Old 01-27-2010, 08:38 PM   #76
sgaylord
Project collector
sgaylord's Avatar
Re: Project "Jezebel"
Finally the firewall going on for the last time.
It took a little bit of work to get everything aligned but it was time well spent. It took several hours to create the lip on the floor sections where they meet the firewall. My floor pans were made to extend several inches up the firewall (not sure if they all are this way or not).
Firewall held in with Klekos
This is the money shot just before installing the firewall for the last time. After this pic, I shot the entire overlap with weld thru primer.
As you can see here the firewall hump did not line up with the hump in the floor.
In this pic you can see that I welded a bolt to a piece of 1x1 square tube and ran the bolt through the floor. Then I attached a nut and washer from the other side and used this jig to pull the floor in line with the firewall. As you can see from the pic it worked pretty good.
Here is a better pic of the jig. I still have some welding to do but it's in there like it should be.
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 01-27-2010, 08:46 PM   #77
sgaylord
Project collector
sgaylord's Avatar
Here are the pics of the firewall all welded in from the front. Lots of spotwelds to grind down.... If I had to do that again it may have been better to buy an aftermarket firewall. This way it would limit the amount of spotwelds.
From there I sent to work on the cab corners!
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-27-2010, 08:48 PM   #78
70stroker
70stroker's Avatar
thats looking good man. keep it up
70stroker is offline   Reply With Quote
Old 01-27-2010, 08:58 PM   #79
sgaylord
Project collector
sgaylord's Avatar
70stroker
Thanks 70stroker, still a ways to go but I am progressing and that's the important part.
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-27-2010, 09:14 PM   #80
sgaylord
Project collector
sgaylord's Avatar
Now to the passenger side cab corner. Here I am going to have to replace the end of the rear brace, the cab corner as well as a small part of the floor.
Here is where we started after opening up the cab corner. As you can see the inner floor in that area needs replacing as well.
I guess the PO thought it would be easier to cut the corner off at an angle instead of replacing the corner correctly. As you can see there is an interesting mud job as well. I have seen worse, this mud was only about 3/8" thick.
Here is it ground down to to the area I will end up replacing anyway. No reason to clean all that off if I am going to replace it anyway. The black like is where I cut for the new panel to go on.
This is the floor section viewed from the rear of the cab. I removed the outer cab corner section. I will replace this entire section.
This is the same pic as the first one on this page, just with those previously mentioned areas removed.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-27-2010, 09:22 PM   #81
VA72C10
VA72C10
VA72C10's Avatar
Looking good...pretty soon you'll have a rust free cab!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-27-2010, 09:25 PM   #82
sgaylord
Project collector
sgaylord's Avatar
Now I needed to remove part of the floor so I could reveal the floor brace so I could replace the end of it. I cut the spotwelds, then cut the floor to just above where the jack hold down is bolted in. This gave me the clearance I needed to cut the end of the brace off so I can add the new one.
Here I have the section ready to come out. It will go back in when I am done replacing a portion of the brace.
Revealing the brace below. Not too bad. Mostly surface rust, except for the first couple inches that needs to be replaced.
Side view
Bad section cut out.
Now I need to figure out what I did with those replacement rear floor braces... I know I put them around here somewhere.....
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-27-2010, 09:32 PM   #83
sgaylord
Project collector
sgaylord's Avatar
VA72C10
Thanks Jonathan, I see your project is progressing very well. One day I will be where you are now. Hopefully it will be before I'm too old to finish it.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-27-2010, 09:39 PM   #84
mcbassin
Still Learning
mcbassin's Avatar
WOW! Have to admit that is a major project you have taken with the cab.
I am just about done with some of the same things you are doing but no where near the rust you have beat. I guess the donor cab was too far gone in other ares to use it complete?
PS. that is one bad Camaro you restored! Love it!
mcbassin is offline   Reply With Quote
Old 01-28-2010, 10:04 AM   #85
sgaylord
Project collector
sgaylord's Avatar
mcbassin
Thanks mcbassin it's finally coming along. The donor cab in the 71 GMC was a patchwork quilt that needed quite a bit. The only good parts were the firewall and roof. I used the firewall and sold the roof. I have since purchased a few other trucks and cabs so the 71GMC will be my next project after Jezebel is done.
Yep, the Camaro was my first attempt at a full restoration. I learned a lot with that one.
