Old 12-26-2010, 11:04 AM   #76
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: #3 The Sickness Continues
Hey Jeff,
Nice ride! I looked at that truck when I was looking for one. I almost purchased it, but then found mine the next day. I got lucky and was the first to look at mine, so I didn't hesitate...
You did a sweet job on it. I like the ride height. I'm gonna have to drop mine a little more like yours.
I need to get a radiator for mine and I'll have to take a trip to the East side and check out your rides in person
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 12-26-2010, 11:56 AM   #77
Dinos63
chevy only
Dinos63's Avatar
looks 100% BETTER ,nice work kat what a nice truck
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-26-2010, 12:03 PM   #78
protrash64
Resistance is Futile
protrash64's Avatar
Thanks guys.....mechanically this truck has been maintained but needed to have things updated. Bodywise it's a little rough but not horrible...at some point the welder will be out
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-26-2010, 06:09 PM   #79
protrash64
protrash64's Avatar
Here are some pics of the updates.........
1. Overflow bottle, battery, and new fuel pump.
2.Headlite relays: notice the new harness plugged into the old switch plug
3.Peel and Seal under the seats...... on the sound level!
4.Kick panels with JBL speaks mounted.......
5.Added a relay with battery power and keyed switch fuse panel...easy accessories
Old 12-26-2010, 06:15 PM   #80
protrash64
protrash64's Avatar
Almost forgot........tunes
Old 12-26-2010, 07:42 PM   #81
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Looks good Jeff
Did you use the relay kit from LMC? I had my wifey get me one for Christmas and I just spent all day today installing it and trouble shooting because the lights were dimm unless I hit the high beams... After while, I figured out that they had the high beam wire and ground wire in the connector swapped on the outer two lamps which was powering up the ground... I should have just bought new lamp pigtails and wired it myself... I figured this would be the easy way out, but was wrong...
Sorry for the rant, just wondering if you had the same kit and troubles.
Great work, keep the pics coming
Tony
Tony
66 GMC LWB
Old 12-26-2010, 08:28 PM   #82
mosesburb
I had a V-8
mosesburb's Avatar
Looks cool man!! Great raw material to start with. What ever happened to that old Suburban that you put the big block in??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 12-26-2010, 09:11 PM   #83
protrash64
protrash64's Avatar
Originally Posted by AZ66GMC View Post
Looks good Jeff
Did you use the relay kit from LMC? I had my wifey get me one for Christmas and I just spent all day today intsalling it and trouble shooting because the lights were dimm unless I hit the high beams... After while, I figured out that they had the high beam wire and ground wire in the connector swapped on the outer two lamps which was powering up the ground... I should have just bought new lamp pigtails and wired it myself... I figured this would be the easy way out, but was wrong...
Tony
Tony, the kit I got was from Classic Industries and looked like it was for a 'tuner' or something....yellow braided covering, etc. I checked out the harness and found I didnt understand the way it was set up. It appeared as though it used switches that ground, like a horn circuit, for eg. I cut off their connector and grounded 85 or 86 to the body(cant ever remember the damn #) used the other wires to plug into the the original plug. It came with the headlite plugs wired correctly and everything worked. So my original headlite switch sends power to ground thru the relay which in turn sends juice from the battery to the headlites(30 to 87).
Thanks mosesburb....still have the 'burb. I drove it around this summer a bit and it wouldnt start. I think I fried the ign module as I had a bad alternator and was only running on 11v for awhile before I figured it out. Due to frustration I havent touched it since that day. Needs a new harness badly!!
Old 12-26-2010, 11:05 PM   #84
daverod
SSN 706
daverod's Avatar
Who needs peal and seal when you have tunes.
daverod is offline   Reply With Quote
Old 01-09-2011, 12:56 AM   #85
protrash64
protrash64's Avatar
Couple new/old pieces today. '72 anti-sway bar and a set of original heater controls......need to pick up some bushings for the bar and get it on there.
Old 01-12-2011, 11:52 PM   #86
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Looking good!!!
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 01-13-2011, 12:44 AM   #87
daverod
SSN 706
daverod's Avatar
I just saw one of those heater controls sell on ebay for about 30. I need to do the head light thing. What's the keyed switch fuse panel?
