Old 10-04-2009, 03:09 PM   #76
68 short step
Re: project BIG RED (gen3 on air)
thanks guys, the fittings are blue because they're aluminum...these are AN style fittings, and in airplane world
blue=aluminum
black= steel
stainless= stainless
so the auto world copied this, but you can get aluminum fittings in black, blue, or ive even seen them in red in the auto world...
68 short step is offline   Reply With Quote
Old 10-04-2009, 11:35 PM   #77
nuke1
nuke1's Avatar
very true, i got an fittings for my brake lines
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-05-2009, 08:19 AM   #78
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What brand of tire is mounted on the 20/22 setup?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-05-2009, 06:32 PM   #79
68 short step
goodyear
Old 10-05-2009, 06:51 PM   #80
mcbassin
Still Learning
mcbassin's Avatar
Another nice project! Hey, where do you find all these late model engines? Do you have a connection with a yard? You mind hooking a fellow Oklahoma member up? I am in the market for a 5.3/4l60e with or without dbw pedal. I have found many just not one in my price range yet. Keep up the Strong skills!
mcbassin is offline   Reply With Quote
Old 10-05-2009, 09:59 PM   #81
68 short step
no connections with any yards, i keep my eye out on CL, and when i need one 'now' schram auto is my recommendation.
Old 10-05-2009, 10:04 PM   #82
mcbassin
Still Learning
mcbassin's Avatar
Yes, I watch local CL pretty hard too. I just missed one this past weekend. I will get one eventually. I would really like to find one in a rollover that hear run first.
Old 10-06-2009, 01:39 PM   #83
franky69c10
chevy runs deep
franky69c10's Avatar
Looking good what harness r u using 4 ur truck 2 get that motor running do u have 2 make one up or are u having sumone make one up 4 u
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 10-06-2009, 04:46 PM   #84
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
subscribed
LOW DOUGH is offline   Reply With Quote
Old 10-06-2009, 06:41 PM   #85
68 short step
im useing the factory one, that i modify.
Old 10-06-2009, 08:28 PM   #86
Thealien
Thealien's Avatar
As always love seeing your work! I can't thank you enough for sharing with all of us, even when you have to answer the same questions repeatedly!
Old 10-06-2009, 10:13 PM   #87
mcbassin
Still Learning
mcbassin's Avatar
It looks like you understand the harness pretty good to re-do all that like you do.
Do you send off the computers to have them reprogrammed? If so, who are you using? What did you do about the A/C compressor?
Old 10-06-2009, 10:40 PM   #88
68 short step
the computers are tuned by my tuner guy, glen, in OKC.... he does all my tuning and my brothers too.... he's very knowledgable on these LS base engines... im gonna use a vintage air magnum gen4 system, with the stock A/C compressor, in the stock position.....i use adaptor blocks from docsblocks.com, to connect my compressor to my A/C lines...
Old 10-06-2009, 10:53 PM   #89
mcbassin
Still Learning
mcbassin's Avatar
Do you know if Glen will do a "plug and play" harness and tune? You have an idea of cost? Thanks, keep up the good work!
Old 10-17-2009, 12:52 AM   #90
68 short step
here are a few pics of the new location of the air tank....its a simple bolt on thing, useing 2 staps i made from 3/16 thick by 3" wide steel plate.... also i had to take 1.25" out of the air tank mounts... the tank hung down little too low for my liking.... ill have to get pics of the compressor mounting tomorrow..
Old 10-17-2009, 09:19 AM   #91
hgs_notes
GEARHEAD
hgs_notes's Avatar
What are you using for a fuel tank?
hgs_notes is offline   Reply With Quote
Old 10-17-2009, 12:00 PM   #92
68 short step
im gonna moddify the stock one, for an in-tank pump...so its gonna stay behind the seat, for now anyways.
Old 10-17-2009, 03:29 PM   #93
68 short step
and pics of the compressor mounting....
Old 10-30-2009, 11:27 PM   #94
68 short step
a little progress to report, got my ECE rear hitch installed.
Old 10-30-2009, 11:36 PM   #95
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Is that a hitch that hides behind the plate or just below the plate/bumper? I guess it looks like it will be below the bumper.....
Old 10-31-2009, 11:46 AM   #96
68 short step
its ECE hidden hitch, it hides under the plate... comes with a bracket that flips the plate up/down to reveal the receiver..
Old 11-01-2009, 07:34 PM   #97
68 short step
got a little body work done on big red this weekend.....made the 'half moon' piece for the pass. side firewall, to make it symetrical with the driver side.. then welded in on.. next i put down some rust inhibitor, seam sealer, then a couple coats of black paint, to make it uniformed...after that i made some \1 1/4" metal strips, so i could cap the rain gutter.....welded in the strips, and ground down the welds...still need to fill in some holes in the firewall, for misc. things im not gonna use... but here are the progress pics
Old 11-01-2009, 07:36 PM   #98
68 short step
Old 11-01-2009, 08:56 PM   #99
-T-
-T-'s Avatar
Good looking build, I just started on mine and headed in some similar directions. I love the Gen3 motors. I have used them in all of my rockcrawlers. I saw some jeeps in the corner in a couple of the pics. I've been into jeeps for about 8yrs and just sold this one to start on my '69
-T- is offline   Reply With Quote
Old 11-01-2009, 09:09 PM   #100
68 short step
the jeeps in the shop all have LSx engines too...my buddy, justin, is into them, and i wire them up/ get the electronics taken care of... he does all the mechanical work...ever looking for another rock-crawler, give me a buzz, i think there is about 8 at the shop now....along with a 70 cuda getting a viper v10