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 05-03-2010, 09:52 PM   #86
sourkraut
sourkraut's Avatar
wow you have really invested some serious time and energy into this cab! I thought mine was bad but wow, I got nothing on you! keep up the good work!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 05-04-2010, 01:03 PM   #87
sgaylord
Project collector
sgaylord's Avatar
Thanks Sourkraut, Jezebel has been on the back burner for a little while because I am working on my burb so I can take it on the PowerTour. I plan to get back to Jezebel soon with plans to complete it this year. That's the plan anyway.... :-)
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-17-2010, 05:04 PM   #88
sgaylord
Project collector
sgaylord's Avatar
Now that the PowerTour is over I'm back on Jezebel. Made a little progress over the last couple of evenings. My camera is on the fritz and don't have any pics. I will get some posted soon. Back to welding and grinding... So much fun!
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-17-2010, 07:26 PM   #89
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Steve
Keep on grinding.....
You have alot of ability and talent. I would have moved on about 10 minutes after I started to dissasemble...lol
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 06-17-2010, 10:11 PM   #90
mcbassin
Still Learning
mcbassin's Avatar
Need to see some pics man!
Old 06-17-2010, 10:45 PM   #91
bigguy69
dazed and confused
bigguy69's Avatar
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 06-18-2010, 11:28 AM   #92
sgaylord
Project collector
sgaylord's Avatar
Good news! After my last post about the camera on the fritz, I went downstairs and my family gave me a new camera for Fathers Day (a couple days early)!
Here are some pics of the progress on the pass floor brace replacement.
In this pic you can see the coating of POR-15 inside to try and keep some of the rust from reappearing.
Replacing the part I cut out to gain access to the brace.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-18-2010, 11:42 AM   #93
sgaylord
Project collector
sgaylord's Avatar
The weld in of the jack hold down area and the inner rocker.
To align the piece all I had to do was find where the spot welds we cut to remove the panel.
Plans are to POR-15 everything inside the rocker. If no treatment from the factory lasted 20-30-40 years, then this should last at least the rest of my lifetime.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-18-2010, 11:55 AM   #94
sgaylord
Project collector
sgaylord's Avatar
Finally are the pics of the patch for the brace where it meets the jack area. Pretty strait forward drill a couple holes rosette weld and then weld in the edges where needed.
Now grinding, that is another story. Not my favorite job, but hey, it has to be done, right?
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-18-2010, 01:58 PM   #95
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice progress!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-19-2010, 08:16 PM   #96
mcbassin
Still Learning
mcbassin's Avatar
Great work on the rust repair!
Old 06-19-2010, 08:25 PM   #97
VA72C10
VA72C10
VA72C10's Avatar
Coming along nicely!!!
Old 06-21-2010, 09:55 AM   #98
sgaylord
Project collector
sgaylord's Avatar
Good progress this weekend. I was able to get both cab corners replaced. I would like to say it was done without incident however that is not the case. There were a few areas where I blew through welding the cab corners, as well as a larger gap in the right side cab corner than I had liked. To fix the abnormal gap I ended up placing a 1" backing strip along the inside and welded it in to bridge the gap. I figure that will not be an issue since it's inside the cab, away from moisture and sight. For the blow through's, I just waited for it to cool, lowered the setting on the welder slightly until I got past that area, then reset the amperage and moved on.
Other than the issues mentioned above there was really no other major incidents. Lot's of grinding. One of these days I hope to get better at welding so I don't spend so much time grinding...
I don't know the name of this piece, for the sake of this discussion lets call it a "B" pillar to rocker patch.
As you can see from this pic it's about 1/4 too short. Oh the beauties of aftermarket.... Not too big a deal. I will cut and form it to fit better after I install the door to mock-up the rocker. Then weld it back together.
Here is the cab corner just before welding. In this pic you can see the gaps mentioned above. This is why I needed the backing strip in the cab.
My welds in all their beauty. I have that issue when welding vertical. Horizontal, as long as it's not upside down goes great. Darn gravity.....
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-21-2010, 10:04 AM   #99
sgaylord
Project collector
sgaylord's Avatar
Drivers side
Where I started. Look abnormally smooth to you? Where is the bottom of the cab corner?
This is a pic with the 1/2-3/4" of filler removed.
Trying to show the gap that was filled with filler.
That section of the cab corner removed. The rear of the floor where it folds down is not in bad shape. What a find! I replaced it anyway, couldn't start getting soft now....
Last remaining cab corner piece removed.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 06-21-2010, 10:15 AM   #100
sgaylord
Project collector
sgaylord's Avatar
More
I had to remove the "B" Pillar extension in order to gain access to the inner rocker/floor patch. and peeled back the floor a little.
Since the brace was not in bad shape I prep-ed and applied a thick coat of POR-15.
Inner Rocker/Floor patch welded in.
One more piece to go.
Jezebel 3.0 NEW!!!
Roll Tide!
