Old 07-25-2011, 10:00 AM   #76
luifer76
luifer76's Avatar
Re: 84 C10 Project
truck is looking really good bro it sucks you have to cut the be tho....how much do you have to cu?....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 07-25-2011, 10:52 AM   #77
Pro Performance
Pro Performance's Avatar
Re: 84 C10 Project
I just need to raise it enough to clear the 1-1/2" tube I have sitting on top of the frame. But, I think to make it look clean and not so much like an after thought, I will put a rise about 3" in between the fenderwells.
I think this is the easiest solution, rather than completely re-doing my x-member and tank brackets that come off of it. Seems a liitle odd to have this when I dont have a step notch, but, kind of have no choice now. I wanted it all under the bed.
Kind of like this.
Pro Performance is offline   Reply With Quote
Old 07-25-2011, 08:23 PM   #78
luifer76
luifer76's Avatar
Re: 84 C10 Project
that should look pretty good....
Old 07-27-2011, 01:23 PM   #79
Pro Performance
Re: 84 C10 Project
I want to paint the exhaust on my truck, and not really sure what color to do it. Want to see what you guys think. All my suspension and frame is black, so i am looking for a little contrast, but at the same time, all flat black exhaust would be kind of sinister.
A) Flat Black Exhaust
B) Silver
C) Charcoal, if I can find it in a high-heat paint.
Old 07-27-2011, 01:45 PM   #80
luifer76
luifer76's Avatar
Re: 84 C10 Project
well since your frame is black paint the exhaust silver that way it can stand out.......
Old 07-27-2011, 01:47 PM   #81
Pop's C-10
Pop's C-10's Avatar
Re: 84 C10 Project
silver with some other parts painted silver to...maybe tha oil & trans pan..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-27-2011, 04:04 PM   #82
Pro Performance
Re: 84 C10 Project
Yeah, silver might break it up some. I just think the black would look clean and simple.... kind of tough looking.
Old 08-05-2011, 09:39 AM   #83
Pro Performance
Re: 84 C10 Project
It has been a little bit since I worked on my truck. But I did pick up my Nitto NT05 tires yesterday. 315/35/20 for the rear, and 255/35/20 for the front. Now i just need to measure for backspace and order my wheels.
Old 08-05-2011, 03:20 PM   #84
kikkegek
kikkegek's Avatar
Re: 84 C10 Project
yeah baby!
kikkegek is offline   Reply With Quote
Old 08-05-2011, 05:13 PM   #85
luifer76
luifer76's Avatar
Re: 84 C10 Project
nice set of tires......
Old 10-01-2011, 08:32 PM   #86
Pro Performance
Re: 84 C10 Project
It has been a while since I have worked on my truck, but plan on making some progress soon and finishing the front end.
Here are the Choppin' Block arms that arrived. They are a very nice part and well built. Quality arms.
Old 10-01-2011, 08:34 PM   #87
luifer76
luifer76's Avatar
Re: 84 C10 Project
Nice arms bro i cant wait to see thing all laid out......
Old 10-03-2011, 11:37 AM   #88
Pro Performance
Re: 84 C10 Project
Here are some more pictures of the truck. This is shown with no springs in the front at all and using a stock spindle. It is sitting on the rubber bump that wont be there with the new arms. I think once everything goes in, it will drop the crossmember on the ground. Just though I would share a few photos. The back is aired out right now also.
Old 10-03-2011, 11:45 AM   #89
luifer76
luifer76's Avatar
Re: 84 C10 Project
it looks good bro.....
Old 10-03-2011, 02:13 PM   #90
dlhughes2005
Re: 84 C10 Project
Nice build!
85 GMC SWB: Fuel Injected 454, TH400, soon to be laying frame on 22s
96 Trans-Am: Full bolt-ons, Weld Rodlite skinnies and fatties
95 GMC Yukon 4x4: 2door all stock with the exception of glasspacks and duals
dlhughes2005 is offline   Reply With Quote
Old 10-23-2011, 04:10 PM   #91
Pro Performance
Re: 84 C10 Project
Got some work done this weekend. The passenger side front is mostly done. Still have to mount valves, trim fender to clear tire, and finish steering. Got the McGhaughy's 2.5" drop spindle, The Choppin' Block arms & Slam Specialties bags. Still have brakes left, which I will be going with the Wilwood D-52's.
Aired out.
Aired up.
Old 10-23-2011, 05:56 PM   #92
luifer76
luifer76's Avatar
Re: 84 C10 Project
truck looks great bro it actually looks like it lays lower than the previous pic you posted nice job so far man....
Old 10-23-2011, 10:37 PM   #93
SS Delux
SS Delux's Avatar
Re: 84 C10 Project
Are you going to have to cut the tubs in the bed to fit that tire in ?
SS Delux is offline   Reply With Quote
Old 10-24-2011, 09:16 AM   #94
Pro Performance
Re: 84 C10 Project
No, they will fit in the stock tubs, but is a tight fit. Just have to get the back space just right.
Old 10-24-2011, 05:16 PM   #95
Pop's C-10
Pop's C-10's Avatar
Re: 84 C10 Project
Nice looking tread
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 11-06-2011, 10:52 PM   #96
Pro Performance
Re: 84 C10 Project
Thanks. I am really close to having the wheels finished and mounted on the truck. I really can't wait to get it back on the ground and at least driving.
Where are most of you mounting your battery?
Old 11-09-2011, 05:40 PM   #97
foamypirate
foamypirate's Avatar
Re: 84 C10 Project
Looking good! Great progress!
What process did you use to get that gas tank so clean? Did you use a wire wheel, sand paper, etc?
foamypirate is offline   Reply With Quote
Old 11-09-2011, 06:29 PM   #98
Pro Performance
Re: 84 C10 Project
I just used a wire wheel on a 4-1/2" grinder. That's how I did all of my frame and anything else I removed paint from. Works well, just sometimes hard to get in tight areas.
I was also surprised about how clean the tank came out after wire wheeling it... and it was extremely easy to get it that clean before painting. I am assuming that is because it is aluminum.
Old 11-09-2011, 07:32 PM   #99
foamypirate
Re: 84 C10 Project
Right on, thanks for the quick response!
Old 11-13-2011, 07:33 PM   #100
Pro Performance
Re: 84 C10 Project
Got the last corner done, and now the whole truck is bagged! The underneath is almost there, next is the core support. But first, I want to wire up the valves and compressors.
I thought I was going to have to change out my headers, but they actually clear. The arms hit the ground first, and actually start to lift the wheels. Overall, I am satisfied with the amount it drops. Wish it went down a little further, but I expected this having a stock crossmember and no step notch.
Wheel should be finished soon also!
