Old 08-27-2010, 12:04 PM   #76
sgaylord
Project collector
sgaylord's Avatar
Re: Good 70 SWB
Great job so far padawan. No, in all seriousness I learn as much from you. Keep up the good work.
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 08-27-2010, 02:38 PM   #77
mcbassin
Still Learning
mcbassin's Avatar
Re: Good 70 SWB
I really like what your doing with the wiring harness! great idea! BTW, the firewall looks smooth! I am liking what you are doing....hope you don't mind copy cats
mcbassin is offline   Reply With Quote
Old 09-01-2010, 08:49 AM   #78
bgood70
bgood70's Avatar
Re: Good 70 SWB
Thanks for the comments. And copy away!!
70 C-10 SWB 350/700r4 Good 70 SWB Build
72 GMC Sprint SP Custom 350/Turbo300
bgood70 is offline   Reply With Quote
Old 11-08-2010, 02:53 PM   #79
bgood70
bgood70's Avatar
Re: Good 70 SWB
I wanted to be able to route my exhaust up through the rear cross member so it did not hang down below the frame. I read this could be done in a FAQ and it mentioned cutting the crossmember may weaken it and you should reinforce it. So.
I had some 4 in pipe laying around and had my neighbour cut a couple sleeves from it on his band saw.
I ground down the area that I plan to cut out.
I located where I wanted the sleeves to go this is pretty much center top to bottom and frame rail to trailing arm mount.
Used plasma cutter to cut it out
Old 11-08-2010, 03:02 PM   #80
bgood70
bgood70's Avatar
Re: Good 70 SWB
I test fit the sleeve and flushed it to the edge of the crossmember.
Ok got the sleeves welded in and ground down. Here is a close up.
Here is a picture of both sides
Here it is after some etch primer and paint applied. Come out pretty nice.
Old 11-08-2010, 03:29 PM   #81
VA72C10
VA72C10
VA72C10's Avatar
Re: Good 70 SWB
Looks nice and smooth....did mine oval and matched the standout of the center oval hoop, but I like that look also!!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-08-2010, 05:05 PM   #82
franky69c10
chevy runs deep
franky69c10's Avatar
Re: Good 70 SWB
Lookn good
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 11-09-2010, 10:46 AM   #83
sgaylord
Project collector
sgaylord's Avatar
Re: Good 70 SWB
Looks good. Now come over and do mine!
Jezebel 3.0 NEW!!!
Roll Tide!
Old 11-11-2010, 12:45 AM   #84
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: Good 70 SWB
looking nice, wish I woulda seen this crossmember mod before I coated my frame, way stronger and looks nice, great work on the firewall as well
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 11-19-2010, 01:29 AM   #85
c10layinlow
Re: Good 70 SWB
when capping the firewall did u have to cut spices in it in order to get it to bend around?
thanks
c10layinlow is offline   Reply With Quote
Old 11-19-2010, 09:56 PM   #86
bgood70
bgood70's Avatar
Re: Good 70 SWB
thanks
I used three sections on this. I cut 2 pieces to go up each end and curve around the top. These were long enough that after the curve they went horizontal for 4 - 6 inches. I had to use a shrinker/stretcher to create the curve needed. Then I used a third piece to complete the middle section.
Here is another build that has information on this also. Project Jezebel
Old 11-19-2010, 10:02 PM   #87
bgood70
bgood70's Avatar
Re: Good 70 SWB
Thanks for the comments. Your build is looking good also... I like the Blue you have selected.
Old 11-19-2010, 10:03 PM   #88
bgood70
bgood70's Avatar
Re: Good 70 SWB
I only work for beer
Old 11-20-2010, 09:37 AM   #89
sgaylord
Project collector
sgaylord's Avatar
Re: Good 70 SWB
You drink my beer anyway. Now it's time to get to the work part! :-)
Jezebel 3.0 NEW!!!
Roll Tide!
Old 12-26-2010, 03:22 PM   #90
RCbowtie69
RCbowtie69's Avatar
Re: Good 70 SWB
looking good
RCbowtie69 is offline   Reply With Quote
Old 12-26-2010, 03:33 PM   #91
yukon ratrod
yukon ratrod's Avatar
Re: Good 70 SWB
this is coming along quite nicely. making great progress. would never guess this was your first build!
yukon ratrod is offline   Reply With Quote
Old 01-22-2011, 10:40 PM   #92
RCbowtie69
RCbowtie69's Avatar
Re: Good 70 SWB
just checking,any progress or pictures,nice build
Old 01-23-2011, 10:31 AM   #93
Stepside
Gasser
Thumbs up Re: Good 70 SWB
Very sweeeet project! Thanks for taking the time to share with us.
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Stepside is offline   Reply With Quote
Old 01-23-2011, 11:42 AM   #94
Hart_Rod
Hart_Rod's Avatar
Re: Good 70 SWB
Missed this one somehow...nice work. I'm sure Steve can give you some good advice on rust repair, I think he's done it a time or two....
Hart_Rod is offline   Reply With Quote
Old 07-02-2013, 01:07 PM   #95
bgood70
bgood70's Avatar
Re: Good 70 SWB
Wow talking about taking a Sabbatical... Looking at my build thread I had not posted anything since Jan 2011. Well I have been working some on my build but have to say I have not made much progress in that time. I have done some additional Firewall smoothing by filling in some extra holes etc. Pictures to follow. I also have aligned and gaped doors, fenders, hood, I picked up new bedside and tailgate. Currently everything is pulled apart for blocking and paint prep. I hope to begin painting panels in by end of month.
Old 07-02-2013, 01:30 PM   #96
mcbassin
Still Learning
mcbassin's Avatar
Re: Good 70 SWB
Long dry spell.
I completely understand, I'm nearing my 4th fall working on my project. Life happens. It is what it is. Now about those pictures.
Old 07-02-2013, 01:36 PM   #97
CC69Rat
CC69Rat's Avatar
Re: Good 70 SWB
Looks great man. Subscribed!
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-02-2013, 01:38 PM   #98
bgood70
bgood70's Avatar
Re: Good 70 SWB
So I decided I would not need all the holes for Throttle linkage and wiring. I will look to route wiring through fender and frame instead. Name:  20130625_170259.jpg
Size:  24.9 KBAlso the area where the EBrake mounted was bothering my. I did not like the way it stuck out so I cut it out and filled it in so it was flat. Name:  20130625_170312.jpg
Size:  22.8 KBName:  20130625_182135.jpg
Size:  30.8 KBName:  20130702_130844.jpg
Size:  28.3 KB Here it the end result.
Old 07-02-2013, 01:40 PM   #99
bgood70
bgood70's Avatar
Re: Good 70 SWB
Also I recently picked up some Bucket seats from an 80's Silverado. Will be looking to have these redone. Name:  70ChevyFirewall 005.jpg
Old 07-02-2013, 01:42 PM   #100
bgood70
bgood70's Avatar
Re: Good 70 SWB
So currently here is where am I at. Getting all panels ready for some color. Name:  20130702_130919.jpg
