Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-15-2012, 01:36 AM   #76
turp mcspray
turp mcspray's Avatar
Re: New member from the Black Hills
And a few more. Got the front axle in and mostly assembled. I need to paint the rest of my front end and steering parts next.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 01-15-2012, 01:45 AM   #77
turp mcspray
And the last few. I just got done welding up my drag link, and tie rod. They will need paint next.
Turp Mcspray
Old 03-18-2012, 05:59 PM   #78
turp mcspray
Time for a few update pics. I had to ream out my pitman arm to fit the large tie rod end taper. Getting front end parts ready to paint.
(Note to mods,since this has evolved into a build thread, feel free to move it to that section)
Turp Mcspray
Old 03-18-2012, 06:04 PM   #79
turp mcspray
More parts in the paint stage.
Turp Mcspray
Old 03-18-2012, 06:14 PM   #80
turp mcspray
I'm doing POR on all my chassis parts, and then topcoating that. The satin black is some urethane that once cured, is very durable. It is unfazed by brake fluid, so I figured it should hold up well in the rain,snow, and street thawing chemicals that get used here locally. Because believe it or not, I'm gonna drive the the wheels off this thing when it's done! I did the hubs and rotors in "cast blast" and the dust cover with a stainless paint, both with flat clear on top. I'm not trying so much for correctness, I just like the detail of some different color, instead of all black.
Turp Mcspray
Old 03-18-2012, 06:23 PM   #81
turp mcspray
Going back together. I probably should have cut off the old tie rod arms from the knuckles. I may not be able to live with them sticking out there, doing nothing. The front end is back on wheels, and sitting on the ground. What a feeling of progress!
Turp Mcspray
Old 03-18-2012, 06:38 PM   #82
turp mcspray
I bought a th400 and matching 205. I'm going to rob the 205 to 400 input shaft, and adapter, and put it in my original 350 205. The donor case has been rebuilt before, but I found traces of having sat with some water in it, and some iffy looking things once I opened it up. My original was very nice inside, so I decided to use it, with an input shaft swap.
Turp Mcspray
Old 03-18-2012, 06:44 PM   #83
turp mcspray
All tore apart, cleaned and blasted for paint.
Turp Mcspray
Old 03-18-2012, 06:50 PM   #84
turp mcspray
Painted, assembled, and installed. Next step is to build a rear end.
Turp Mcspray
Old 03-18-2012, 07:00 PM   #85
rsavage
rsavage's Avatar
Looking good!
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 07-04-2012, 02:15 PM   #86
turp mcspray
I've been falling behind on my blazer thread. Since my build got started on the 4th of July, I figure I should post a few pics today.
I scrounged a different rear end from my spare pile. The original had a bent spring mount, and one tube was broke loose from the center. It is a late 70's rear, so I had to remove all of the brackets and mounts.
Turp Mcspray
Old 07-04-2012, 02:24 PM   #87
turp mcspray
I borrowed a truing bar from a buddy, so I could straighten the housing after welding on the new perches and brackets. As you can see, they are far from straight, as they come from the factory. I welded on new spring perches, shock mounts, a traction bar bracket, and welded the tubes to the center section.
Turp Mcspray
Old 07-04-2012, 02:29 PM   #88
turp mcspray
I had to make a cross member for the front end of the traction bar. Also decided to add a balance tube to my exhaust.
Turp Mcspray
Old 07-04-2012, 02:34 PM   #89
turp mcspray
I haven't decided 100% on my tailpipes yet. I,m leaning towards angling them to the outer corner of the body and bumper end area.
Turp Mcspray
Old 07-04-2012, 02:39 PM   #90
turp mcspray
I had a twin stick set up in my other blazer. I really liked it, so I decided I needed one again. I decided to use two factory sticks, for a somewhat stock look. I used some rod ends from Speedway Motors.
Turp Mcspray
Old 07-04-2012, 02:46 PM   #91
turp mcspray
A load of parts ready for some satin black.
Turp Mcspray
Old 07-04-2012, 02:51 PM   #92
turp mcspray
Misc. black stuff.
Turp Mcspray
Old 07-04-2012, 02:56 PM   #93
turp mcspray
Couple more satin black pics. Rear end is back under the chassis. A shot of the new gears.
Turp Mcspray
Old 07-04-2012, 03:14 PM   #94
turp mcspray
I added a fancy cover to hopefully add a little strength. I plan to beat on the big block for all it's worth! And a few pics of everything bolted up.
Turp Mcspray
Old 07-04-2012, 03:20 PM   #95
turp mcspray
It feels really good to see it setting back on 4 wheels again! Now I plan to get back to the body while I'm waiting for funds to build up for the engine rebuild.
Turp Mcspray
Old 07-04-2012, 07:33 PM   #96
Pife
It looks great! Keep up with the great pics and commentary.
Pife is offline   Reply With Quote
Old 07-06-2012, 02:01 PM   #97
thor
thor's Avatar
Looking good Turp!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 07-16-2012, 12:35 AM   #98
PHAT TONY
PHAT TONY's Avatar
I just came across this; better get on board!! LOL.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 07-22-2012, 12:36 AM   #99
hgs_notes
GEARHEAD
hgs_notes's Avatar
I didn't know you had your own build thread going. Looking good. I was really surprised you could fit the newer blazer tank in behind the axle. I used the same tank on my C-10, but that is a longbed and clearance was tight for that because of the track bar. Did you use the 73 style crossmember for the front of the tank? And is the skid plate an OEM piece? And now I think I need to find another t-case shifter so I can twin stick mine like that.
hgs_notes is offline   Reply With Quote
Old 02-16-2013, 10:04 PM   #100
turp mcspray
hgs...for the gas tank, I used the 73 up front crossmember, and I moved my original rear one, back as far as it would go. And yes, the skid plate is a factory piece.
I finally made some decent progress over the last several months. Here are some more pics. I went to mount the body to the rotisserie, and discovered that I had a rusty rear body mount thingy.
Turp Mcspray
