10-23-2009, 12:13 PM | #76 |
Wide Eyed User
Re: 63 Short Fleet Build
Love those doors!! What seats did you put in it?
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441 |
10-23-2009, 06:02 PM | #77 |
Thanks for all the feedback guys! Yes teh wheels are Coys C5's 22" and the seats are out of a 01 Silverado.
10-23-2009, 11:06 PM | #78 |
10-24-2009, 12:57 AM | #79 |
60-66 Nut
I'm anxious to see what you come up with on the windows. I have a couple of ideas, but never any time to work on them. FrizzleFry was working on the '60-'63 one piece windows, but I don't think he got them finished.
10-26-2009, 03:10 AM | #80 |
Man your truck looks killer! Nice work!
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
11-21-2009, 01:11 PM | #81 |
Headers! These are the Pacesetter headers. They fit well but I do need to clearance one spot on the driver side by the crossmember. Full length and they don't hang below the frame.
11-22-2009, 04:05 PM | #82 |
Sick!
12-14-2009, 11:38 PM | #83 |
Great work. Trucks looking awesome. Subscribed
12-14-2009, 11:46 PM | #84 |
Easy Does It
SWEEET truck!!! are you happy with the shaved drip rail? I was thinking of doing it myself, but was not sure about water leaking in through the doors?? also where did you get the frame-suspension products? thanks
12-15-2009, 12:59 AM | #85 |
Porterbuilt Streetrods @ www.dropmember.com
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-15-2009 at 01:02 AM. |
01-28-2010, 12:49 AM | #86 | |
Also what year were the trunions/lower pivots you used? I like your idea would like to use it |
01-28-2010, 12:32 PM | #87 |
Mar-K parts are:
102837 for the tailgate links and 100266 for the latch kit. I got the trunions off of a '90s *cough* ford *cough* After putting on the link kit, i had the thought in retrospect that i should have got the modern cable style link but the Mar-k parts did go in well. |
01-28-2010, 03:23 PM | #88 | |
01-28-2010, 08:04 PM | #89 |
Ok, Here is my write up on the one piece power window conversion.
video here: http://67-72chevytrucks.com/vboard/s...d.php?t=382369 I would review this first: http://www.webrodder.com/article.php?AID=286&SID=7 It is what I used as a guide. First, I bought the windows from Vintage Glass in Atlanta. They have a website but no products listed at this time. I just called for the glass. Their kit comes with felts but i am experimenting with a couple different types other than theirs to see which fit the best. Next, I bought the power window kit from specialtypowerwindows.com. Part number 5559-2cvr. It is important to get this kit because it is what allows the back of the window to tilt as it goes up and down. I did make one mod to the assembly which i will detail below. I also got a variety of 1/4 20 hardware and some spacers and some springs from Ace Hardware. Remove the old vent windows and manual regulators. There are a couple tabs in the forward top of the window frame area that I removed with a dremel tool so I'd have room for the window felts. Then install the guides. I had to space out my rear guide because of my suicide doors about an inch on the bottom. It shouldn't affect the travel of the kit to leave them stock though. The SPW kit comes with a front guide which you have to figure out where to put. I simply installed mine straight down from the bottom edge of the window and tried to keep it paralleled with the rear guide. Here is where I used the Ace Hardware spacers and bolts that I bought. To secure the top of the forward guide I used the original bracket that held in the vent window and screwed it to the guide: Install you felts now. The mod I made to the regulator was to add an "L" shaped bracket between the regulator and glass mount piece to attach a spring to. This assures that the back of the window drops immediately when you power the window down to avoid any binding.: Next install the regulator. I drilled the bolt hole 14" from the back edge of the door. It should be close to the center. I hung it parralell to the tracks and secured it at the middle and bottom as well. Next mount your glass in the channel as the first link described. Make sure you've trimmed it so the channel won't catch on your felts. Then install you glass in the door. I would recommend having power to the unit and a switch wired up so you can move it up and down as you install it to reach the nuts on the track. The install went quite a bit easier than i was afraid of. I don't know if you'll be able to use the original inner trim pieces after this install but mine are going to be custom anyway. I'd be happy to answer any other questions anybody thinks of. |
01-28-2010, 08:18 PM | #90 | |
01-29-2010, 07:24 PM | #91 |
Very clean truck man...really looking good...screw this, its been way too long since I have touched my project! Im heading to my shop to get some work done on my 63...
-wes |
01-29-2010, 07:35 PM | #92 |
Registerd User
Looking real good.
02-01-2010, 05:43 PM | #93 |
very cool truck
02-02-2010, 04:46 PM | #94 |
I'M TRUCK CRAZY!
awesome!!!!
03-14-2010, 02:01 AM | #95 |
60-66 Nut
Any updates on this awesome build?
03-14-2010, 11:28 AM | #96 |
No major updates for now...I've been working a lot which keeps me away from home and the garage. I have been amassing lots of parts though so as soon as I can get some time I should be able to get some progress made!
03-14-2010, 03:51 PM | #97 |
Sunburst C10!!!
are those for an f body?
Gage 1967 C10 Shortbed Stepside |
03-14-2010, 05:54 PM | #98 |
Yes, F-body headers. I believe there is a vendor on the site that sells them:
http://67-72chevytrucks.com/vboard/s...d.php?t=383663 |
03-23-2010, 07:05 PM | #99 |
Check The Champ, Demonstrator
Very nice.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
04-11-2010, 07:14 PM | #100 |
