05-20-2010, 08:38 AM | #76 |
Redefining LowBudget
Re: Pipe Notch
thanx..I guess I'll go with it ( kida a PIA to get under it now) I do regular inspections though the wheel opening and whe ever I get it up in the air
thanx Agian great info |
05-29-2010, 07:17 PM | #77 | |
Re: Pipe Notch
Also, I was curious of the effect of welding thicker metal to thinner in a structural concept e.g. 1/4 inch wall sub-frame to chassis with factory spec frame. Does the lack of flexibility in the thicker metal create more stress at the meeting point causing undue stress? Thanks! Chris |
06-03-2010, 02:28 AM | #78 | |
Re: Pipe Notch
I think ultimately though, to do as you want to do (as do I) and keep a baseline as a stock frame strength with a notch, we will have to build our own, or modify a prebuilt one. Adding a truss or adding height to the prebuilt notch wouldnt be hard, but not as good as it would be with a solid steel piece. Im going to run the 3/8" version and just not go crazy with towing. If I build a long wheel base later on, I will probably just end up building a whole box tube chassis for peace of mind. Last edited by 8mpg; 06-03-2010 at 02:29 AM. |
06-03-2010, 10:13 AM | #79 | |
Re: Pipe Notch
I do like CPP's reaction to the concerns. Another idea would be to increase the height of the C'd portion of the notch on the thinner notches available. It might require cutting into the bed runners (or something similar), but it would be stronger.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-03-2010 at 10:14 AM. |
06-03-2010, 10:27 PM | #80 |
Re: Pipe Notch
I wasn't calling anyone out. It was more of a disclaimer since it's easy to focus on what our concerns were vs. what these kits are advertised to do. I also agree the c-notches should completely restore the strength of the frame to OE stats.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-03-2010 at 10:28 PM. |
06-04-2010, 09:25 AM | #81 | |
Re: Pipe Notch
I'm 230lbs.....Catchin' up with ya.... Did ya go to Beaches opening weds last week....I saw it rained
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
12-24-2010, 11:06 PM | #82 |
Re: Pipe Notch
Wow! What a great thread! I have to chime in on a few things. I have used belltech c-notch kits for years on my own personal projects as well as customers. I have never had those inside plates in any of the kits. I have used them on 1 ton chevy duallies as well as standard cab 1/2 ton trucks.
I wonder how weak the frame is now. I have a kit installed on a frame off project so I will measure the thickness of the notch tomorrow. I agree with Scoti on they now consider these modified trucks as "Sport Trucks" and lose towing capacity. But Belltech has there Air Jack kits to restore lost capacity. Wonder how that effects the frame strength? As I said I have never had the inside frame plates in any of the kits I have installed. One last note. Alot of people dislike Chassis tech but they have a notch kit that is a bolt on and has a piece of 2"x2" steel welded to the notch with the ability to weld to the top of the frame..wonder how those fair? Lake roadster. I have taking all you info and will be using it in the near future. I know What you are saying about comparing ONLY modified to stock frames in strength. I just wanted to add my 2 cents about using bell tech stuff as well as other products out there. Greg "GT" Tholen Last edited by 71'tahoe; 12-24-2010 at 11:08 PM. |
12-25-2010, 12:47 AM | #83 |
Re: Pipe Notch
I only recall Bell tech having 'reinforcement' plates on the 88-up kits; nothing for year models prior.
12-27-2010, 01:14 AM | #84 | |
Re: Pipe Notch
12-27-2010, 11:14 AM | #85 |
Re: Pipe Notch
The information we usually thought was most important was
RBM (Resistance to bend moment) What is the RBM for the std chevy frame ? By using this number wouldn't we have a quick and ready number that we could judge the frame strength and compare it to a modification. ??? Kieth |
12-30-2010, 10:01 PM | #86 |
Re: Pipe Notch
Here's 62Bowtie's truck being pipe notch by my co-worker Johnny B good
01-11-2011, 09:15 PM | #87 |
Lucky Teter at the wheel
Re: Pipe Notch
I have a question or two.
I am installing a 72 body on a 2001 Silverado frame. The frame drops the cab pretty low, which is nice, but the rear of the frame kicks up a lot. In my hot rod truck situation, I am needing to lower the bed down over the wheels. Not really any different than raising the wheels up into the bed wheel well, just looking at it from a different perspective. I can channel the 2.5 inch bed cross mounts that are underneath the bed floor. I will remake them with 1.25 inch tall channel iron (2 inch wide). I can install as many of these as needed. (How many would I need?). I still need 1 inch more, Can I section the height of the 5.25 inch tall frame by 1 inch? Making the bed area of the frame 4.25 inches tall, would I get back to original strength by boxing the inside of the frame rails? MANY thanks in advance!
