01-12-2011, 09:45 PM | #1 |
Re: The Fuse is Lit...
looking good, motor & trans R looking like they belong there, keep up the work & keep on truckin''
01-13-2011, 12:26 AM | #2 |
Still Learning
Hey Rocket, just wondering why you needed to add the extra length to the motor perches? Was it only to move the engine/tranny back 1.75"? I am trying to plan my motor install and really don't want to buy a bunch of high$ parts. If I can make or modify parts to that's what I to do. Where did you get the adapter plates? Did you make them or buy them? thanks
01-13-2011, 11:34 AM | #3 | |
The 6 cyl perches are mounted in the rear holes and should move the motor the closest possible to the firewall, allowing me more room up front for fans. That is the plan anyway. Here is a the thread I used to help me plan it out http://67-72chevytrucks.com/vboard/s...d.php?t=413855. I bought the #2 adapter plates off ebay and modified the passenger one to work. But with the instructions on that thread they should be easy to make. Hope this helps, let me know if I can answer anything else.
Rex |
01-13-2011, 12:18 PM | #4 |
Still Learning
Thanks for the link, I'm sure I will have more questions to ask.
01-20-2011, 01:18 AM | #5 |
Have most of the work done until I can put the cab on the frame. I am currently working on the cab at a friends bodyshop. I thought you might want some pics of the progress so far
Trying to use the fuel lines from the 04 Burb by rebending them.
Rex |
01-20-2011, 03:46 AM | #6 |
6>8 Plugless........
Very nice!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-20-2011, 10:19 AM | #7 |
67cheby
looking good man
01-20-2011, 07:59 PM | #8 |
looks great!
01-20-2011, 08:46 PM | #9 |
Christmas may be long past but I got a shipment from...
Santa Sharpie! The box it was shipped in was so nice it was almost a shame to open it...almost. Great looking pieces, Thanks Sharpie!
Rex |
01-20-2011, 08:49 PM | #10 |
sharpie is the man!!!!!!!!!!!!!!
01-29-2011, 11:19 AM | #11 |
GEARHEAD
If you go with the white top, also paint the windshield posts and door window frames to match. I would do the grill also if you went that route, but not the bottom of the body.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-30-2011, 05:19 PM | #12 |
VA72C10
nice work...and the lens may not be dirty...if you had just finished spraying it might have picked up the particles in the air...happened to me all the time when documenting my last build...
Looking for a 67-72 swb or blazer project in or around VA. |
01-31-2011, 10:11 AM | #13 |
67cheby
looking good
02-04-2011, 12:22 AM | #14 |
Primer and sand...and sand...and sand.
Rex |
02-04-2011, 12:32 AM | #15 |
VA72C10
Looking good! And I feel your pain with the sanding!!!
02-04-2011, 12:38 AM | #16 |
my favorite part of sanding was the door jambs and the roof on the inside! that was fun your lucky you have a big window! less metal.....
02-04-2011, 12:30 AM | #17 |
Still Learning
Diggin the roticerie. I bet that makes it a lot easier hitting the roof. Hey, you got any fingerprints left? Gotta love sanding.
02-04-2011, 03:21 AM | #18 |
Nice work! It is coming along nicely!
02-04-2011, 10:22 AM | #19 |
67cheby
quit typing.....back to sanding, only a few months left until Summer !!!
02-16-2011, 09:31 PM | #20 |
Has more rust than truck...
Rocketking, Have you test fitted the cab with the engine/trans in place? I tried putting my 4.8/4l80e all the way back like yours and the trans hit the pinch weld on the cab when I tried installing the trans mount. I ended up modifying my adapter plates to both be like your passenger side(1.75" forward). Body work is lookin great by the way!
02-16-2011, 10:43 PM | #21 |
Still Learning
What is the main reason for moving the engine towards the back? Just to close the gap at the firewall or to gain clearence for the cooling fan(s)? thanks
02-17-2011, 10:10 AM | #22 |
Room up front and wieght transfer were my reasons for trying, oh and it was easier to put it all of the way back because of the adapter plates i have.
02-17-2011, 12:02 PM | #23 | |
Thanks for the compliment on the body, I hope the major work on the cab is done! My main reason was for more clearence up front.
Rex Last edited by RocketKing; 02-17-2011 at 12:05 PM. |
02-17-2011, 12:10 PM | #24 |
67cheby
Have the cab painted next week.......wow !!! Smoking me
02-17-2011, 02:50 PM | #25 | |
