Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 07-12-2011, 06:49 PM   #76
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Do's/Don'ts of Engine Cleaning (Tell us your experiences...)
Originally Posted by jimmyballpeen View Post
Does simple green or purple power take off firewall markings? I am going to clean 40 years of oil off my engine bay and would like to keep the firewall markings
I tried to not spray on the firewall markings, but let's see if anyone has any experience with this...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-12-2011, 08:07 PM   #77
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I believe it does I took mine off
I wish I had a pic or something to put them back on, what did they stand for anyway?
John
1999 Toyota Tacoma 4x4
Old 10-07-2011, 02:14 PM   #78
theastronaut
theastronaut's Avatar
Here's my tip, I found this one out through personal experience. After spending many hours detailing the engine compartment in my car, I decided I'd finish it off with a spray it of quick detailer and wipe it down with a microfiber towel to get the dust off from it's first drive since the engine swap. Well, I bought Quick Detailer and Spray on Wax in nearly identical bottles, and guess which one I grabbed? Yep, the Spray on Wax. Now I've got a ton of white specs all in the nooks and crevices that are unreachable. The engine was slightly warm so the wax dried pretty quickly before I could wipe it all off. So, check your bottles before you spray...
theastronaut is offline   Reply With Quote
Old 10-10-2012, 08:04 AM   #79
JBerno
JBerno's Avatar
So is it better to have the engine warm before applying the simple green (or anything else)? it seems like this should be the case but just want to confirm.
72' CST K5 Blazer
JBerno is offline   Reply With Quote
Old 11-19-2012, 04:03 AM   #80
HybridK
HybridK's Avatar
I've got a power steering pump that spewed all over the place because it got over-filled. I'm not trying to show it or anything, but I would like to get the big stuff off to keep it from being an eye sore. Will it be possible to soak it in simple green for a while and pressure wash it off? I'm going to be commuting with this truck when I get home from asscrackistan and won't have the time to tear it apart. What are your thoughts?
1972 K10, 1 Ton Suspension, 420hp SBC, SM465, NP205, 10.5" FF Rear, Dana 44 front. Daily Driver
HybridK is offline   Reply With Quote
Old 02-21-2013, 04:23 PM   #81
Stickman
Stickman's Avatar
Originally Posted by jcsbrat View Post
DUNNEZ this stuff is AWESOME!!!!! Its A CONCENTRATE and you use straight on or dilute with water for different applications. My favorite part is it smells like cherry and is non-toxic, like you could take a bid swig and not worry about a thing. I personally have used it to clean oil off a motor block, degrease a commercial used deepfryer, use to clean the greasy floor, ink out of clothing, food stains out of a carpet and to clean windows. I LOVE THIS STUFF. And its pretty cheap. Dont be afraid to haggle with them.
X2 this stuff is great,I tried this cleaner on jcsbrat recommendation and it is awesome. I'm cleaning a greasy engine with it now and it is working great. The best thing is it the smell. I can't stand the smell of Simple Green but this stuff is almost odorless .
dunnez.com
Stickman is offline   Reply With Quote
Old 02-21-2013, 05:11 PM   #82
LEEVON
LEEVON's Avatar
I have a cautionary tale. I had an engine out, on a stand. I degresed it pretty well, but it had aluminum heads and some paint flaking on the block. I decided to plug all of the exhaust and intake holes real well and lightly hit the trouble spots with the soda blaster. By the way, wal-mart plastic sacks make perfect plugs especially if you cram them in tight. The soda blaster did a nice job, took off some of the stubborn stuff and it came out real shiny. The problem came later when I started re-assembly. The first couple of accessory bolts wouldn't thread, then I started checking all of the bosses and most wouldn't thread. Turns out the soda went into holes, where there was still some moisture from cleaning and it turned hard as a rock. I had to chase many of the holes, and clean them out with a bottle brush. Still had issues and had to oil most of the bolts as well.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-22-2013, 11:05 AM   #83
midniteblues
midniteblues's Avatar
If you have belt squeal, you can very carefully take a scotchbrite pad and lightly hold it to the inside of the belt while the engine is running. I can not stress the importance of being careful doing this so you dont get your hand caught in the pulleys/and/or mechanical fan. All your tring to do is deglaze the belt some. It might just save you from buying new belts if the old ones are still decent.[/QUOTE]
this is crazy!dont ever stick your fingers in/on a running belt unless you dont want them!
