06-29-2011, 11:24 PM | #1 |
Re: 2 for 1, My son's first Square Build
That could be a problem lol...
1980 1/2 ton shortbed project 1978 grand prix project Never stop trying... |
06-30-2011, 12:14 PM | #2 |
I'm just glad to be here!
korbin again, i knew that i didn't have tires, but i knew that i could get my hands on wheels, and plywood i think i'm going to combine the ratchet strap/ engine hoist idea sometime soon.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-30-2011, 09:37 PM | #3 |
Good idea...
06-30-2011, 02:16 PM | #4 |
Subscribing. Can't wait. Thoughts of doing this with my oldest son. He's 19, though.
'85 SWB Silverado |
08-19-2011, 04:01 PM | #5 |
Glad you guys are back to work on my "ex". Don't let your dad sluff off now just because he's an invalid.
07-01-2011, 01:05 AM | #6 |
korbin again,i know its a long way ahead in the build process, but i want to lower it for sure i'm not alowed to let it lay frame, since it will be my dd, but i am alowed to bag it, as long as if a bag blows, it wont drag the frame. i'm think a step notch( little one) in the rear and a flip kit w/ bags. for the front, i don't really know, but i like how n2trucks' 77 cheyenne sits, so...i know i need drop spindles, but lowering arms? i want bags. but i dont know exactly how to go about it. more questions. what is the difference between a 2 or 3 or 4 link suspension and how does it work? ( may be a dumb question but hey, i gotta learn somehow!)
07-01-2011, 01:50 AM | #7 |
If I was on my computer I could throw up a couple quick sketches to explain the whole suspension thing, but I'm not...so I'll do my best to explain it verbally, which is something I'm not good at... Suspension geometry is something I got really into a couple years ago though. Do you know how the control arms work on the front of your 2wd truck?
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
08-08-2011, 01:49 AM | #8 |
korbin, again, i got the bed off a while back then i had multiple summer camps, when i got home, i got the rearend out, and once its rebuilt, the plan is to put it back in with a flip kit and c notch. now, i plan on cleaning the firewall a little bit soon. then i will probably go to work on the front suspension with a bushing rebuild kit. when it all goes back together i will go with drop spindles and drop springs.when i clean the firewall, what is my best bet, lacquer thinner, acetone??? will try to get pics soon
08-09-2011, 01:55 PM | #9 |
daydreaming here, i'm set in stone that i want either american eagle 225's or boss 338's in chrome. when i lower it ( hopefully soon ) i'm gonna go with sport truck direct's 4/6 economy lowering kit. to add a little rake i may replace the 1.5 inch drop coils that come with that kit with 2.5 inch coils. i know that their deluxe drop "b" come with a towing bag kit for the rear and new leaf spring for a smoother ride. but is it worth it? because it's nearly $300 more expensive...
"As I walk through the valley of rice i fear no honda, for i have torque!" |
08-15-2011, 01:42 PM | #10 | |
Check w/our board supporting vendors or try Summit Racing for your drop parts. As for the brake lines, the OE style rubber will last plenty long enough & get the job done w/o added expense; braided lines on these trucks are just 'bling'.
08-16-2011, 01:52 PM | #11 | |
08-16-2011, 02:58 PM | #12 | |
a fool with no money
I did it by myself using 4 jackstands, a floor jack, and four 2x6 boards. basicly, I went around to each corner of the cab and jacked it up until I could get two of the boards all the way across the frame and sticking out the sides, then layed the other two front to back on each side of the cab, put my jack under that board and jacked it up until it made contact with the boards going across the frame, and supported them, where they intersected, with the jackstands. jacked up the back of the truck, took off the rear wheels (had to do this to clear the jack stands, slid a two wheel dolley under the rear end with the handle on the driveway facing towards the front, let the jack down, and pushed the frame out from underneath the cab, back to front. took a while but it worked. btw... think i met your dad at Toppin it all Off car show last year. I had the black pro street inside the building.
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
08-15-2011, 01:36 PM | #13 |
Hey guys, quick question, performance and price wise, what are the difference between braided and regular brake lines?
08-16-2011, 02:12 PM | #14 |
well korbin u have a lot of very good ideas to make a killer truck. glad to see theres more younger generation who love these trucks instead of big wing imports
08-16-2011, 02:30 PM | #15 |
thanks man i agree all my friends are drooling over this chinese pieces of crap and lamborghinis and big new 4x4 fords that will never see dirt, and the sad part is, they will never ever drive something that expensive, have fun in your honda's guys...
08-16-2011, 03:35 PM | #16 |
that's sorta kinda thinkin that's how i was gonna do it, where was the toppin it all off show? i think i may remember your car
08-16-2011, 03:41 PM | #17 |
Maud Cobb... around Sept
08-16-2011, 03:51 PM | #18 |
oh yeah i don't remember real well but i remember the show, if i saw you in person i'd recognize you
08-16-2011, 10:25 PM | #19 |
Well we got a little more done this afternoon when I got home from work today. I have not been much help lately since I had surgery on my foot. Korbin and I got the entire front suspension apart and he has taken all of the rear suspension off with the help a friend and only asked me for advice on the rear.
Next we hope to get the cab off and get the rest of the frame stripped down for blasting... I will get him to take pictures in the daylight and we will post them up tomorrow.
08-17-2011, 09:44 AM | #20 |
gig'em...
check your P.M.s I think I have a solution to lifting Korbin's cab
08-17-2011, 01:30 PM | #21 |
look at that ball joint!!!
08-17-2011, 02:40 PM | #22 |
LOOK AT THAT GREEN GRASS! LOL
you better take your dog for a ride in that when you get it done, cuz she's gonna be pissed that you took her shade from her!
08-17-2011, 03:44 PM | #23 |
it's a he, his name is beaux and yes, he loooovves his cool spots. we also have another dog named daisy. it's kind of a love hate relationship with them when i'm under it wrenchin because they come in and lick, and lick, and lick, and lick, and lick, and lick. but then i bring out the power tools *makes tim allen man bark* and they get scared and run away, at least beaux does, daisy smart enough to know i wont hurt her...
"As I walk through the valley of rice i fear no honda, for i have torque!" Last edited by Can't kech me; 08-17-2011 at 03:48 PM. Reason: spelling and typing isn't my thing |
08-17-2011, 03:53 PM | #24 |
Daisy
beaux
08-17-2011, 10:22 PM | #25 |
Yeah that green grass is the benifit of my yard being down hill from the neighbor. When he waters, his run off runs thru my back yard. There is a strip about 15 feet wide that is lush and near perfect. The rest of the back yard is dry, brown and barely surviving this heat.
Those dogs are the best. Daisy is the smart one and Beaux is the lazy one.
Tags |
project, son, square body |
