project. I'll probably kick this 203 around until (IF) it breaks... I don't plan on using the my 70 a whole lot... I have a 98 RAM parts getter, a couple 4 cyl cars for drivers, and a 77 dodge 3/4ton 4x4 with a 440 that I use to pull a trailer and haul wood. The 70 is a hobby... It may replace some of the 77 dodge's duties depending on how dependable and stout it turns out to be...
10-06-2010, 08:43 PM | #81 |
Nice work so far. Just wondering where you got the patch for the corner of the cab where the cowl and fender bolt. I noticed the keyparts sticker but could not find the part. Thanks.
10-06-2010, 10:23 PM | #82 |
Those were scraps from other pieces. Don't Think anyone makes that yet. Its an area that will never he seen so I just cut out that bad and shaped the pieces so the fender and cowl fit tightly
10-20-2010, 11:07 AM | #83 |
Its been two weeks... Anything new with the truck?
10-26-2010, 09:36 PM | #84 |
Been finishing up rust repair on a friends 67 cab. Turning out way better than mine but forgot How time consuming it is. Have Got my drivers door ready for paint. Hope to have it on thus weekend and ill finally have a one color truck! I'm running out of warm weather so ill be running the manual transfer another winter.
10-26-2010, 09:54 PM | #85 |
10-26-2010, 09:59 PM | #86 |
And a gratuitous truck shot plus some cab work on my friends 67
10-26-2010, 10:09 PM | #87 |
looking good bro
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
10-26-2010, 10:19 PM | #88 |
Glad to see some updates... even if they're not on your truck! Looks like nice work! Your truck looks tough! Hot rod black and stainless - looks cool... like my Satellite!
Its about time to hang that plow... aint it?
10-26-2010, 11:04 PM | #89 |
6>8 Plugless........
Nice progress. Your truck is looking good!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-19-2010, 06:53 PM | #90 |
12-04-2010, 03:28 PM | #91 |
Ok guys, lots of things changing here. I found and accepted a new job in Chicago (downer's Grove). I just had my first week and things going great. Spent last two weeks painting my old house before it got cold. I did get my new driver's door finished and installed, so the truck is FINALLY all black. I also nearly finished my friend's cab, including the below gas hole fill. I also assembled my nova and got it moved to the new place in Chicago (my parents are still trying to sell their house in Elgin, so I'm renting it, which means 3 stall garage!!). At this point the truck will remain unchanged at least until the nova is driveable. I would consider selling the truck if someone was interested, but if I have it when the nova is done, it''ll probably get blown back apart, painted right, auto trans/overdrive/np205 swapped, and maybe EFI. Anyways, here's some pics!
02-28-2011, 11:26 PM | #92 |
Need some help here. I've sold my nova, which sucks but it's ready for paint and thats a big chunk of change that I couldnt justify. So, I am back to the truck but lacking ALL motivation to either sell, or make changes to it. Now that I'm in chicago, i need an automatic with overdrive, AC and more like a stock lift if I want to drive it. I have a 700r4 and a divorced np205, which would be nice. I'll also have a rebuild '03 5.3 EFI motor and harness from the nova project that could make him fuel injected. AC then wouldnt be a crazy change, and a stock suspension could be sourced, and I already have some 16" wheals with 31" tires.
However, that's some people's WHOLE project, and I already built this one once as a big bad 4x4. So, do I cut bait and sell for what I can, or do I sink even more money and time (which is the biggest hurdle) into essentially a complete change over. I guess I know exactly what I'm dealing with on my truck, but for all the changes, I could sell him for what he is, and buy another near dead truck and build it. HELP!!
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro Last edited by 67mater; 08-27-2011 at 08:56 AM. |
08-27-2011, 08:57 AM | #93 |
I suppose too there may be people out there with projects that would trade fior a running driving truck, no?
08-29-2011, 07:53 PM | #94 |
but he does fit in the garage nicely...
09-10-2011, 05:08 PM | #95 |
10-30-2011, 12:48 PM | #96 |
well, I still don't know whats gonna happen, but I did pick up some parts to go back to stock height. also sold the 35s, some buckets seats I had for the nova, and took 800 pounds of parts to scrap...
10-30-2011, 05:22 PM | #97 |
It is tough when your life changes and the outlook on the project changes. Mine has done several times on my 70 and she still lies there. At least you can use yours while you think about it. I am driving an 83 at the moment and stealing from the 70 to keep it running, so that gives the run down feeling about the 70 too. Hang in there. Enjoy what you can of the truck while you get settled in the new area.
10-31-2011, 08:01 PM | #98 |
Good luck with your truck. Only thing I could suggst is to either get another driver, or buy the parts to make your truck the way you want it. Not much help, I know.
11-05-2011, 09:49 AM | #99 |
The big question is what time I'm going to have. Baby in january, and have an offer in on a house. I think I'm going to keep the truck and just work on it when I can. I've sold everything else (nova, and every other garage related distraction). So let me start my wish list;
700r4 and divorced np205 (have big parts including auto column) need rebuild and little things like tv cable, shift linkage, new driveshafts, and likely custom mounts stock suspension (gotta fit in parking deck to be a daily driver candidate). just picked up front leaves/mounts with sway bar and stock drag link. need 3/4 ton rear leaves, stock length shocks, and some new tires (sold the 35"s). The other big wish all along was the 67 chevyu front end, which I already made happen (and he looks sweet everytime I open the garage to go in the house; makes parking outside a lot easier!). So that's one of the big three done already. I think too the suspension swap will pay for itself (minus tires) as I can sell all my lift parts for more than stock parts cost. I need new master, booster, front calipers, and because I dont' like how I did them to start, probably rerouted brake lines. There are exhaust leaks, the bed needs rhino lined, the carpet needs put it, blah blah blah. i think because it's getting cold I'm going to leave him as is (drivable) until I have a new house. Once relocated though, I'll probably start taking him apart........again....... oh yeah, and my new DD/parts hauler:
11-15-2011, 09:39 PM | #100 |
finally got new clips for the grill hoops. painted them on both sides before I put them in (hopefully someone thanks me for that some day...) and got bezels and hoops painted and installed.
