07-18-2011, 08:21 PM | #76 |
Re: 1972 Longhorn 4x4 Diesel Project
Where did you find that Cowl Induction Hood at?
07-18-2011, 09:58 PM | #77 |
6>8 Plugless........
I purchased it frm a guy locally, but it is a Tri-Plus hood. It fits really well and is a nice piece as well. Not a thin poor built unit like some others being sold.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-19-2011, 08:48 AM | #78 |
Well Im sure it will turn out nice either way.
My 69 Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=398263 |
07-19-2011, 07:18 PM | #79 |
Lately it has been hotter than all get out, but i'm still making head way! Here are pics of the interior color change:
Here is dissassembley of the RH door getting ready for sand blasting: Here is the hood in primer. We'll see how I feel tonight. I'd like to get the door the rest of the way taken apart and get it sand blasted. I need to get the doors back on it so I can hang the fenders and line it up.
07-19-2011, 09:30 PM | #80 |
What would you like to see? Our drag videos? Or sled Videos???
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
07-19-2011, 10:35 PM | #81 | |
07-21-2011, 01:22 AM | #82 |
nice work!! hood doors panels visors and arm rests look good!
07-21-2011, 02:21 AM | #83 |
Thanks Rick. Hopefully I can get the doors blasted, sanded, and primered soon so I can get this thing back together!
07-21-2011, 03:32 AM | #84 |
tell me about it i still need to tear mine apart!
07-22-2011, 07:42 PM | #85 |
Where did you get your interior pieces from?
07-23-2011, 10:08 AM | #86 |
They were the original green ones and I repainted them. I purchased the new arm rests locally and he gets them from Classic Parts.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 07-26-2011 at 02:41 PM. |
07-23-2011, 10:45 AM | #87 |
Still Learning
Looks like a lot of progress on this one. Keep the pics coming.
07-25-2011, 04:00 PM | #88 |
We didn't end up going to the truck pull we were going to go to in Mo on Sat, so in between rain showers I started blasting my doors. Man was it hot, muggy and misreable. I just acted like there were hot chicks in the distance so I could get through it. All in all the doors cleaned up really well. The RH door had some rust through in the lower front corner, and the inners of both corners had holes in them. The LH door had 2 cracks in the window opening and some holes on the inner door skin from where the door was hitting the rocker panel. I was really surprised how little rust holes these actually had.
Here are repair pics. Seeing how I'm strapped for time on this truck, I decided that on the inner panels I would just use my valvoline epoxy and not cut and weld new metal in seeing how I'm in a hurry.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 07-25-2011 at 04:09 PM. Reason: Can't type. |
07-26-2011, 03:58 AM | #89 |
nice! getting rid of the screw huh? i have only seen one door that was really spreaded.
07-26-2011, 02:42 PM | #90 |
Nope, not getting rid of the screw. That door had 2 cracks in the window opening. One on the inner panel and one on the outer panel. I cut the crack wider and then welded it closed. Then ground it smooth.
07-26-2011, 02:52 PM | #91 |
Last night I got the RH inner side sprayed with etch primer and sealer primer. I also cleaned up the door hinges and primed them. This morning I went back to the shop and the dang thing was kind of tacky. I put it out side in the hot sun to cure longer. Then I started on the body work on the LH inner side of the door. My hardener for my filler wasn't too happy so I will have to get some more.
07-26-2011, 08:36 PM | #92 |
What are you using to blast those?
Are you using sand or a different type of media like walnut shells or glass? How bout your blasting tank, you got one of those portable ones or what? Scott |
07-26-2011, 10:17 PM | #93 |
Still Learning
Nice work Ryan! The doors look great. Knocking it out bro.
07-26-2011, 10:28 PM | #94 |
Has more rust than truck...
Very nice work!
07-26-2011, 10:51 PM | #95 |
Thanks guys.
07-26-2011, 10:54 PM | #96 |
We have a small pressure pot sand blaster we got at harbor freight tools. It works great. I used silica sand and you can get that from most hard ware or lumber yards. Menards is where I got this batch. I'll take a pic of it and post it for you.
07-27-2011, 12:51 AM | #97 |
Nice progress Keep up the good work !!! I seen a truck that reminded me of your truck today... the license plate frame said " Real trucks have turbos "
72 C20 Longbed 05 1500 Z71 |
07-27-2011, 02:03 AM | #98 | |
I don't have a HF or Menard's up here, but i am familiar with what you are referring to and know where to get them. I just have never had much experience using that pressure pot set up for some thing like this. Do you find there is potential for warping and you have to be careful or is it not a big deal? I will only be doing sheet metal, for the couple hundred bucks i'll have a pro do the frame and such. |
07-27-2011, 02:42 AM | #99 |
nice truck!! i love how this is going!! very nice build!
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear! 1969 C30 Open Road Motorhome 350/th400 1972 K10 350/350/205 Daily Driver -SOLD |
07-27-2011, 02:29 PM | #100 | ||
Thanks.
