Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 11-27-2009, 03:19 PM   #76
Re: Project Tahoe on a Budget
Originally Posted by 5150 View Post
Travis, I want your old front end parts, headlight, grille, etc.
Do we see a change to the crewcab coming?
Old 11-27-2009, 06:13 PM   #77
bumslie75
bumslie75's Avatar
Looks good great buy
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
bumslie75 is offline   Reply With Quote
Old 11-28-2009, 10:04 PM   #78
tvblazer78
Low & Fast!
tvblazer78's Avatar
Well, a buddy and I started at 9am and worked to 4pm today and it was a long day but it's on the ground. The only thing we did not do is the c-notch, that will be in the next week or so. And I will cut or heat the front springs, I need to get it down about 1" or 2". But it's one step closer.
tvblazer78 is offline   Reply With Quote
Old 11-28-2009, 10:12 PM   #79
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks really GOOD!
What is the total drop in these pics?
Cut those fronts springs,... don't heat them.
Keith
Convert to disc brakes.
Old 11-28-2009, 10:45 PM   #80
menace121978
menace121978's Avatar
looks alot better buddy! nice job. i agree... 1-2 more inches in the front. maybe just try whacking off 1/2 a coil 1st.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 11-28-2009, 10:52 PM   #81
VA72C10
VA72C10
VA72C10's Avatar
Looks really good. Definitely cut the springs. Mine were heated and were downright dangerous...the passenger side spring broke due to the stress...and they were binding and popping on each other as you drove....so cutting is the way to go.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-29-2009, 12:01 AM   #82
tvblazer78
Low & Fast!
tvblazer78's Avatar
Looks really GOOD!
4 up front and 6 out back, it needs to be 5 up front, but it will be soon.
Thanks guys..
Trav
Old 11-29-2009, 12:19 AM   #83
watahyahknow
watahyahknow's Avatar
cant realy see how far the bottomlip is of the ground but the front looks like its there allready maibe just raise the rear an inch will equal it out and keep it driveable at least untill you got the airbags to put under there
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-29-2009, 10:31 AM   #84
k5hart
k5hart's Avatar
I wonder if the springs may settle some once you drive it a little and bring the front down some more.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 11-29-2009, 11:56 AM   #85
60ratrod
yes, i do
60ratrod's Avatar
i dunno about cutting. you still weaken the spring when you cut it. but then again i don't think they make a 5" drop spring so cutting might be the way to go on this one. its just i've seen bad things happen when springs have been cut.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 11-29-2009, 12:01 PM   #86
scotts62
One day...
scotts62's Avatar
Just cut them but i wouldn't heat them.
Scott
93 crew cab build
Project 62
Old 11-29-2009, 12:52 PM   #87
watahyahknow
the only thing when you cut a spring is that the cut part doesnt fit whell in the springpocket you might need to heat up the end after cutting and bend it so the last coilwind is about level again
Old 11-29-2009, 01:56 PM   #88
lolife99
lolife99's Avatar
Totally disagree.
Cutting springs can be done, and is done sucessfully all the time.
Don't use a torch. Use a cut-off wheel in a die grinder. That keeps the spring cool. Even in the old days springs were cut with a torch, while the spring was in a bucket of water.
A good formula is:
1/2 coil removed = 1" of drop.
What bad things have you seen with cut springs?
Keith
Old 11-29-2009, 02:03 PM   #89
N2TRUX
Happy to be here
N2TRUX's Avatar
Looks great Travis. I agree with the general consensus. I have cut many springs over the years with no adverse affect.
Another thing that will clean your front end up and is budget conscious is adding clear corner markers. They look just right with the clear headlights.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-29-2009, 04:33 PM   #90
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Are you any closer to finding a set of wheels?
Old 11-29-2009, 05:10 PM   #91
5150
C10 Club Tennessee
5150's Avatar
I agree, nothing wrong with cutting springs.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-29-2009, 06:24 PM   #92
tvblazer78
Low & Fast!
tvblazer78's Avatar
After the first of the year I may be closer, are you getting new ones for your truck?
And it looks like I may cut them, after all that..
Thanks,
Trav
Old 11-30-2009, 12:00 AM   #93
jb1016
jb1016's Avatar
Nah, just wondering. You wouldn't want my little old 18s anyway
Old 11-30-2009, 10:10 AM   #94
menace121978
Thanks,
Trav
"Dennis the Menace"
Old 12-03-2009, 11:33 AM   #95
tvblazer78
Low & Fast!
tvblazer78's Avatar
Here are some better pics, plus I put air shocks on the back for right now. I can not go any lower in the front with the tires I am running. So I may have to do something about that.
Old 12-03-2009, 12:08 PM   #96
Billet Jason
Man that thing looks good! I wish mine was black!!!
Billet Jason is offline   Reply With Quote
Old 12-03-2009, 12:36 PM   #97
menace121978
sure is clean buddy!
wonder how it would look with the small spokes on the wheels painted black?? there's alot of different options you could do w/ those wheels...
"Dennis the Menace"
Old 12-03-2009, 01:31 PM   #98
watahyahknow
the stance looks perfect to me actually when you go lower withouth airsprings you'll prolly hurt the bottom of the truck
Old 12-03-2009, 04:32 PM   #99
jb1016
jb1016's Avatar
Did you tint your taillight lenses?
Old 12-03-2009, 06:08 PM   #100
Very Nice Travis!!!