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
01-11-2011, 10:07 PM | #88 |
Re: Pipe Notch
Wow, what an amazing thread! I have leaf springs,(66 GMC Suburban) so strength is even more important. I am thinking of doing a 2 1/2 inch notch with 1/4 plate inside and out. Hopefully I will still be able to tow and carry a load.
01-12-2011, 09:08 AM | #89 | |
Re: Pipe Notch
Since you are making home made cross sills anyway why not make them out of 2 x 2 square tube and weld them to the frame? Then bolt the bed to the cross sills in the factory stock locations around the perimeter? I'd avoid reducing the height of the frame... especially with all those cross members. And I would recomend against notching the frame web for the 2 x 2 tube, notch the 2 x 2 tubes themselves. Notching the frame flange should be fine as long as you are welding the tubes to the frame. I made a quick model of what I am trying to descibe.....Makes sense? Wouldn't that work for ya? John Last edited by lakeroadster; 01-12-2011 at 09:40 AM. |
01-12-2011, 11:17 AM | #90 | |
Re: Pipe Notch
How much do I owe you????? Seriously, this is a perfect solution and I am pretty sure it will be all I need to get low enough. I think I might want the outriggers to extend out to the inner bed sides to support them fully. Maybe cut the tips at 45 degree angles and weld an end cap on for looks? I also could have a box tubing section right on top of the tubular x members for great strength.
01-12-2011, 11:40 AM | #91 | |
Re: Pipe Notch
The 2" square tube (I'd use 10 ga. or 3/16" thick tubing) should be more than adequate, compared to the stock 2-1/4" high sheet metal stock cross sills. The only disadvantage to this concept is you will have to assemble the bed wood (assuming your not going with steel) with the bed on the truck. This is doable, but not as convenient as doing it off the truck. Good luck and be sure to post up photos as you go ! Last edited by lakeroadster; 01-12-2011 at 11:42 AM. |
01-13-2011, 04:29 PM | #92 | |
Still plays with trucks
Re: Pipe Notch
It should help increase the section modulus a bit and it would be an easy way to add some strength to the frame of people running this kind of notch. I'm curious how much of an improvement it will make. Also please take a look at how far away from the pipe notch the added material needs to continue to gain the most benefit from the change. Out of curiosity how thick would you have to make the pipe notch material to give it the strength of the stock unmodified frame?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-13-2011, 05:19 PM | #93 |
Re: Pipe Notch
Ok Lake I have been tagging along on this thread and heres what I have been thinking...
since my front is lower than the back ( surprise there) I was planning on lifting the floor of the bed 3" ( the amount of space from the top of my wheel tub to the bottom of the inside rail and I could use the space for tires too) in order to keep the floor strong and FLAT ( since I work the hell out of it) I was going to get 2 pieces of 2" X 3" X 8' box tubbing and place them from the back of the head board to the end of the frame then remove the C notch I have to gain the extra 1 1/2" +/- This is where you come in what is the best way to attach the box to my frame ( I was thinking 3 plates ( say 3" wide) on each side in front of the axle and 2 behind it...... plates on both sides ) how strong will it be?? I need to be able to pull my 4000 lbs boat ( 250 lbs tongue wgt,) from the bumper Thanx
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-13-2011, 06:11 PM | #94 | |
Re: Pipe Notch
They don't offer them for 60-66? WTF??? That's Racist!!! LOL
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 Last edited by REDNOSE65; 01-13-2011 at 06:25 PM. |
01-23-2011, 12:04 AM | #95 | |
Re: Pipe Notch
01-23-2011, 12:59 PM | #96 |
Re: Pipe Notch
thank you again for all your knowledge and time invested. we all appreciate it. and im sure will all be sending people to this thread for years to come
03-21-2011, 06:58 PM | #97 |
Re: Pipe Notch
I reviewed this thread and was concerned that some of the information that was posted would be taken out of context and misused. To prevent this from happening I deleted my posts and reworked the data into the following:
Frame Notch Based On Strength
03-21-2011, 07:54 PM | #98 |
Re: Pipe Notch
thanx and I think I'm going to build your tub notch for my floor lift
03-21-2011, 07:58 PM | #99 |
Re: Pipe Notch
Very nice write up. Thank you for your expertise.
03-22-2011, 10:23 AM | #100 |
Re: Pipe Notch
Hey Lake Roadster, read this thread and your analysis with great interest, the information is invaluable and I would just like to ask a question about the beam analysis. You state that most of the strength is being added by adding material above the frame, I would say it is also being added by the double wall material in the tubing ?
1. If one built a 2.5" notch kit that had upper and lower frame flanges inside and outside of the frame lets say 5/16 110,000 psi yield strength material bolted in with grade 8 bolts couldn,t we pick up enough strength to equal the old frame. (I do not ask this to be critical just a different way of looking at the problem) 2. What is the section modulus of the stock 60-66 frame and the yield strength of the material. thanks in advance. Kieth |
