Old 05-27-2010, 12:37 PM   #76
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Cam Replacement
Originally Posted by HOGDADDY View Post
Fwiw I put 350 aluminum L98 heads on a smaller bore before (305 which is 3.736 bore) but had to use 350 head gaskets and it ran fine. 350 heads will work and I am guessing the Vortecs would work also as long as you don't add large valves.
I'll keep that in mind. For now im going to use the LT1 engine, less the TPI for now. The TPI will be added later on when I start a complete build, I need a motor now to use my truck for home repairs, then I can tear it down and build it the way I want.
VDOG is offline   Reply With Quote