Old 01-13-2011, 10:25 PM   #88
protrash64
protrash64's Avatar
Originally Posted by Mad Rods View Post
Looking good!!!
Thanks dude!!!!!
I was cleaning up the wiring as I started finding wires that do nothing, wires hooked to the fuse block and going nowhere.....you know how it is. There was a section of wire with about 3 crimps, tape, and six different wires going every which way and it was all hooked to the ignition switch. I wanted to clean it up and add some stuff so I made the ignition switch turn on a relay which then powers the fuse panel fed from the battery. I relocated the switched stuff to the fuse panel so it doesn't draw power thru the switch anymore; plus I can add if I need to do so later.
Old 01-13-2011, 10:34 PM   #89
protrash64
protrash64's Avatar
Oh yeah.........here is my new shifter. I'll be installing this when I get to the tranny once over.
Old 01-14-2011, 11:19 PM   #90
protrash64
protrash64's Avatar
OK, a weeks progress and I'm just about done with everything I want to do to this thing. Mounted the tool box up on 4'' stands so it has clearance underneath and is flush with the bed sides.
Today I took on the sway bar install. Cleaned it up and painted it gold. Why? Cuz I had 1/2 a can of gold hammertone.....picked up some new bushings and grade 8 bolts.
Got going on this and ran into a PO's project. 1/4'' plate hoops on the front frame. This made drilling a real PITA. Yet once again, I managed to win out over the truck.
Old 01-14-2011, 11:28 PM   #91
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks good.
I like the gold sway bar!
I bet it drives much better.
Keith
Convert to disc brakes.
Old 01-15-2011, 06:11 PM   #92
protrash64
protrash64's Avatar
Still plugging away!!! Pulled the tailgate and I am going for the fauxtina attempt to match the truck. Using all Rustoleum products.....fun anyway. Also started cleaning out the drip rail around the roof. I will add new seam sealer and then paint the roof.
What color do you think it should be?? I was leaning toward white but thought maybe silver, or metalflake white??
Old 01-15-2011, 06:55 PM   #93
daverod
SSN 706
daverod's Avatar
So you had a fun time drilling did u. Damn I should have painted mine gold. I did know it made it handle better. Nice looking tailgate. What the hell were the hoops for?
Old 01-15-2011, 07:31 PM   #94
CVA59
PRO...... Your truck is looking great! Those Rally wheels really set it off.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 01-15-2011, 10:32 PM   #95
protrash64
protrash64's Avatar
Drilling sucked. Everything was fine except for the front bolts thru those hoops. I have no idea what they were for..... The gold paint keeps you from driving like an idiot and scraping it on stuff
Thanks CVA59.....this one is coming together well.
Nobody has a color opinion??
Old 01-15-2011, 10:52 PM   #96
lolife99
lolife99's Avatar
I say a 1964 white.
Keep it looking stock.
Keith
Old 01-16-2011, 12:15 AM   #97
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Man, I'm really on the fence on the color. Silver keeps popping in my mind. my .02
Alan's Classic is offline   Reply With Quote
Old 01-16-2011, 09:28 AM   #98
protrash64
protrash64's Avatar
I say a 1964 white.
This was my first thought; I'm leaning toward white.
Silver was my second idea. I like it a lot but the sun out here kills silver paint. It lead me to the middle of the road with a metallic white or flake clear over white......it's all for fun and practice!!
Old 01-16-2011, 04:32 PM   #99
SkullCandy
Nice driver!
1990 Dodge Ram D250 Cummins
SkullCandy is offline   Reply With Quote
Old 01-16-2011, 10:59 PM   #100
66BowTieBoy
66BowTieBoy's Avatar
Do they make 1 piece windows? Think I'll stick some insulation in my doors.
NO LIMIT ENGINEERING in San Bernardino California offer a kit for a little over $400. ( nolimit.net ) is their website and there's an interesting article about it.
Here's a link: http://www.classictrucks.com/tech/04...ows/index.html
It's in their technical section as, Project Old School-Building Out the Doors.
HAPPINESS IS A COLD BEER, A SATELLITE DISH & QUALITY TIME WITH MY DOG....!
66BowTieBoy is offline   Reply With Quote
