10-11-2008, 09:41 PM | #76 |
Re: LFD's 4dr Burb Build
I got allot done today and would have finished the 4th door but I ran out of gas for my TIG. I started off by adding the second skin to the front of the door edge. This is to add strength to the front edge just like the factory did. Since mine did not have the factory door edge I had to make it this way. I first welded the edge all the way up the door making sure not to warp anything. Then I added an 1/8" Tig rod to the edge of that to give a thicker profile so their is more for the paint to stick to and to give a bit more metal to to scribe for my door gap. Then I sprayed some blue die on the edge of the door so when I scribed my 3/16" gap it would be allot easier to see and grind. After that was done I started welding up the inner door panel up until I ran out of welding gas.
Kevin LFD Inc. |
10-11-2008, 10:02 PM | #77 |
Luv the Crewcabs
Looking Good, Between you , Hart & Frizz You Have Set the Bar Pretty High for any one Even Thinking of a Burb Build
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
10-11-2008, 10:28 PM | #78 |
Your thread is very inspirational. I learn a lot by watching others. My gaps on my truck are all over the place. Im trying not to look at them for the moment maybee they will correct themselves... lol. just kidding. Keep up the good work and keep the pictures coming.
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
10-12-2008, 12:19 AM | #79 |
10-12-2008, 06:39 PM | #80 |
GEARHEAD
The part I'm waiting to see is a pancaked roof. A beaded one would be very slick looking.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
10-12-2008, 09:14 PM | #81 |
10-12-2008, 11:53 PM | #82 |
BlahBlahBlah
Like everyone else, I love your work. Its fun to watch. I really like your attitude about learning.
Ive read about Laz's classes a few times. I would like to take one someday. I wish he was closer. So did everyone in your class build the same things? I see you have a good start on a 34 roadster. Ive seen the Willy's coupe they built and I heard they built a Cobra in a class too. I wish I was a little more flush right now. I would love to have the burb or the truck. Have you posted either of these for sale yet? Last edited by CG; 10-12-2008 at 11:53 PM. |
10-13-2008, 06:32 AM | #83 | |
Kevin LFD Inc. |
10-13-2008, 11:42 AM | #84 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-13-2008, 01:54 PM | #85 | |
Kevin LFD Inc. |
10-13-2008, 03:21 PM | #86 |
I hear you on the little ones vs. available time. I have 1 year old twin boys and I'm not in the shop nearly as much as I'd like to be now.
It would still be really cool rolling up to pick up a customer's project pulling a trailer with a bagged, 4 door burb. Plus, you'll have a lot more room than you would in an older burb/panel/pickup. You need wheelbase and weight to pull your trailer, and the burb has both of those going for it.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
10-13-2008, 06:57 PM | #87 | |
Kevin LFD Inc. |
10-14-2008, 12:46 PM | #88 |
As long as you keep getting new projects and posting these inspirational build threads I personally don't care what you actually drive. I just love seeing your work. Between you, Frizzle Fry and a close friend who said "Its only metal, shape it how YOU want it" I've gained the confidence (or lack of sanity) to customize my Blazer. Now if I can just convince my better half it’s a good use of funds.
10-14-2008, 04:15 PM | #89 | |
Now your friend is right and here is one more for ya. Their are only 5 things you can do with steel! 1) cut 2) bend 3)weld 4) shrink 5) stretch Once you have a god grasp on those 5 things their is nothing that can not be done with it! Kevin LFD Inc. |
10-14-2008, 04:24 PM | #90 | |
Life, Be In It.....
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
10-14-2008, 04:26 PM | #91 |
I have been asked a few times in PM's for other pics of the burb so here are 1 or 2! It has all the glass except the rear side's and the windshield. New body mounts and the tub has been cleaned and undercoated. New trailing arm hardware and I assume bushings as well. And the best part is zero rust that I have been able to find. The driver rocker was replaced by a PO but they did a great job, it took me a bit of looking before I even saw it had been done.
The rear door hard ware has been rebuilt and works like new! Kevin LFD Inc. |
10-14-2008, 04:33 PM | #92 |
The white stuff is the weld thru primmer I used on the 4th rocker. Kevin LFD Inc. |
10-14-2008, 04:39 PM | #93 |
The last few.
Kevin LFD Inc. |
10-14-2008, 06:05 PM | #94 |
On the fast track to nowhere..
Just read the whole thing, I'm tired just thinking about all of those welds Looks nice!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
10-14-2008, 10:10 PM | #95 |
love the burb
truckjunkie
truck junkie |
10-16-2008, 01:44 AM | #96 |
Damn that thing is clean! What a great stating point that will be.
10-16-2008, 06:13 AM | #97 | |
Kevin LFD Inc. Last edited by Rokcrln; 10-16-2008 at 06:13 AM. |
10-17-2008, 10:07 AM | #98 |
Questoin:
How did you bend the flange that's right next to the drip rail over without pushing it in? In other words, how did you get such a nice brake there? Last edited by Frizzle Fry; 10-17-2008 at 10:14 PM. |
10-17-2008, 08:52 PM | #99 |
With the flat sharp end of one of my dolly's and very light taps working back and forth until it was just right. I was surprised how easy it ended up being and how factory it looks.
Well I should get almost a full weekend to work on and finish up the 4th door so I hope by Sunday to be able to put up some red and white price sign's very soon! Kevin LFD Inc. Last edited by Rokcrln; 10-17-2008 at 08:59 PM. |
10-19-2008, 03:19 PM | #100 |
Finished!! Well at least the 4th door is now done. I still need to put the front end back on before it goes up for sale. Kevin LFD Inc. |
