Old 03-24-2011, 11:23 PM   #76
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: True C5 Rear Disc w/ internal parking brake in the works
8 sets left
thanks,
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-17-2011, 04:48 PM   #77
87chevy.com
7 sets left, last 2 sets at 160.
After the first 5 have been sold at intro pricing, the set price willl be 180.00 shipped.
Thanks!
Clint
Old 04-21-2011, 09:50 PM   #78
87chevy.com
6 sets left - 1 last set for 160 !
thanks,
Clint
Old 05-17-2011, 09:07 PM   #79
87chevy.com
last set sold for 160 shippped!
Last 5 sets for 180 shipped.
Thanks,
Clint
Old 05-24-2011, 12:06 AM   #80
layingC10nK5
Just received my kit today, everything looks great and shipped very fast. Great Guy to deal with, very helpful
layingC10nK5 is offline   Reply With Quote
Old 06-21-2011, 10:42 PM   #81
87chevy.com
Lets do a 4th of july special, rear brake kits back at 165 shipped. Sale ends 12 am on the 5th.
If you have been eyeing the kit, nows your chance to grab a set.
Kit now includes a 1/8 spacer for the ebrake cable holder to cable retainer if you choose to use the LS1 style cables. This spacer is the same thickness of one of the surfaces on the parking brake cable end. (photo of this soon). This allows you to tighten down the holder without putting a bind on the brackets. Added bonus.
Old 09-27-2011, 12:34 AM   #82
87chevy.com
4 sets left thanks fellas
clint
Old 12-13-2011, 01:50 PM   #83
aggie91
I'm just glad to be here!
aggie91's Avatar
How many sets do you have left?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-10-2012, 03:31 PM   #84
aggie91
aggie91's Avatar
Got my set yesterday, parts look good.
Where do you bend the bracket for the parking brake cable? I do not see a mark for bending it like in your rendering...
Karl
The LST Challenge:
Old 11-29-2012, 08:11 PM   #85
Gooker928
Hello.
I would like to buy a set.
I also live in Houston ( Hwy 6 & clay rd.), so I can pick it up if possible.
I would also like the number to the machine shop you used to modify the spindles.
Gooker928 is offline   Reply With Quote
Old 11-29-2012, 11:55 PM   #86
aggie91
aggie91's Avatar
Clint
I am getting my axles back tomorrow. I will be putting the brakes together sometime tomorrow. I got calipers and rotors from RockAuto.com I will have to paint the calipers to match the red front calipers we already have. I will post pictures of my set up this weekend.
Karl
The LST Challenge:
Old 12-01-2012, 11:39 PM   #87
aggie91
aggie91's Avatar
Got them mocked up yesterday. I do not have my e-brake parts yet so this is only the parts required for the caliper and rotor. I got my axles machined locally to have the register turned down to fit the C5 rotor and he faced off a groove near the outer edge that allows the rotor to sit flush. I did not have the OD of the flanged turned at all. I drilled my own rotors for the 5 on 5 pattern. Brackets looked good and had all the hardware I needed. Thanks again.
I did not get a picture of the caliper mounted but I will next time I go to the shop and get the rim off.
Karl
The LST Challenge:
Old 12-02-2012, 02:19 AM   #88
87chevy.com
Red face Re: True C5 Rear Disc w/ internal parking brake in the works
Looks awesome! Your chassis locks super clean!!
Clint
Old 12-02-2012, 05:17 PM   #89
bigmone
So what years do these fit? Up to 99 OBS?
bigmone is offline   Reply With Quote
Old 12-03-2012, 02:11 AM   #90
87chevy.com
If your rear axle flange measures :
http://www.southwestspeed.com/parts/...langeChart.jpg
Then it will bolt up. If you have 6 lug, you would need to get 5 lug.
Old 12-03-2012, 04:45 AM   #91
bigmone
Just seeing if any OBS guys have looked into this I have a 1990 c1500
Old 12-03-2012, 12:13 PM   #92
aggie91
aggie91's Avatar
I think the 1990 C1500 axle flange is the same. If it is, then this set up would bolt on. You may have to work out the spacing so that the caliper is centered over the rotor...
You really need to get under the truck and look at where the backing plate bolts to the axle flange. If the measurements of the bolt spacing matches the drawing linked in Clint's post above, then the brackets will bolt up.
Karl
The LST Challenge:
Old 01-04-2013, 12:13 AM   #93
Sanchez Garage
any sets left. Please pm or email me at fanacrnajo@gmail.com
Sanchez Garage is offline   Reply With Quote
Old 07-01-2013, 10:57 AM   #94
aggie91
aggie91's Avatar
Clint, I am getting closer to putting Korbin's truck on the road. I got the rear brakes all mounted up, just waiting on installing new studs in the axle before buttoning up the rear end.
I got all teh E-brake parts I needed from corvetterecycling.com. Here are some pictures:
Had to make a slight modification to your bracket to mount the e-brake cable.
Karl
The LST Challenge:
Old 07-02-2013, 01:05 AM   #95
87chevy.com
Looks killer! I should have painted my brackets lol.. I was anxious
Clint
Old 07-02-2013, 09:47 AM   #96
aggie91
aggie91's Avatar
I got my axles done with the new studs last night. I had an issue getting the passenger side axle pushed in far enough to get the C-clip in. I ended up taking the limited slip springs and plates out to get just enought room to get the clip in place. Now I have to put the plates and springs back in. That is going to be a pain, we tried for about a hour, but no luck. Stopped and went to bed, will try again tonight.
Did you have any issues getting the axle to push in far enought to get the clips on?
Karl
The LST Challenge:
Old 07-03-2013, 09:59 AM   #97
87chevy.com
Maybe remove the parking brake bolt and shave it down. I think that's what I did on one side or both. Or installed the axle without the parking brake plate top bolt in and then wiggled the shoe on at the end.
Clint
Old 08-08-2013, 09:54 AM   #98
aggie91
aggie91's Avatar
Got is all together and been driving it a bit. Korbin likes the way it stops and the parking brake holds well. I think I might have an issue with my booster, but overall I am very happy at this point.
Karl
The LST Challenge:
Old 10-27-2013, 11:44 AM   #99
JustN
anymore of these kits?
JustN is offline   Reply With Quote
Old 10-28-2013, 12:00 PM   #100
87chevy.com
1 kit left
-clint