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-28-2013, 12:37 AM   #84
ls1nova71
ls1nova71's Avatar
Anybody have any ideas on how to make a cast aluminum alternator look nice again? My last truck I actually bought a reman alternator just so it would look nice, worked, but not really the cheapest route.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-28-2013, 12:51 AM   #85
rcrahn
rcrahn's Avatar
Nothing better than steam for cleaning anything with caked on grease and oil. Find a steam cleaner near you and pay them (probably $40 but worth it) to do the engine compartment top to bottom. You'll be amazed....
rcrahn is offline   Reply With Quote
Old 03-02-2013, 07:18 AM   #86
richards72chevy
richards72chevy's Avatar
What do you guys think about pressure washing an engine thats out and may not be started for awhile?Exhaust manifolds intake carb distrubitor is all there.Im just concerened about water getting in to the cylinder walls and pistons and causing damage.Should i just wait until its in and started?
richards72chevy is offline   Reply With Quote
Old 03-02-2013, 09:42 AM   #87
71K20chevy
71K20chevy's Avatar
When pressure washing an engine, it really is best to do bare block-heads instead of with everything on it, it'd probably be fine if you sealed it off plenty good but I personally wouldn't try it.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-10-2013, 12:42 PM   #88
TH3JUICEMAN
TH3JUICEMAN's Avatar
When soaking in Simple Green and then power washing what parts in the bay should be covered or not exposed to high pressure water?
TH3JUICEMAN is offline   Reply With Quote
Old 12-28-2013, 10:05 PM   #89
mpierce9
Great question here. I'd like to take my truck to one of those DIY car wash places, remove the air cleaner, cover the carburetor with a plastic bag and spray that sucker off real good... Is this a bad idea? Could this negatively impact the engine?
If this is a reasonable approach, I'd like to spray on some Purple power and let it soak in beforehand.
Thoughts?
mpierce9 is offline   Reply With Quote
Old 12-31-2013, 02:48 AM   #90
Rich 5150 69
Rich 5150 69's Avatar
Lower shock mounts for my `64 c-10 after sitting in white vinegar for four days.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-31-2013, 07:51 AM   #91
71K20chevy
71K20chevy's Avatar
Well that's impressive! Thanks for the tip!
71 K20
64 GMC mud truck
Old 08-09-2014, 02:13 PM   #92
thelawdoc
Vinegar is really great for rust removal. Anytime I see it on sale, I buy it like there's no tomorrow. It is not an instant cleaner by any means, but it is damn cheap. Sometimes, I toss a part into the bucket and leave it for weeks until I get back to it.
thelawdoc is offline   Reply With Quote
Old 08-09-2014, 03:23 PM   #93
Senorx
Senorx's Avatar
I'm degreasing my engine for the first time this coming Monday. Anymore words of wisdom for a newbie?
Senorx is offline   Reply With Quote
Old 08-09-2014, 03:36 PM   #94
thelawdoc
Senorx, wear gloves. My fingerprint grooves and nails were black for a long time after I once cleaned an engine. No amount of scrubbing them got me through inspection by my old lady. The gloves might save you from a few nights on the living room couch.
Old 08-09-2014, 03:39 PM   #95
Senorx
Senorx's Avatar
Good to know. I have a box of latex gloves.
Old 09-10-2014, 02:40 PM   #96
greystoke
what do you guys recommend for cleaning LS motors? Do these require special handling?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 09-10-2014, 02:48 PM   #97
thelawdoc
Graystoke, the only engine I have a clue about is my 250 I6. In general, I cover the distributor, coil, carb, air cleaner, and other electrical areas, and I use brushes and a bucket of water. I do not pressure wash the engine bay. It all cleans up pretty nicely and it is really no big chore. Take your lazy time. Have a look at what you are doing. Then use smaller brushes or rags to clean any areas that you did not get to with the larger brush. I suppose more experienced guys will use a hose, but I don't mind the slower, hand cleaning, method.
Old 11-15-2014, 02:09 PM   #98
NJ C10 Guy
Stupid question here: if I take my time and mask off what needs to be masked off, would it be possible to paint my engine without removing it? It's not too messy under the hood, but the motor has paint flaking/chipping and it drives me crazy. I'd like to do a nice detail of everything, but it's pretty worthless if my engine looks like crap.
NJ C10 Guy is offline   Reply With Quote
Old 11-15-2014, 02:23 PM   #99
thelawdoc
NJc10Guy, My '66 c10 250 has room for a bed under the hood and I suppose the engine could be painted without removing it. Obviously, you are not going to get the paint job you would get if the engine were removed. I have read over and over again that the I6 250 is no big deal to take out. It seems to me that you would be spending a lot of time doing the masking that you mentioned, plus you might want to remove some accessories, hoses, etc. Look, every guy does his own paint job. You can spend a day painting or you can spend a week, and I am sure there are guys who will spend a month to get the result that they want. You get what you sow, I would say. Anyway, do what you gives you joy and enjoy what you did.
Old 11-15-2014, 03:50 PM   #100
piecesparts
Parts and more parts
piecesparts's Avatar
Simple answer is yes. However cover the whole vehicle, the fumes carries small amounts of paint in them and it will settle everywhere you do not want it.
Frank
piecesparts is offline   Reply With Quote
