Old 03-02-2013, 07:52 PM   #76
SNEAKYPETE
Re: Project Boosted
Here are a few more progress pics, I am getting alot of body flex and squeeks with the new suspension mods so the plan is a full tube structure and removable rollcage to eliminate flex and make me legal at dragstrip, here a few pics, the plan is to cut out rockerboxes and tie all mounts to the frame, modify trailing arms into an adjustable 4link setup. There will be alot more triangulation in structure and another lower door bar, rollcage will be easily bolted in for a quick trip to the strip.
SNEAKYPETE is offline   Reply With Quote
Old 03-04-2013, 11:28 AM   #77
fxdxharley
Just a nother gear head
fxdxharley's Avatar
Re: Project Boosted
Im wanting to put the t56 in my blazer. what position is your shifer in? what did you use for a cross member? and any more info on your hydro clutch set up would be much appreciated. Sweet jimmy too!!
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 03-04-2013, 09:48 PM   #78
SNEAKYPETE
Re: Project Boosted
My shifter is in the rear location and i built my own crossmember bolted solid to trans and is bushing mounted at framerails. It has a stock internal slave cylinder and i installed a hydrualic master and a stock pedal mated to it.
Old 03-06-2013, 10:16 AM   #79
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Project Boosted
Have you read the NHRA rulebook? Its my understanding that all cages on full frame cars must be weld in, no removable or bolt in. Thats why mine is welded to the frame. Do you have a tech inspector near you?
Tom Vogel is offline   Reply With Quote
