Old 01-18-2011, 02:20 AM   #76
65Pickup
65Pickup's Avatar
Re: project lownslw64
Thanks that's real helpful. I need to run some 1/2" ss fuel lines, and yours look professional. A buddy at work recommended compression fittings like yours, (industrial) very high psi rating. Thanks again, I'll start looking for that bender.
65Pickup is offline   Reply With Quote
Old 02-12-2011, 11:04 PM   #77
Chapstr's65
Chapstr's65's Avatar
Did you spray on the Por-15 or brush it on. I have never used it but was thinking of using it on my frame after I sandblast it.
-Chapa
65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear.
Chapstr's65 is offline   Reply With Quote
Old 02-13-2011, 12:07 AM   #78
lownslw64
lownslw64's Avatar
i brushed it on, it works really well after you blast it. I did two coats on mine. the only problem i ran into is you need to apply it at a certain time. i think it is when it is slightly tacky when you drag your finger on it after the first coat. i didnt realize that and i did it after it dried and it turned out still good but could have been alittle better. hopes this helps.
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors
2007 chevy 2500 hd 4x4 duramax
lownslw64 is offline   Reply With Quote
Old 04-02-2011, 01:27 AM   #79
Slow Build
Slow Build's Avatar
How's it going. All your work looks great. Any updates?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-03-2011, 11:09 AM   #80
lownslw64
lownslw64's Avatar
thanks rich, everything has been good slow progress. how bout yourself? didn't know if your were still around or not. glad to see u back. any progress on yours? saw you got a stock a/c system, thats cool. I've done a couple things recently. bend and installed a 3/8 ss fuel line to a filter regulator on the frame for the feed to the fuel rail and got some ss flex lines and fitting for the rear bags. hopefully soon going to get my fuel cell modified for an intank pump and start working on the cab fixing all the floorboards, rockers etc.....
Old 12-01-2012, 01:42 AM   #81
65shortbox
65shortbox's Avatar
I know it has been a while but do you have any updates for us on this build? Great looking project! I am knee deep into an LS1/T56 swap on my 67 camaro. Maybe one day I will tear into the truck for a drop member and LS1 swap on that one as well, lol.
65shortbox is offline   Reply With Quote
Old 04-24-2016, 12:45 AM   #82
Slow Build
Slow Build's Avatar
Unfortunately this project is up for sale now, minus engine and tranny, on CL. I was really looking forward to seeing this build go forward.
Past GM Trucks:
Old 06-21-2017, 12:01 PM   #83
Chevy Iron
Chevy Iron's Avatar
Outstanding! How about an update?
A bit of a technical side note/question; does your rack 'float' on the bushings or is it snug? I've seen instructions from Heidts that say float but I have a problem with that.
Great work on the chassis!
Chevy Iron
Fully customized 1968 C-10 Stovebolt 292, T-5 trans 3:73 posi
Wife says it's a "midlife crisis".....I'm okay with that.
Chevy Iron is offline   Reply With Quote
