09-02-2010, 02:25 PM | #76 | |||
Re: project " Blue-Ray"
09-02-2010, 02:31 PM | #77 |
What's the plan for cruise control?
R.I.P. Killer 71 10/26/07 |
09-02-2010, 04:39 PM | #78 |
You have a NAPA in front of your shop! Tits!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
09-02-2010, 05:12 PM | #79 |
Under Construction
Awesome work Don!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
09-02-2010, 09:17 PM | #80 | |
09-02-2010, 11:37 PM | #81 |
no, the A/C compressor wont be bad at all...probley 30 mins. to R&R it if needed..take a look at kalebs black truck, it is alot less cramped then that...and also with your lift, it'll be super easy
09-12-2010, 08:24 PM | #82 |
bit more progress to report on blue ray....
got the wiring ran for the fuel pump, adding a factory style weather-pack connector. also installed the gas tank, fuel filter/regulator, and made/installed the braided SS fuel lines with the AN fittings....mounted the transmission cooler, fabbed the lines, and connected it all up..then i fabbed/installed the P/S lines...and finally, measured, bent, and installed the shift linkage.... Last edited by 68 short step; 09-19-2010 at 07:24 PM. |
09-12-2010, 09:04 PM | #83 |
Bixby oklahoma,used to work at oreillys there and professional body works for a few months.. Bixby sure has grown the last few years..Truck looks great!
09-12-2010, 09:34 PM | #84 |
Still Learning
Very nice progress! those stainless hoses look super clean! You may have already said, but where do you buy your hardware for the hoses and connectors? Summit racing? You have a parts list put together for a swap like this? thanks
09-12-2010, 09:50 PM | #85 |
With the transmission mounted at an angle like that ,is that the manufactures suggested mount or does it matter? Or does the transmission pump push it thru. on its on anyway? Will the shift indicator be able to show Overdrive for this style motor or will we have to change the shift viewing block out? Or would you just use the 1-2 3 low gear options for the O/D? Looking good though. Can"t wait.
09-12-2010, 09:56 PM | #86 |
Just a note: So someone like me will know for future use, What Temp does that transmission cooler keep the temp. at compared to a radiator type style?
09-12-2010, 10:38 PM | #87 | ||
the shift indicator will have a OD on it, im going to re-do the factory one so it'll read accurately.. specific temp, im not sure, ill have to see once its all up and running....but i can tell you that these heat sink designed coolers were desiged to work better then the traditianal tube/finned type... |
09-13-2010, 01:13 AM | #88 |
Second Chance Program
So awesome! Hard to tell, is that a metallic blue?
09-13-2010, 07:34 AM | #89 |
nice progress man. i love the bend you put in the shifter rod. looks good!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
09-13-2010, 11:20 AM | #90 |
Under Construction
nice work Don!
09-19-2010, 07:44 PM | #91 |
few more progress pics to post...
got a adaptor harness (first pic) made for the brake sw./ TCC control.. so its a factory (for 84) brake switch controlling everything, and its a simple plug in deal.. i also mounted, and wired in the OBD2 port, its on the driver side, and is easy to get to, yet inconspicuious..also blasted/painted the stock exhaust manifolds, and installed them...i then had a few friends over to help hang the front clip... it went well, and had it installed/bolted down in about 15 mins...once the clip was installed i put in a new battery perch (hard to see in the dark pic), but looks better then the rusty one it replaced...then determind the best place to mount the fuses/relays for the engine/trans, after going back and forth on either mounting them on the backside of the core support, or on the dr. side fender, i thought that they looked good on the fender and the fact that they are easy to get to made my decision...so i mounted them there....now came to the air intake, its a 4" chrome one that i had to 'tweak' the mount on it so it would mount to the head, rather then the battery box of a newer style truck (like it was designed to do) worked out nicely (only thing i have to do now is paint the bolt that holds it to the head)... |
09-19-2010, 07:56 PM | #92 |
looking great Don! i was wondering if you had some more info and pics of how that brake harness you built works?
09-19-2010, 08:49 PM | #93 |
Formerly- 1972SuperCheyenne
Hey man, what are your plans for the rest of the air intake? I need to build one myself so I was just curious.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
09-19-2010, 08:54 PM | #94 |
VA72C10
looking good. nice work
Looking for a 67-72 swb or blazer project in or around VA. |
09-19-2010, 09:51 PM | #95 |
looking good as always. I noticed radiator and condesner missing, Is that next? Will it have a K&N on end of intake? also how is that connection for brake assembly work, I guess I trying to figure that one myself. Keep it up though good job.
09-19-2010, 10:36 PM | #96 | ||
yes the radiator will be next, the condenser will be the same, just rotated so the fittings come out on the lower pass side, instead of the uppr driver side... |
09-20-2010, 03:31 PM | #97 |
chevy truck fan
68 short step,
would you mind telling me where you purchased the wire connectors for your gauges, i am looking to do the same for my '72 & i have no idea where to get the wire connectors??? thanks!! rodstored-72 |
09-20-2010, 07:11 PM | #98 |
are you talking about the plugins?
09-20-2010, 09:13 PM | #99 |
make the fenders look like the firewall!
09-21-2010, 11:20 AM | #100 |
chevy truck fan
yea i guess??? i think they are called "molex connectors"?? i am looking for a wire plug or plugs to run all the gauge wires to so that i have "plugs" between the dash harness & the new gauges.
thanks!! p.s. you are a very talented "garage tinkerer" LOL!! |
