Old 02-06-2011, 02:03 AM   #76
butternut1972
butternut1972's Avatar
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
Looks sweet!
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 02-07-2011, 01:22 AM   #77
Hoffa
Hoffa's Avatar
Keep up the great work!
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973.
70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch
72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior
Hoffa is offline   Reply With Quote
Old 02-15-2011, 08:56 PM   #78
mcmlxix
Collector of Projects
mcmlxix's Avatar
Frame looks great... nice Duc too....
Rich
1972 K5 Blazer CST Click HERE
Old 02-26-2011, 03:40 PM   #79
Robertjust777
how is comming along and im here in vegas what part do you live in?
Robertjust777 is offline   Reply With Quote
Old 02-26-2011, 05:27 PM   #80
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Clean build keep the pics comming..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-26-2011, 06:24 PM   #81
Posi12Bolt
Originally Posted by trkfrk View Post
what finish is that?
2011 GMC Yukon XL - Denali/Escalade Mutt
2003 Moomba Mobius LSx Swap'd
1987 IROC-Z Original 90k miles, 2nd owner
1972 Chevy C10 - Dropped & Shaved
1970 Chevelle SS396 - currently in Body-off Resto
1970 Chevelle (LSx TT 4x4/SUV Chassis Project)
Posi12Bolt is offline   Reply With Quote
Old 02-28-2011, 12:20 PM   #82
67cheby
67cheby
67cheby's Avatar
SUPER clean...nice work
67cheby is offline   Reply With Quote
Old 03-16-2011, 01:13 PM   #83
BlackZ28
Your building my dream truck! Any other updates?
BlackZ28 is offline   Reply With Quote
Old 04-08-2011, 01:06 PM   #84
BobDuher
Thanks for sharing your pics....I have a similar build. I have a 72 C10 Shortbed with a 2000 Camaro SS LS1 with auto trans. All of the body is off and getting painted. I'm currently working on the frame. There's not a lot of header options. I think the Doug Thorley's that you have are the best option.
BobDuher is offline   Reply With Quote
Old 04-09-2011, 12:45 AM   #85
Nova_Cobra64
Nova_Cobra64's Avatar
I noticed you still have the shifter in the stock location, do you have any pictures of where the shifter ends up inside the cab? I'm doing an LS3 swap in my truck and will be putting a manual tranny in. I was planning to go with an RS600 but it seems like Keisler isn't terribly eager to do business so I'm thinking of going the T-56 magnum route from a different supplier as it seems like there are too many horror stories out there with the TKO's.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 04-09-2011, 01:08 AM   #86
y5mgisi
Second Chance Program
y5mgisi's Avatar
Should be one awesome driver when its done!
y5mgisi is offline   Reply With Quote
Old 05-17-2011, 07:37 PM   #87
trkfrk
trkfrk's Avatar
Sorry for the late reply. see picture where the shifter is located inside the cab. For now I notched the cab floor 1 3/4" X 3 1/2".
Installed front suspension 2.5" drop spindle & 1.5" drop spring
rear end disassembled for PC, new bearings/seals
rear end and all suspension parts PC. installed 6" lowering springs
cab is set back on for now. Waiting on rear disc brakes and tires to set back on the floor.
Thank you for all of the compliments!!!!
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 05-17-2011, 07:50 PM   #88
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
looking good, nice progress
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 05-17-2011, 08:38 PM   #89
mikekaiser
What exhaust headders are you using?? Can you run manual clutch linkage with them?? Also who's motor mount kit is that?? It is very clean!!
Thanks,
Mike
mikekaiser is offline   Reply With Quote
Old 05-17-2011, 09:20 PM   #90
mcbassin
Still Learning
mcbassin's Avatar
Great progress! Couple of questions, are you using shock relocating brackets? What shocks are you using? thanks,
mcbassin is offline   Reply With Quote
Old 05-17-2011, 11:42 PM   #91
67cheby
67cheby
67cheby's Avatar
man that looks killer
Old 05-17-2011, 11:46 PM   #92
VA72C10
VA72C10
VA72C10's Avatar
great build!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-18-2011, 12:04 AM   #93
wtchop
wtchop's Avatar
wow awesome build!!
wtchop is offline   Reply With Quote
Old 05-18-2011, 12:51 AM   #94
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Haven't check on this one in a while, Looks great!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-18-2011, 05:24 AM   #95
skoffice
skoffice's Avatar
Beautiful build! Man I wish I had my chassis parts powdercoated.. it really makes everything stand out
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 05-18-2011, 06:48 AM   #96
Bennett68C10
Bennett68C10's Avatar
Nice build, love the ls1/6 speed combo.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-18-2011, 10:09 AM   #97
texastrendz
nice build, is the shifter going to be under the front seat. looks way back in the pics. i like the finish of your frame, i had mine powdercoated in a smooth gloss and it was the worst mistake i made.
texastrendz is offline   Reply With Quote
Old 05-18-2011, 02:40 PM   #98
68 TT
Still plays with trucks
68 TT's Avatar
What do you regret about the smooth gloss on the frame? The gloss color instead of satin or something else?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 05-18-2011, 03:15 PM   #99
texastrendz
if you breathe wrong on the gloss finish it scratches. you have to be way to carefull during assembly. go with a semi gloss finish when you coat it or it will take decades to reassemble it without scratching it. i went with a super wet black, bad mistake.
Old 05-19-2011, 08:40 AM   #100
68 TT
68 TT's Avatar
Good to know. I was trying to make up my mind on which to go with satin or gloss on the frame. That makes the decision for me. Thanks for sharing, I'm sure it will help others make the right choice too.
